What causes the belt to jump a tooth? - 3000GT/Stealth International Message Center
Auto Insurance
Wheel & Tire Center
Old 10-27-2008, 10:07 PM   #1 (permalink)
Minty
Alt0id's Avatar
Drives: '94 3000GT SL
Alt0id Level 1Alt0id Level 1
Feedback Score: 19 reviews
Default What causes the belt to jump a tooth?
Hey guys
I have been reading a lot more about people having problems with their timing belts as of late. I have noticed a lot of people saying their belt "jumped a tooth." I know what this means, however I am not sure what would cause this.
I assuming if the belt wasn't tensioned properly it would have the ability to do such a thing, but can it happen if the belt is at proper tension?
Is this something that maybe the tensioner just didnt do its job because it is getting old?
How can I prevent this from happening after I do my 120k maintenance this upcoming winter?
The reason I am asking is I am becoming increasingly paranoid about many things about my car. I have recently been doing a lot of maintenance (weekly couple hundred dollar purchases) and trying to just make the car like new again. I am just scared to death of something happening that is major, timing jump, spun bearing, etc.
Thanks in advance!
-Steven
1994 Mitsubishi 3000GT SL Twin Turbo
10:1 - 13t turbos - MR downpipe - KN FIPK - 360cc injectors - ATX to MTX
BUY MY CAR - MOVING OUT JAN 7th
http://www.3si.org/forum/f10/1994-30...t-13ts-526760/
Alt0id is offline   Reply With Quote Quick reply to this message
Old 10-27-2008, 10:13 PM   #2 (permalink)
Maelstrom's Avatar
Drives: 1999 3000GT VR-4
Maelstrom is an unknown quantity at this point
Feedback Score: 10 reviews
Default Re: What causes the belt to jump a tooth?
I would attribute it, like you said, to an improperly tensioned belt or a failing tensioner that's just getting weak. It could also be someone didn't tighten down the tensioner bolt enough and it worked it's way loose a bit or something of that sort, aged belt, stretched belt, etc.
I'm in the same boat as you pretty much. I've been spending quite a bit a week trying to get my car back up to tip top shape and I'd really hate it if mine jumped a tooth or two or three and messed up my valves especially since I just had a motor put in it. I'm thinking I'm good for awhile, so most of what I'm doing now are just little minor things like weather stripping or missing plastic pieces, renewing black parts on the outside of the car (like the black around the bottom of the back of the back glass)
Maelstrom is offline   Reply With Quote Quick reply to this message
Old 10-27-2008, 11:41 PM   #3 (permalink)
Wingless Since Spring 08
eblank8's Avatar
Drives: BMW
eblank8 Level 1eblank8 Level 1
Feedback Score: 35 reviews
Mine jumped when a piece of the rubber gasket under the timing belt cover broke while putting the cover on. Over time it becomes brittle and will break easily. This small rubber piece found its way inbetween the belt and the gear. You can guess what happened next. Good thing was that nothing seriously bad happened. No bent valves or anything. Reset the timing, check compression, and she was on her way.
eblank8 is offline   Reply With Quote Quick reply to this message
Old 10-27-2008, 11:44 PM   #4 (permalink)
Hater
misegades's Avatar
Drives: spaceship
misegades is an unknown quantity at this point
Feedback Score: 0 reviews
My honest opinion? Poor timing belt tensioner design.
However, if you're doing your timing, make sure everything is torqued properly. I think it's like 7.2 ft/lbs on the belt, then 42 ft/lbs on the tensioner pulley bolt. That's quoted from memory, so could be off a bit.
misegades is offline   Reply With Quote Quick reply to this message
Old 10-28-2008, 12:16 AM   #5 (permalink)
I've been here way too long
DCIV's Avatar
Drives: 93vr4 & 92vr4
DCIV Level 2DCIV Level 2DCIV Level 2DCIV Level 2DCIV Level 2
Feedback Score: 15 reviews
if you miss a gear or over rev your car you will jump the timing. The stock tensioner just cant keep up and your screwed. Another thing is just replacing that tensioner, and bolts, alot of ppl dont do it untill 120k but it wouldnt hurt to do it at 60k.
Coop
DCIV is offline   Reply With Quote Quick reply to this message
Old 10-28-2008, 11:18 AM   #6 (permalink)
Black_Sunshine's Avatar
Drives: 2 wheels
Black_Sunshine Level 2Black_Sunshine Level 2Black_Sunshine Level 2Black_Sunshine Level 2
Feedback Score: 117 reviews
i've always replaced the hydraulic tensioner on 60ks. spend a little over 100 or a couple grand? i'll spend the 200 for the peace of mind. and i've always used oem tensioners. some parts can be aftermarket, but i wouldn't cheap out on something that vital to the engine.
Black_Sunshine is offline   Reply With Quote Quick reply to this message
Old 10-28-2008, 01:52 PM   #7 (permalink)
Pampena Motorsports
Drives: 95 VR4
WidowMaker Level 2WidowMaker Level 2WidowMaker Level 2WidowMaker Level 2WidowMaker Level 2WidowMaker Level 2
Feedback Score: 16 reviews
I have found that many times the timing will jump when you use a light-weight flywheel and/or light-weight crank pulley.
Of course failing parts and improper installs will do it as well.
Best bet is to make sure you use new OEM parts and use a reliable shop that knows what they're doing.
-Steve
USE PROMO CODE: MISHI15 for 15% off all Mishimoto parts
www.PampenaMotorsports.com
Custom Pampena Motorsports AWS Delete kits on sale at $124.99
Custom Pampena Motorsports Bellhousing braces on sale at $124.99
Full Bolt-In FMIC kit on sale at $580 shipped
Full Bolt-In Dual Core FMIC for $650 Shipped!
We build and tune really sick cars!!!
Contact us for any of your performance and repair related needs
Custom Parts and fabrication/In-house AWD Dyno/Tig Welding/Turbos/FMIC's/etc...
Dealer for Mitsu, Precision Turbo, Delphi, Fidanza, BC Racing, AEM, etc...
(631) 676-2448 SHOP
(516) 456-7792 PARTS/SALES please call only between 9am-5pm mon-fri
Steve-Pampena Motorsports
WidowMaker is offline   Reply With Quote Quick reply to this message
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Real Name(First & Last)
(Required/Hidden)
Mailing Address(Street)
(Required/Hidden)
City
(Required/Hidden)
State
(Required/Hidden)
Zip
(Required/Hidden)
Country
(Required/Hidden)
Date of Birth
Month Day Year
Privacy
Log-in
Random Question
