#1 (permalink) |
Certified White Boy
For those who dont know, I have a 92 Stealth R/T TT, i pulled my ECU out the other day to see if the caps were leaking because the car wouldn't start. Well it ended up just being a blown fuse, so i put the ECU back, replaced the fuse, and everything was working fine until I tried to roll down the passenger side window. Neither the driver's or passenger side switches work to roll down the passenger side window, but the driver's side window still works fine. Does anyone know what could cause this? Any help would be greatly appreciated. Thanks!!
"Clutch-Eater"
-1992 Dodge Stealth R/T Twin turbo AWD, Dynamic Racing stage II heads, 99 lifters, 6-speed Getrag from 99 vr4, SPEC Stage 4 clutch, TEC 15g's, Greddy blow off valve, Dejon Powerhouse Blow-Thru Intake Pipes, DSM sidemounts, Denso fuel pump, 550cc fuel injectors, Apexi SAFC, HKS VPC, Apexi AVCR, msd ignition dis-4, MSD 8.5mm wires, NGK coppers 1 stage colder, alamo y-pipe, custom exhaust from turbos back, highflow cat, Lowered, Nitto tires. "Knockin' Beater" -1996 Mitsubishi Eclipse GS |
#3 (permalink) |
Forest Gump
did you press the window lock button
![]() Power: DSM 13G/DR650 Combo, EVO 560cc injectors, SAFC I, K&N, Ebay Downpipe, ATR Dual Catback, no cats, DN Y-Pipe, HKS SSQV, HKS EVC 5 at 14.5PSI, Walbro 255 with AN Bulkhead 8.07 @ 85.55 1/8th mile 1.84 60FT Suspension: KYB GR-2 - Tein S-Techs, Crossdrilled/slotted rotors, AWS Delete Drivetrain: RPS Street Max, M.W. 300m O/S, Seattle F&R Poly Mounts Etc: Roller Bearing Short Shifter Smokinvr-4 Corner box, 10" Rockford Fosgate Punch sub, Eclipse Headunit Leatherseats.com Charcoal/Dove Grey Interior, 99 front end/lights/wing/sideskirts/doorcaps Maintenance New VSS, all 60K stuff, new 1st,2nd, 3rd syncro, trans seals, oil pump, rod and main bearings. Mobile 1 10w40, Redline MTL in trans, 85w90 Coastal GL5 in transfer case and rear |
#8 (permalink) |
Certified White Boy
yea, sometimes i hit the window button with my leg accidently and my friends are like.. um.. why is your window rolling down? haha, but yea, thanks for the help, i feel like an idiot. haha.
I like how I am able to pull the ECU, do a fuel pump, change the spark plugs, do lots of complicated stuff, etc, but I can't even figure out how to press a button. lol. |
