Old 09-04-2008, 04:06 PM   #1 (permalink)
Paid Member
Pearl97SL's Avatar
Drives: 97 3000gt Base
Pearl97SL Level 3Pearl97SL Level 3Pearl97SL Level 3Pearl97SL Level 3
Default window regulator questions
Ok so I have a 97 I was between what ive been told and the research I need a 97-99 regulator my question is what changed between the years? If its just the plug for electrical then screw that i will find a way around it,
So does a 91-96 regulator bolt in and connect to the window? Or did they actually change the design of the window or door too? I just can't come up with 200 bux to buy a new regulator when I see the older ones go for like 25 on ebay all the time.
Pearl97SL is offline   Reply With Quote
Old 09-04-2008, 04:24 PM   #2 (permalink)
Curmudgeon
Steve '93ES's Avatar
Drives: '93 ES, '92 TT
Steve '93ES Level 7Steve '93ES Level 7Steve '93ES Level 7Steve '93ES Level 7Steve '93ES Level 7Steve '93ES Level 7Steve '93ES Level 7Steve '93ES Level 7Steve '93ES Level 7Steve '93ES Level 7Steve '93ES Level 7
Default Re: window regulator questions
I believe the mounting brackets are different. The old style ones won't bolt into a newer car.
BTW - Could you point me to the $25 ones on ebay?
Steve '93ES is offline   Reply With Quote
Old 09-04-2008, 05:20 PM   #3 (permalink)
Paid Member
Pearl97SL's Avatar
Wow they are all expensive now but im positive I have seen them start bidding at $15-$25 for the 91-96 regulators or else I wouldnt have made this thread to begin with. Things change on ebay all the time though.
Old 09-04-2008, 05:53 PM   #4 (permalink)
Curmudgeon
Yeah, I've seen them start that cheap but they almost never sell that cheap.
You might find this helpful though:
http://www.3si.org/forum/f13/window-...nt-fix-147888/
Old 09-04-2008, 08:33 PM   #5 (permalink)
Paid Member
Pearl97SL's Avatar
Awesome thread but unfortunately the cable on my old regulator is what broke not the actuall mounts on it.
Old 09-23-2008, 09:52 PM   #6 (permalink)
3SI #816
pickel is an unknown quantity at this point
If i get a replacement, you have my old one...cable is good, motor is bad.
Will send you a PM either way. May have to send t for repair if i can't find one.
1993 Silver Base Stealth
1972 SS 454 El Camino( wrecked )But will live again in my 1978 C10...YES!
1991 Trans Am
pickel is offline   Reply With Quote
