#1 (permalink) |
James R Hayman
My 91 non-turbo R/T will not start and I cannot figure out why, can anyone steer me into the right direction
I pulled a couple different plugs, they have spark, and seemed to have fuel on them from trying to start it...It started one day, and then nothing the next??? It cranks fine, but does not seem like there is any amount of effort to fire, no sputtering or anything. thanks for your help in advance ![]() |
#2 (permalink) |
Paid Member
Hmm... If you're cranking, getting fuel, and spark, and sometimes starting and sometimes not, then I have to suggest popping open the ECU and checking the caps. These sound like symptoms I had when mine were toast. It's pretty easy to check too.
#4 (permalink) |
Paid Member
Behind the shifter, under the radio. It's held in by 3 12mm (10mm?) bolts and will have 3 harnesses plugged into it. Remove the carpet on both sides of the center console to do it. Once you've done it once you can literally pull the thing in 5 minutes.
Stealth 316 - ECM Removal Since you're a 91, if the caps haven't been replaced yet they need to be. Even if they aren't leaking. |
#8 (permalink) |
Check for spark,fuel and compression(timing)
If ok, go for ECU
intake,modified mass sensor,13G with TD04l housing, 450 injectors,iridium plugs,8,5 mill Magnacor wires,SAFC,hot wire 255lph Walbro fuel pump,stage III 6 pack clutch,gutted cats ,down pipe-full 3"exhaust. Main cat illuminated ,pillar gauges and more.....
