Old 06-05-2008, 10:15 PM   #1 (permalink)
James R Hayman
JamesRHayman's Avatar
Drives: 91 Dodge Stealth R/T
JamesRHayman is an unknown quantity at this point
Default Will not Start :(
My 91 non-turbo R/T will not start and I cannot figure out why, can anyone steer me into the right direction
I pulled a couple different plugs, they have spark, and seemed to have fuel on them from trying to start it...It started one day, and then nothing the next???
It cranks fine, but does not seem like there is any amount of effort to fire, no sputtering or anything.
thanks for your help in advance
JamesRHayman is offline   Reply With Quote
Old 06-05-2008, 10:42 PM   #2 (permalink)
Paid Member
Drives: 91 GTO SR
kylejw is an unknown quantity at this point
Default Re: Will not Start :(
Hmm... If you're cranking, getting fuel, and spark, and sometimes starting and sometimes not, then I have to suggest popping open the ECU and checking the caps. These sound like symptoms I had when mine were toast. It's pretty easy to check too.
kylejw is offline   Reply With Quote
Old 06-05-2008, 11:30 PM   #3 (permalink)
James R Hayman
pardon my ignorance, but this is the easiest way to find out, so where is the ECU, thanks
Old 06-05-2008, 11:55 PM   #4 (permalink)
Paid Member
Drives: 91 GTO SR
Behind the shifter, under the radio. It's held in by 3 12mm (10mm?) bolts and will have 3 harnesses plugged into it. Remove the carpet on both sides of the center console to do it. Once you've done it once you can literally pull the thing in 5 minutes.
Stealth 316 - ECM Removal
Since you're a 91, if the caps haven't been replaced yet they need to be. Even if they aren't leaking.
Old 06-06-2008, 07:59 AM   #5 (permalink)
James R Hayman
if they have started to leak, is it necessary to change the whole unit or would installing new caps still solve the problem?
Old 06-06-2008, 08:31 AM   #6 (permalink)
Here for the tuna.
lawdogg's Avatar
Drives: The Speed Limit
Trader Rating: (61)
Installing new caps would solve the problem assuming your caps are the only thing that went bad.
2002 WJ -- 1994 VR-4 -- Canon Rebel XTi
Originally Posted by Kenneth Ellis View Post
Every one of you are fools, each and every one.
Old 06-06-2008, 10:10 AM   #7 (permalink)
Paid Member
Drives: 91 GTO SR
Though sometimes the fluid that leaks, which is corrosive, can damage other parts of the board. There isn't really a clear answer but if the leakage is small it should be alright
Old 06-06-2008, 10:14 AM   #8 (permalink)
glimerman's Avatar
Drives: 1993 3000GT VR4
glimerman is an unknown quantity at this point
Check for spark,fuel and compression(timing)
If ok, go for ECU
intake,modified mass sensor,13G with TD04l housing, 450 injectors,iridium plugs,8,5 mill Magnacor wires,SAFC,hot wire 255lph Walbro fuel pump,stage III 6 pack clutch,gutted cats ,down pipe-full 3"exhaust. Main cat illuminated ,pillar gauges and more.....
glimerman is offline   Reply With Quote
