Old 02-18-2008, 11:30 AM   #1 (permalink)
nduda78's Avatar
Drives: 96 VR4
Trader Rating: (14)
nduda78 Level 7nduda78 Level 7nduda78 Level 7nduda78 Level 7nduda78 Level 7nduda78 Level 7nduda78 Level 7nduda78 Level 7nduda78 Level 7nduda78 Level 7
Default What level of boost can I run?
I know this question has a lot of "It depends" as part of it and if my car is running "properly"...but humor me.
I'm finally getting the RPS Max Street Disc clutch installed. So along with the mods in my signtature what boost levels should I be looking to push to on pump? Granted my wideband and other gauges show good stuff, I was thinking like somewhere between 16-18psi?
Maximum Power: 417.2 @ 5812RPM / 91.1MPH @ 18PSI (Mustang Dyno)
Maximum Torque: 440.7 @ 3615 RPM / 57.3MPH @ 18PSI (Mustang Dyno)
Best Track time: 12.211 @ 119.45 (NE Dragway) but not for long!
www.MyVR4.net
nduda78 is offline   Reply With Quote
Old 02-18-2008, 11:34 AM   #2 (permalink)
One Sinister Motha Sucka!
Sin'sVr4's Avatar
Drives: 91 VR4/94 Wrangler
Trader Rating: (9)
Sin'sVr4 Level 2Sin'sVr4 Level 2Sin'sVr4 Level 2
Default Re: What level of boost can I run?
I'm wondering the same thing
Still Waiting for her to get on the road!! $$$ and counting!!!!
Sin'sVr4 is offline   Reply With Quote
Old 02-18-2008, 11:38 AM   #3 (permalink)
1fstascar's Avatar
Drives: Just a V6.
1fstascar is an unknown quantity at this point
16 is safe with no meth but watch your AFR's. I would look into getting some sort of Methanol injection it helps a hell of a lot.
Kevin
1fstascar is offline   Reply With Quote
Old 02-18-2008, 11:49 AM   #4 (permalink)
nduda78's Avatar
Drives: 96 VR4
Trader Rating: (14)
Kevin
I dont know diddly about Methanol injection....other than one rumor (or maybe its a fact), once you have Methanol injection installed you have to always run it, meaning once your out you cant even run on good ole plain petro. Im new to modding, doing it by the book.
Old 02-18-2008, 11:54 AM   #5 (permalink)
Here for the tuna.
lawdogg's Avatar
Drives: The Speed Limit
Trader Rating: (65)
16-18 as long as you're tuned correctly I believe.
94 VR-4: 11.8 @ 116, 17psi, pump, 13Ts
Old 02-18-2008, 11:58 AM   #6 (permalink)
nduda78's Avatar
Drives: 96 VR4
Trader Rating: (14)
Thanks Lawdogg
With Methanol what would be safe...I'm going to hit up the good ole search and stealth316 to see if i can read more about what this Methanol stuff is...from what I see briefly its good to have (helps control/prevent knock or something)
Old 02-18-2008, 12:04 PM   #7 (permalink)
Fool...No man can kill me
JasonY's Avatar
Drives: TT = Design Flaw....
Trader Rating: (26)
JasonY Level 7JasonY Level 7JasonY Level 7JasonY Level 7JasonY Level 7JasonY Level 7JasonY Level 7JasonY Level 7JasonY Level 7JasonY Level 7JasonY Level 7
There is no definite answer. All what your car allows you to do. Tune it and push it as far as u can and theres your answer.
Jason
"Busting your butt doesn't guarantee success but sitting on your butt will pretty much guarantee failure"
01.5 Dodge 2500 Cummins powered - tow rig 4"/Intake/Edge EZ/35's/built trans
Quality Parts and Service from I.P.S.
and Dynamic Racing
JasonY is online now   Reply With Quote
Old 02-18-2008, 12:11 PM   #8 (permalink)
nduda78's Avatar
Drives: 96 VR4
Trader Rating: (14)
Jason
I totally agree/understand. I guess I was more curious as to what other people with similiar setups on a "decently running" vr4 are doing for PSI. I'm having ESP tune the vr4, so I should get some good numbers. They will push it as far as it will go saftley.
Old 02-18-2008, 01:26 PM   #9 (permalink)
DarkHeroKOTRAJ's Avatar
Drives: 1993 3000GT VR4
DarkHeroKOTRAJ is an unknown quantity at this point
I am bosting between 18.5 and 20.5 most days with my setup.
David P.
Savannah, GA
1993 3000GT VR4 :: Mods :: New Short Block, APR Head Studs, Multi Layer Head Gasket, Port/Polish Heads, 560cc Lancer Injectors, 15G Turbos, 3.5 GM MAF With Translator, Dejon Blow Though Pre Turbo Pipes, 36x14x3 FMIC, 3inch Custom intake, 255 Walbro fuel pump hot wired, Fuellab Fuel Pressure Regulator, Precats removed, Greddy Type-RS BOV, Greddy E-01, AEM Wideband Air/Fuel, Fidanza Aluminum Flywheel, SPEC Stage 3 Plus Clutch, Steel front and mid transfer case upgrade, All sensors replaced, EGR block off, 3SX engine mounts, Ground wire kit, Iridium IX @ .028, and some other stuff
DarkHeroKOTRAJ is offline   Reply With Quote
Old 02-18-2008, 01:31 PM   #10 (permalink)
Here for the tuna.
lawdogg's Avatar
Trader Rating: (65)
I see you got the ferret mod. Good for at least 1 ferret power.
