Wrong order for Spark plug wires - 3000GT/Stealth International Message Center
Auto Insurance
Wheel & Tire Center
Old 04-30-2009, 09:43 AM   #1 (permalink)
Finally A TT!!!
VillasenorStealth's Avatar
Drives: a banana
VillasenorStealth is an unknown quantity at this point
Feedback Score: 8 reviews
Default Wrong order for Spark plug wires
Yesterday i found out two of my spark plug wires were in the wrong spots. One and four were mixed up. I thought this was going to fix my hesitation problem but it didn't. When i started up the car it sounded fine for a good ten seconds then it went back to crap. Maybe i need to disconnect the battery after the wire change.
Also during idle i tried pulling out the plug wires from the coil pack to see if it affected the idle. All wires when pulled out from the coil pack would effect the idle except the number 1 wire. I'm thinking maybe either the number 1 wire is bad or the coil pack. I also found tons of clear goop in the coil pack.
Any ideas? thanks
VillasenorStealth is offline   Reply With Quote Quick reply to this message
Old 04-30-2009, 10:03 AM   #2 (permalink)
durdyvr4's Avatar
Drives: a rolling nightmare
durdyvr4 is an unknown quantity at this point
Default Re: Wrong order for Spark plug wires
hook up all the wires and park in a dark spot. spray the motor with water and watch closely for cross fires. thats what i did and found lotsa problems. the clear goop is prolly dialectic
durdyvr4 is offline   Reply With Quote Quick reply to this message
Old 04-30-2009, 10:27 AM   #3 (permalink)
I'm a dude.
Toni's Avatar
Drives: 15geed 92 rt tt
Toni Level 2Toni Level 2Toni Level 2Toni Level 2Toni Level 2
Feedback Score: 91 reviews
Depending how long you had those two mixed up you could have fouled out the plugs in those cylinders so if you are under any boost its going to misfire. I'd say check the plugs, or at least #1 since it will probably look the same as #4 and it's easy to get to.
-Antoni
If my links/photos don't work replace penguinhosting.net/~bigmac with primaryboost.com
95 Stealth RT Part Out Uncut 3000GT keys for sale! Various colors!
Toni is offline   Reply With Quote Quick reply to this message
Old 04-30-2009, 10:46 AM   #4 (permalink)
RealMcCoy's Avatar
Drives: 92 RT/TT, 96 Cobra
RealMcCoy Level 3RealMcCoy Level 3RealMcCoy Level 3RealMcCoy Level 3RealMcCoy Level 3RealMcCoy Level 3RealMcCoy Level 3
Feedback Score: 48 reviews
1&4 fire at the same time... It will make no difference. The only thing you did was change the firing polarity.
If #1 has a misfire you need to find the root of that problem...
RealMcCoy is offline   Reply With Quote Quick reply to this message
Old 04-30-2009, 10:49 AM   #5 (permalink)
I'm a dude.
Toni's Avatar
Ohh right, waste spark action...
Old 04-30-2009, 11:10 AM   #6 (permalink)
Drives: 92 Sandstone VR4
bert0mac is an unknown quantity at this point
Feedback Score: 0 reviews
did you check the ecu?
i would check that first since its so easy to pull and look at it. if you pulled the no.1 plug wire and got sparks without affecting idle it sounds to me like the injector driver circuit is bad.
good luck
92 sandstone vr4
....sold...
bert0mac is offline   Reply With Quote Quick reply to this message
Old 04-30-2009, 12:39 PM   #7 (permalink)
Finally A TT!!!
Drives: a banana
good luck
I checked it about 2 weeks ago and there were no signs of it leaking. I'll double check it though. I also have aftermarket resistors that burn up sometimes, maybe one gave out. I might also be off on my timing too, but still haven't got a chance to fix that.
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Real Name(First & Last)
(Required/Hidden)
Mailing Address(Street)
(Required/Hidden)
City
(Required/Hidden)
State
(Required/Hidden)
Zip
(Required/Hidden)
Country
(Required/Hidden)
Log-in
Random Question
