Old 05-02-2008, 01:50 PM   #1 (permalink)
stealth-TwnTrbo's Avatar
Drives: 92 Stealth TT 400WHP
stealth-TwnTrbo is an unknown quantity at this point
Default AEM EMS Knock Voltage Reading
On my logs i am seeing knock voltage about 0.5 volts what is severe knock or to much knock?? I was told real knock was only over 1.5 or high anything less than that on the AEM is just noise, does anybody know what real knock is based on voltage on the AEM.
92 Stealth R/T TT
CurrentMODS:
K&N FIPK
Ultimate Performance Short Throw
HKS Turbo Timer Type-1
Greddy Profec B Spec II
Greddy Type S
GEN 3 Lifters
3sx Crank Pulley
Accel 8.0mm Wires
Denso IK24's .032
Borla Catback
Stillen Downpipe no Cats + Gutted Rear Pre-Cat
Denso Supra Pump Hotwired
AEM FPR @ 46 psi + RobBecks Fuel Rail Adapter
PST 2 Piece Hybrid Aluminum Driveshaft
Aeroquip Fuel Rail Loop Adapter
680cc PTE's
AEM EMS
AEM Wideband 02
Vibrant Performance FMIC Core Custom Piping
2 x TD04 15G's W/ HL Exhaust Wheel
395 AWHP @ 16 PSI on 93 405 AWTQ.
Stopping: Stillen Front and Rear Cross Drilled Rotors
Stock Arctic Cat F-7 World Record Holder on Grass 500FT 5.313 ET @ 90.92 MPH
stealth-TwnTrbo is offline   Reply With Quote
Old 05-02-2008, 05:30 PM   #2 (permalink)
Banned from Classifieds
Dj4play's Avatar
Drives: 3000gt x3
Trader Rating: (25)
Dj4play Level 4Dj4play Level 4Dj4play Level 4Dj4play Level 4Dj4play Level 4
Default Re: AEM EMS Knock Voltage Reading
2 volts is about where you need to watch what your doing. What your experiencing is just noise. UNLESS you have solid mounts, your "noise" should always be under .75 volts or thereabouts.
Dj4play is offline   Reply With Quote
Old 05-02-2008, 08:03 PM   #3 (permalink)
New project in the works
niterydr's Avatar
Drives: Tractionless wonder
Trader Rating: (33)
niterydr Level 3niterydr Level 3niterydr Level 3niterydr Level 3
Typically the 3s displays under 1.5V's of knock threshold voltage.
However any sharp spikes or inclines could be real knock. What is the current state of your tune? How much boost and ignition timing? What is your pick/delay comp and ignition sync at?
The knock voltage and knock raw #1 should ramp up with a steady increase in rpm.
-Josh
mildly modified blue 93 rt/tt-SOLD
3780lbs, pump gas 3/s. 127.08mph-92 octane.
I still tune cars!
new project, T.B.A
niterydr is offline   Reply With Quote
Old 05-03-2008, 08:42 PM   #4 (permalink)
My car was tuned and is good, it made good power A/F's in the mid 11.3-11.6 timing is at 21 degrees at 7k boost is about 17 psi. I was just playin with the boost and watching knock but im only getting 0.5 max on the knock voltage, what is considered dangerous voltage ?? 1.75v - 2.25v???
Old 05-03-2008, 10:21 PM   #5 (permalink)
Panda Master
maTT's Avatar
Drives: In place @ 200
maTT Level 7maTT Level 7maTT Level 7maTT Level 7maTT Level 7maTT Level 7maTT Level 7maTT Level 7maTT Level 7
Your knock volts is dependant on your knock cal table. If your knock control is on then the knock volts = knock raw - knock cal table. Have you made a knock cal specific to your engine? Is your knock control turned on?
www.3sx.com
1992 VR4 - Sold - 12.5@110
1991 SL - Sold - 16.5@85
1993 RT/TT - Sold - 11.44@129.3
1992 VR4 - Sold
1994 VR4 - Sold
1993 SL - Retired - 10.19@140
1991 VR4 - Retired - 9.21@159
1993 VR4 - Sold
1992 Base Stealth ATX - DOHC TT
maTT is offline   Reply With Quote
Old 05-04-2008, 02:35 PM   #6 (permalink)
niterydr's Avatar
Trader Rating: (33)
Like Matt says, that is dependant upon your knock cal table.
Do you have a file or log you can post?
Old 05-04-2008, 03:10 PM   #7 (permalink)
Play that Funky Music
Import Power's Avatar
Drives: Vicki Insane
Trader Rating: (209)
Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7
Are you saying 2 volts Knock #1 ABOVE your Knock Raw volts?
Or 2 volts Knock Raw?
And are you saying "Noise", Knock Raw should be under .75 volts? Cause noise would be noise without knock, and .75 volts noise (knock raw during knock cal runs no boost low timing) is a damn quiet engine. Quiter than any 3S I have done a knock cal on.
Personally, and I know this leaves some power on the table (where is this damn table everyone leaves power on anyway?) I run the knock cal run, no boost low timing 93 pump. Add 20% even though I have seen 25% is allowed, make that my knock cal map, then when I seen ANY blips of Knock #1 volts I adjust the timing so the runs are dead quiet. Not one spec above the cal table. I know it's leaving power down but I play it safe.
AEM Factory Trained Tuner
T4 AWD 9.21 @ 154.98
T2 FWD 10.19 @ 140.31
T4-995AWHP Uncorrected 6G72 3.0L
91VR4 Red-17Gs w/supporting mods-sold
93SLTT/T2
91VR4 Pearl White-sold
91VR4 Black-sold
92VR4 Sandstone-sold
94VR4 Green-sold
93VR4 Pearl White-currently parting out
91VR4 Black-Currently building "daily Driver"
3SX Performance
3SX Performance Service Email
Import Power is online now   Reply With Quote
Old 05-04-2008, 04:12 PM   #8 (permalink)
And how do you guys do a knock cal run? No boost (open WGs) or low (WG pressure) and low timing?
2nd or 3rd gear?
Old 05-05-2008, 07:38 AM   #9 (permalink)
Yea i will post a log later today of 2nd and third gear, i had my car tuned at IPS and knock control is enabled. I'll post logs later this afternoon.
Old 05-13-2008, 06:54 AM   #10 (permalink)
logs???
