Old 05-24-2008, 04:37 PM   #1 (permalink)
Fijivr4 is an unknown quantity at this point
Default Very Unique ECS Problem! Test your skills.
I have a 92 VR4 with 95K miles on it.
My tour/sport light is stuck on Solid. Unlike every other post I have read regarding this issue, they do not blink, alternate or go off. They stay on solid from the time I start the car until I take the key out of the ignition.
About a year ago the ECS lights were blinking tour and sport. I replaced the two front strut harnesses which fixed the problem.
Now that the lights are solid, I checked the front and rear strut covers to make sure the wires were ok. They all looked to be in excellent condition.
So of course, I thought it was the ECS computer. I took it out and opened it. Leaky caps all over the place. Sent it out Foreign Computer to have it repaired. Got it back yesterday, reconnected it and nothing has changed.
So in sum:
1) I checked all strut covers for broken strut cover wires
2) repaired the ECS computer
and
3) disconnected the battery for like an hour in an attempt to "reset" the ECU.
4) did the Strut "push" test on each strut, they seem fine.
NOTHING has worked. So what else could it be? My struts seem fine, nice and solid.
Keep in mind the lights are NOT blinking, they are on solid. Anyone have any ideas?
1992 VR4
Apexi Boost Controller
Fidenza Flywheel
RPS Stage III Clutch
K&N FIPK
Intrax Springs 1.75 " Drop
HKS SSQ BOV (open loop)
New 3G lifters
17" Fittipaldi Avus + Rims
17" Michelin Pilot XGT Z4
Fijivr4 is offline   Reply With Quote
Old 05-24-2008, 06:29 PM   #2 (permalink)
In Training
etecnifibre's Avatar
Drives: 99 3/4 Ton Silverado
Trader Rating: (64)
etecnifibre Level 7etecnifibre Level 7etecnifibre Level 7etecnifibre Level 7etecnifibre Level 7etecnifibre Level 7etecnifibre Level 7etecnifibre Level 7etecnifibre Level 7etecnifibre Level 7etecnifibre Level 7
Default Re: Very Unique ECS Problem! Test your skills.
Sorry if this sounds terribly simple, but what about the switch?
Also, I'd swap the computer with known good one to make 100% sure that the computer you got back is good.
etecnifibre is offline   Reply With Quote
Old 05-24-2008, 07:03 PM   #3 (permalink)
BlackStealth's Avatar
Drives: 93 RT/TT
Trader Rating: (162)
BlackStealth Level 7BlackStealth Level 7BlackStealth Level 7BlackStealth Level 7BlackStealth Level 7BlackStealth Level 7BlackStealth Level 7
My bet is that the ECS computer is still broken.
BlackStealth is offline   Reply With Quote
Old 05-24-2008, 07:12 PM   #4 (permalink)
3KGT2NV's Avatar
Drives: 1994 3kgt vr-4
Trader Rating: (16)
3KGT2NV Level 73KGT2NV Level 73KGT2NV Level 73KGT2NV Level 73KGT2NV Level 73KGT2NV Level 73KGT2NV Level 73KGT2NV Level 73KGT2NV Level 73KGT2NV Level 73KGT2NV Level 7
+1
try a known working unit and see if it does the same thing. Have you tried pulling a code to see what the error is?
3KGT2NV is online now   Reply With Quote
Old 05-24-2008, 07:15 PM   #5 (permalink)
Fijiblue92vr4's Avatar
Drives: the bat mobile
Fijiblue92vr4 is an unknown quantity at this point
if it is the comp. i can sell u mine works fine....but i got the tein flex coilovers..no need for the comp.. flashes all the time no matter what
92 VR4
98 Danger Ranger DD
Fijiblue92vr4 is offline   Reply With Quote
Old 05-24-2008, 07:18 PM   #6 (permalink)
3KGT2NV's Avatar
Trader Rating: (16)
same here with the jic's I currently have mine unplugged to stop the christamas tree dash
Old 05-25-2008, 10:02 AM   #7 (permalink)
I guess I could check the switch next. Pull it out and try to manually trigger sport and tour mode. That is not a bad idea.
I have not tried to pull an error code yet though.
I wonder if something else could be wrong with the ESC unit perhaps. Its possible that when the caps leaked they damaged a resistor which was never replaced by Foreign Auto.
I think getting my hands on another working ECS would be ideal but I have no idea how I can get that done. Maybe I can see if Foreign Auto would send me aknown working one to test out?
Old 05-25-2008, 10:12 AM   #8 (permalink)
ESR/TWS6 Stealth owner
1991StealthR/T's Avatar
Drives: 91' Stealth eSR/T
1991StealthR/T Level 11991StealthR/T Level 1
Mine does the same thing and I replaced the caps in the ECS comp. and checked the switch but II have a 91 N/A R/T And I knew the front struts were shot so I replaced them with one from an es but the light is still solid.
1991 Dodge Stealth R/T - Passion Red - Spun bearing soon to be TTFWD
1985.5 Mitsubishi Starion - California Red - Blown head gasket and sat for 10+ years. - soon to be either running or sitting until the Stealth is done.
1991StealthR/T is offline   Reply With Quote
Old 05-25-2008, 11:07 AM   #9 (permalink)
Damage Control
Stealthee's Avatar
Drives: 1994 Stealth
Trader Rating: (78)
if caps leaked all over the place I am going to agree and say the ECS computer is shot.
Old 05-25-2008, 11:14 AM   #10 (permalink)
3KGT2NV's Avatar
Trader Rating: (16)
where in LI are you I would be willing to meet you some where and let you try my ecs comp. I live like 1.5 hours north of the city but I can make a reason to go to the city for a day. (katz's deli)
