Old 05-09-2008, 08:45 AM   #1 (permalink)
Drives: Bone Stock '94 VR-4
slimsunny34 is an unknown quantity at this point
Default Where did you hook up your boost gauge power source?
I'm installing my boost gauge today and I have the vacuum line all set but I was wondering where everyone hooks up the electrical connections for the lights? It's an Autometer gauge mounted in the A pillar.
Thanks
slimsunny34 is offline   Reply With Quote
Old 05-09-2008, 09:55 AM   #2 (permalink)
Default Re: Where did you hook up your boost gauge power source?
anyone?
Old 05-09-2008, 10:05 AM   #3 (permalink)
Ex-Owner
wheelman's Avatar
Trader Rating: (8)
wheelman Level 7wheelman Level 7wheelman Level 7wheelman Level 7wheelman Level 7wheelman Level 7wheelman Level 7wheelman Level 7wheelman Level 7
I tapped into the dimmer switch
Jon, 92 vr-4: sold
wheelman is online now   Reply With Quote
Old 05-09-2008, 10:36 AM   #4 (permalink)
Certified Car Nut
JeffWVR4's Avatar
Drives: Like a Grandpa
JeffWVR4 is an unknown quantity at this point
ditto
Jeff W.
Red '92 VR4 211,000 mile daily driver that run's 11's! Once I convinced the wife I needed 600hp to drive to work every day, the rest was easy
Big 16G Turbos w/adapter plates, DR Stage 3 heads, 92mm Wiseco pistons, PTE 680cc injectors, Pre-cat eliminators w/dump tubes, ARC2 fuel controller, HKS Twin-Power Ignition, HKS EVC IV BC, HKS SSBOV, Alamo I/C's and HardPipe kit, ATR DP, Borla exhaust, NeedsWings Electronic Exhaust Cutout, MSD 8.5mm plug wires, Denso Stage1 fuel pump, Home-made Fuel Pump Hotwire Kit, South Bend FE/SS clutch, Boost Cooler water/meth injection, DynoTech Metal-Matrix aluminum driveshaft, no cats, Eibach lowering springs, Stillen rotors & pads, Goodrich SS brake lines, PSI Tire Pressure Monitor System, AEM Wide-Band O2, Fittipaldi Design wheels, custom 2-tone all-leather Interior.
JeffWVR4 is online now   Reply With Quote
Old 05-09-2008, 02:04 PM   #5 (permalink)
Ŧŵĩň Üĺŧřå \/ïøĺèń©ë
houdini's Avatar
Drives: 92 R/T Twin Turbo
Trader Rating: (29)
houdini Level 1houdini Level 1
yeppers same here, dimmer ftw
I used a double gauge pod held on by 3M heavy duty (i think 15 or 20lb rated) double sided tape. Great stuff and you don't have to drill up your A-pillar. Its held mine securely in place for about 4 years now? My other stealth I removed a double sided tape attached pod and the residue came off pretty well, but touched it up with some GOOF Off and ya never knew it was there.
+rep accordingly lol
=HØÜÐÌÑÍ= 3Si #1042 Si vis pacem, para bellum
90' Laser RS turob Parted out and Sold
92' Stealth RT Twin Turbo - upgraded FOR SALE $8000 OBO
94' Stealth - SOLD! 12/16/06 10+ years of great service, you'll be missed
99' Dodge Durango 5.9L V8 Magnum 4x4
92' Dodge Stealth RT/TT w/ upgrades FOR SALE CLICK HERE
houdini is offline   Reply With Quote
