Old 01-21-2008, 12:48 PM   #1 (permalink)
Sure you don't, Scotty.
93RTTurbo's Avatar
Trader Rating: (18)
93RTTurbo Level 593RTTurbo Level 593RTTurbo Level 593RTTurbo Level 593RTTurbo Level 593RTTurbo Level 5
Default What convertible top frame did R. Straman use for the Stealth?
I need to have a minor repair done to the top on my Straman Stealth convertible. I am positive the frame and top is simply a modified "factory" convertible frame and top from another vehicle.
My question is, does anyone KNOW what make and model the convertible top and frame was, that R. Straman used for the Stealth convertible he produced?
Please don't just say I should "contact him". He's long retired, and I understand he doesn't answer "technical" questions anymore.
Specifically where do I look, to determine what this top really is? I have looked in the "obvious" places. And I have gone through what literature and articles I have on the car, in case it was mentioned. It isn't.
Once I know, I can just order the part for "that" model.
On your knees, wretch!
Originally Posted by Pavone
I don't just want the sex, if I just wanted the sex, I'd offer the sex.
93RTTurbo is offline   Reply With Quote
Old 01-21-2008, 04:27 PM   #2 (permalink)
Drives: 93 SL 92 Vr4
93/3kgtsl is an unknown quantity at this point
Default Re: What convertible top frame did R. Straman use for the Stealth?
Ouch, that's the downside of having a rare option car.
93/3kgtsl is offline   Reply With Quote
Old 01-21-2008, 04:52 PM   #3 (permalink)
Forest Gump
cbehnken's Avatar
Drives: 1992 Stealth TT
Trader Rating: (42)
cbehnken Level 7cbehnken Level 7cbehnken Level 7cbehnken Level 7cbehnken Level 7cbehnken Level 7cbehnken Level 7cbehnken Level 7cbehnken Level 7
it looks a lot like a mustang top. Find a mustang and measure them against each other.
Power: DSM 13G/DR650 Combo, DSM 450 cc bluetops, SAFC I, K&N, Ebay Downpipe, ATR Dual Catback,
no cats, DN Y-Pipe, HKS SSQV, HKS EVC 5 at 14.5PSI, Walbro 255 with AN Bulkhead 8.07 @ 85.55 1/8th mile 1.84 60FT
Suspension: KYB GR-2 - Tein S-Techs, Crossdrilled/slotted rotors, AWS Delete
Drivetrain: RPS Street Max, M.W. 300m O/S, Seattle F&R Poly Mounts
Etc: Roller Bearing Short Shifter Smokinvr-4 Corner box, 10" Rockford Fosgate Punch sub, Eclipse Headunit
Leatherseats.com Charcoal/Dove Grey Interior, 99 front end/lights/wing/sideskirts/doorcaps
Maintenance New VSS, all 60K stuff, new 1st,2nd, 3rd syncro, trans seals, oil pump, rod and main bearings.
Mobile 1 10w40, Redline MTL in trans, 85w90 Coastal GL5 in transfer case and rear
Looking for scanmaster...
cbehnken is offline   Reply With Quote
Old 01-21-2008, 04:58 PM   #4 (permalink)
Z32 FTMFL
South_FL_RT's Avatar
Drives: Z32 TT POS
Trader Rating: (18)
South_FL_RT Level 7South_FL_RT Level 7South_FL_RT Level 7South_FL_RT Level 7South_FL_RT Level 7South_FL_RT Level 7South_FL_RT Level 7South_FL_RT Level 7South_FL_RT Level 7South_FL_RT Level 7South_FL_RT Level 7
contact boca rat he may know he has the same thing
94 Stealth R/T Luxury 1 of 148 Gun Metal STOLEN 8-24-2007
South_FL_RT is offline   Reply With Quote
Old 01-21-2008, 08:55 PM   #5 (permalink)
165 mph and counting...
UTRacerX9's Avatar
Drives: like Jason Bourne
Trader Rating: (7)
UTRacerX9 Level 7UTRacerX9 Level 7UTRacerX9 Level 7UTRacerX9 Level 7UTRacerX9 Level 7UTRacerX9 Level 7UTRacerX9 Level 7UTRacerX9 Level 7UTRacerX9 Level 7UTRacerX9 Level 7UTRacerX9 Level 7
Liu Kang also has one, he might know.
As for looks, I really think Straman might have used the top from a 1991-1995 Ferrari 348 Spider, and just modified the rear window part.
Take a look.
http://www.autovermietung-24.de/Ferr...ider_seite.jpg
Or possibly the old Vette.
http://www.carsatcarlisle.com/photos...ette_large.jpg
1991 Stealth Twin Turbo
Mods: 13T turbos, Stillen downpipe, HKS Super Drager catback, Fidanza adjustable cam gears, UR flywheel, DXD-F, DSM sidemount intercoolers, front mount oil cooler, LS6 MAFT, DN Y-pipe, gutted precats, ported exhaust manifolds, Apexi AVC-R set to 1.0 kg/cm, Greddy BOV type S, Supra pump, and an Unorthodox racing pulley.
UTRacerX9 is offline   Reply With Quote
Old 01-22-2008, 12:34 PM   #6 (permalink)
93RTTurbo's Avatar
Trader Rating: (18)
I'd say the 'Vette is a good guess, although it needs to be confirmed. The Ferrari one is probably not it, because the "roof" part is shorter than this one. I will have to post a photo of it with the top up, to get a better idea of what it might be.
I'm thinking, perhaps if I posted photos of the hardware, that might be familiar to someone. The lever/handle to un-clip it from the front visors is definitely a factory item, but for what car? If I put a picture up of it, perhaps someone will recognize it as maybe one from a LeBaron or something, or maybe someone will have seen it before in a car they've owned.
At least if I know what make it is, that will narrow down what it is. I do know it has to be something that was available prior to 1991.
Will post pictures shortly.
Old 05-11-2008, 10:37 PM   #7 (permalink)
NO Barack HUSSEIN Osama!!
blusilvr's Avatar
Drives: PiMpMobile
Trader Rating: (67)
blusilvr Level 7blusilvr Level 7blusilvr Level 7blusilvr Level 7blusilvr Level 7blusilvr Level 7blusilvr Level 7blusilvr Level 7blusilvr Level 7blusilvr Level 7
bump for curiosity
Lamborghini Marketing VP describing Countach- "on the down side, you can't take packages, there are only two seats so no kids, only a beautiful woman. The white one, she is like a virgin. The red one is like a mature woman, the black one like an intriguing woman."
blusilvr is offline   Reply With Quote
Old 05-11-2008, 11:31 PM   #8 (permalink)
AIM-Allhalo1
pokey's Avatar
Drives: 92 3000GT VR-4
Trader Rating: (6)
pokey Level 4pokey Level 4pokey Level 4pokey Level 4pokey Level 4
Believe it or not i have the motor trend or whatever publication that that car was featured in. Should i go dig for it? Would it help??
"That oil under the car is my motor sweating from making all that horsepower".
pokey is offline   Reply With Quote
