#1 (permalink) |
curt93T/T
Had my buddies stuff packed and shipped off today. They can't ship anything with chemicals in it so the wax had to stay. He has like 4 bottles of Mequier's liquid wax and was wondering if I should toss it or use it? I had an experience back in 98 with some wax. I bought some Blue Coral resin glaze and put it on my car. Turns out it had been sitting in some warehouse for like 3 years and the resin crystalized and screwed my paint job up. What do you think?
93TT Stealth, mods include: Forge dual piston open loop BOV, full ATR setup, GReddy PRofec E-01 boost controller, MAP-ECU, GT Pro "Y" pipe, Dynamic Racing DR650 + turbo's, UDP, RPS Stage II clutch with aluminum flywheel, ACCEL coil conversion, GReddy 60mm white faced boost and EGT gauges on "A" pillar with peak hold, white faced cluster gauges, Kenne Bell Boost-a-pump, denso fuel pump, Denso 660 injectors, Bob's short throw shifter, LM-1 wide band O2 sensor. 99 front end conversion with Cianci Viper hood and 1970 Boss Mustang hood pins.
#3 (permalink) | |
Smashed Honda for 3S Cash
Toss it....
BAWC OFF |
#4 (permalink) |
2nd Place NG08 DRAGS
out da door
1994 Stealth TT, 1 of 10, Mods- 3.1l 8.5:1 ross pistons, pauter rods, gtpro head gaskets, apr studs, DR stage 3 heads with street grind cams, high rev springs and 3gen lifters ,3SX TD05 kit with EVO III 16G's, PTE 680cc Injectors, SAFC II, Emanage Ultimate, Denzo Fuel Pump, LM-1 Wideband, Intrax Springs, DN Downpipe, FMIC ,Blitz DSBC Boost Controller, K & N Aircharger, 3" split dual exhaust- Straight pipes, Greddy Type-S BOV, Fidanza Flywheel, SS Brakelines,Hotwired fuel pump
#5 (permalink) |
Verified
6 solar years! its on the label read it
92 VR4 Pearl White 67,000 miles {original owner}
Body:Full '99 Body conv-Pitroad M fighter Hood-Cianci widebody-6000K Phillips Xenon HID Interior&Audio System: Blitz SBC i-Color Boost-All 5 Defi BF red gauges-Boston Acoustics: gt-24 & 50 Amps-Z6 Front Components-SL95 Rear Fill-G512-44 Sub-Alpine IVA-W505- alum dash vents-Dynamat Extreme throughout Suspension:18” Fikse Forged Profil FM/5 race satin finishw/ BFG Drag G-Force R1-3SX/SanerPerformance Sway Bars-Teins Flex w/EDFC-3point pitroadm strut bar-Stillen Performance Cross-Drilled Rotors-SS Brake Lines Motor and Drive Train: Balance/BluePrinted 4bolt block 3.5L w/ pauter rods-20 over 9.1 ross pistons-ARP bolts top/bot-DR MaxFlow stage 3 heads w/ High Rev Valve Kit-WebCam Street profile cams-3rd Gen Lifters-Unorthodox Cam Gears w/ Kevlar belt-Unorthodox UnderDrive-6-speed conversion-NorthBend Tech rebuild-Kormex OS-Kormex LSD-Supercar Billet shift forks-Micro polished gears-Silver Powder Coated w/ clear coated Tranny Case-Roller Bearing Short Throw Shifter-New rear end carrier-ACPT CF Drive shaft-RPS CC-3SX Polished Poly Motor Mounts-Modified Cylcone Intake Manifold-Ported lower intake plenum-Precision 1000cc inj-Aeromotive external pump-SX Fuel Filter-Aeromotive fp w/ autometer gauge-8 an SS braided fuel lines pump to engine compart-6 an SS braided fuel lines within engine compart-GTPro billet Fuel Rails-AEM EMS w/all supporting sensors-Mag 10.5 mm wires-HKS DLI-MSD Coils-Custom vertical flow FMIC w/Adel wiggins clamps-Koyo rad w/flex-a-lite fans-Earl's 25r oil cooler w/pull tru-cool fan-Twin Garrett gt3076r's A/R .60 E housings w/HP 2400 deg coat-DR t3/t4 headers w/coatings-tial 28mm wastegates-SS oil & water lines-Billet Alum Spark Plug Cov-Polished Low & up Intake Plenum-shaved valve cov-Polished Thermostat Hous-Chorme Plated oil pan-Stillen SS dp-1off JIC dual Titanium Bullet exhaust-Random Tec High-Flow Cat-Optima red top |
