Old 03-08-2008, 04:18 PM   #1 (permalink)
GTO68's Avatar
Drives: 3000GT VR-4
Trader Rating: (8)
GTO68 is an unknown quantity at this point
Exclamation AEM EMS.. CEL as a Knock light
Just wanting to know .. can the AEM be configured to do this .. use your CEL as a knock indicator on the VR4..? Because i find this:
Using AEMPRO press Control-O, find LS10 ALTSWT. Set the value to ON.
Find LS10 SWITCH, set the value to SWITCH #7 ON.
GO to SWITCH #7 ANALOG IN, set the value to KNOCK #1.
Move down the SWITCH #7 ON ABOVE, and set that value to whatever voltage your knock retard table starts pulling timing.
I don't know if this would work on a VR4..
Saphir
Powered By Pampena Machines
GTO68 is offline   Reply With Quote
Old 03-16-2008, 11:08 AM   #2 (permalink)
kmartens's Avatar
Drives: 97 3000gt VR-4
kmartens is an unknown quantity at this point
Default Re: AEM EMS.. CEL as a Knock light
Has anyone tried this yet? I'm interested to know if it works! If my car was running I'd try it on my own but I'm a couple weeks out still.
kmartens is offline   Reply With Quote
Old 03-16-2008, 05:28 PM   #3 (permalink)
220K club
mehlosTT's Avatar
Drives: AWD or nothing.
Trader Rating: (8)
mehlosTT is an unknown quantity at this point
I think_ not sure_ but by the time the AEM ems sees the first Knock Table volt event and triggers the CEL, the time span is too short to light it up long enough for the human brain to register it. Look at the difference in Knock events shown between the internal Logger and when logging on the laptop.
'92 R/T TT 236 K mileage club
AEM EMS,
Twin TD-O5 MHI EVO 16G,
Electronics:
AEM ems, FJO dual WBO2, GaugeTech AEM ems display, custom made EL type main gauge faces,
[/size]
mehlosTT is offline   Reply With Quote
Old 03-17-2008, 06:18 PM   #4 (permalink)
Supporting Vendor
Dj4play's Avatar
Drives: 3000gt x3
Trader Rating: (25)
Dj4play Level 7Dj4play Level 7Dj4play Level 7Dj4play Level 7Dj4play Level 7Dj4play Level 7Dj4play Level 7Dj4play Level 7Dj4play Level 7Dj4play Level 7Dj4play Level 7
I have done this before, that is not what i did to do it. You have to set your not threshhold on how many volts of knock it will take to trigger the cel light. You have to go to configure and options to get to that screen. i can walk some of you guys through it if you want
AEM EMS INVENTOR TRAINED JEDI MASTER CERTIFIED TUNER
www.gtpro.com
Dj4play is online now   Reply With Quote
Old 04-01-2008, 05:59 AM   #5 (permalink)
kmartens's Avatar
Please share with us how you did this. I really want to do this on my AEM EMS.
