#1 (permalink) |
On my logs i am seeing knock voltage about 0.5 volts what is severe knock or to much knock?? I was told real knock was only over 1.5 or high anything less than that on the AEM is just noise, does anybody know what real knock is based on voltage on the AEM.
92 Stealth R/T TT
CurrentMODS: K&N FIPK Ultimate Performance Short Throw HKS Turbo Timer Type-1 Greddy Profec B Spec II Greddy Type S GEN 3 Lifters 3sx Crank Pulley Accel 8.0mm Wires Denso IK24's .032 Borla Catback Stillen Downpipe no Cats + Gutted Rear Pre-Cat Denso Supra Pump Hotwired AEM FPR @ 46 psi + RobBecks Fuel Rail Adapter PST 2 Piece Hybrid Aluminum Driveshaft Aeroquip Fuel Rail Loop Adapter 680cc PTE's AEM EMS AEM Wideband 02 Vibrant Performance FMIC Core Custom Piping 2 x TD04 15G's W/ HL Exhaust Wheel 395 AWHP @ 16 PSI on 93 405 AWTQ. Stopping: Stillen Front and Rear Cross Drilled Rotors Stock Arctic Cat F-7 World Record Holder on Grass 500FT 5.313 ET @ 90.92 MPH |
#2 (permalink) | |
Banned from Classifieds
#3 (permalink) | |
New project in the works
However any sharp spikes or inclines could be real knock. What is the current state of your tune? How much boost and ignition timing? What is your pick/delay comp and ignition sync at? The knock voltage and knock raw #1 should ramp up with a steady increase in rpm.
-Josh
mildly modified blue 93 rt/tt-SOLD 3780lbs, pump gas 3/s. 127.08mph-92 octane. I still tune cars! new project, T.B.A |
#4 (permalink) |
My car was tuned and is good, it made good power A/F's in the mid 11.3-11.6 timing is at 21 degrees at 7k boost is about 17 psi. I was just playin with the boost and watching knock but im only getting 0.5 max on the knock voltage, what is considered dangerous voltage ?? 1.75v - 2.25v???
#5 (permalink) |
Panda Master
Your knock volts is dependant on your knock cal table. If your knock control is on then the knock volts = knock raw - knock cal table. Have you made a knock cal specific to your engine? Is your knock control turned on?
www.3sx.com
1992 VR4 - Sold - 12.5@110 1991 SL - Sold - 16.5@85 1993 RT/TT - Sold - 11.44@129.3 1992 VR4 - Sold 1994 VR4 - Sold 1993 SL - Retired - 10.19@140 1991 VR4 - Retired - 9.21@159 1993 VR4 - Sold 1992 Base Stealth ATX - DOHC TT |
#7 (permalink) | |
Play that Funky Music
Or 2 volts Knock Raw? And are you saying "Noise", Knock Raw should be under .75 volts? Cause noise would be noise without knock, and .75 volts noise (knock raw during knock cal runs no boost low timing) is a damn quiet engine. Quiter than any 3S I have done a knock cal on. Personally, and I know this leaves some power on the table (where is this damn table everyone leaves power on anyway?) I run the knock cal run, no boost low timing 93 pump. Add 20% even though I have seen 25% is allowed, make that my knock cal map, then when I seen ANY blips of Knock #1 volts I adjust the timing so the runs are dead quiet. Not one spec above the cal table. I know it's leaving power down but I play it safe.
AEM Factory Trained Tuner
T4 AWD 9.21 @ 154.98 T2 FWD 10.19 @ 140.31 T4-159.23 MPH Ran on 6G72 3.1L! T4-995AWHP Uncorrected 6G72 3.0L 91VR4 Red-17Gs w/supporting mods-sold 93SLTT/T2 91VR4 Pearl White-sold 91VR4 Black-sold 92VR4 Sandstone-sold 94VR4 Green-sold 93VR4 Pearl White-currently parting out 91VR4 Black-Currently building "daily Driver" 3SX Performance 3SX Performance Service Email |
