Old 07-03-2009, 12:23 AM   #1 (permalink)
soccermania688's Avatar
Drives: Mitsubishis
Trader Rating: (7)
soccermania688 is an unknown quantity at this point
Default Vr4 Misfiring!!!! No Power!!
i just finished up my vr4. stock except for air filter. i bought it knowing it had a bad motor. i took the motor out of my sl and put the turbos on it. so its a 10:1 tt. ecu's rebuilt.
its won't idle no matter how much you move the biss screw. also when floored it takes like 4 secs just to get to 3k rpms. i haven't even drove it yet since its basically undrivable right now. I'm getting the CEL codes
#13- Intake air temp sensor
#14- throttle position sensor
#41- Injector
things you should know-
>using na throttle body
>motor ran great in other car
>did 93 style cas conversion
>maf and tps from sl
>fuel pump relay jumped out like on stealth 316
> vac reduction done
>waste gate psi
could it be something as obvious as a bad injector? i don't know the history on them but the car ran b4 it lost a rod. tried knock sensor off, diff knock sensor, unplug maf. all did nothing. what should i do next?
posted in turbo section but got no response.
1992 3000GT VR4 10:1 comp, Fidanza FW, RPS PP & Stock disc, Air Filter, Greddy type S BOV, gutted precats, AWS Delete, Vac Reduc, MBC-not set yet, Autometer BG.
Coming Soon: Maximal Single Shot(hopefully), MBC, Downpipe, FMIC.
1993 3000GT SL(PARTING OUT-PM FOR PARTS!!!)
-Junking this car soon so if you want really CHEAP PARTS PM me now!!!!!
'93 Sl ECU rebuilt 100$ shipped
soccermania688 is offline   Reply With Quote
Old 07-03-2009, 12:41 AM   #2 (permalink)
Damage Control
Stealthee's Avatar
Drives: 1994 Stealth
Trader Rating: (134)
Stealthee Level 2Stealthee Level 2Stealthee Level 2Stealthee Level 2Stealthee Level 2Stealthee Level 2
Default Re: Vr4 Misfiring!!!! No Power!!
SOunds like the MAF is unplugged. Using the NA TB wont have an effect as its the same size as the TT one. Did you move the TPS and if so did you use feeler gauges to get it back into spec?
Old 07-03-2009, 01:49 AM   #3 (permalink)
Drives: Mitsubishis
Trader Rating: (7)
didn't move tps. maf plugged in or unplugged has no effect at all on the way it runs. maf was good in my sl
Old 07-03-2009, 01:58 AM   #4 (permalink)
Damage Control
Stealthee's Avatar
Checked ECU caps?
Old 07-03-2009, 02:13 AM   #5 (permalink)
Drives: Mitsubishis
Trader Rating: (7)
ecu was rebuilt
Old 07-03-2009, 02:14 AM   #6 (permalink)
Damage Control
Stealthee's Avatar
Maybe check wiring to MAS.
Old 07-03-2009, 02:16 AM   #7 (permalink)
Drives: Mitsubishis
Trader Rating: (7)
where do the maf wires eventually lead back to? ecu? i can check for continuity from maf to its destination
Old 07-03-2009, 02:18 AM   #8 (permalink)
Damage Control
Stealthee's Avatar
That I dont know for sure. I just know a friend of mine was having issues and found out his MAS harness was effed up.
Old 07-03-2009, 02:19 AM   #9 (permalink)
Drives: Mitsubishis
Trader Rating: (7)
alright i'll look into that tomr'w. does the injector code mean anything or can a messed up maf give codes like that?
Old 07-03-2009, 02:23 AM   #10 (permalink)
Damage Control
Stealthee's Avatar
It may. I just know a MAS will definitely give you an IAT fault code.
