LinkBack (1) Thread Tools
Old 07-25-2009, 04:56 AM   #81 (permalink)
¡ıɐɥ 'o
PezCore's Avatar
Drives: into the D dimension
Trader Rating: (31)
PezCore is an unknown quantity at this point
Default Re: The vacuum hose reduction: walkthrough and pics
FINALLY did this on my 97VR4 and the CEL came on almost instantly, oops!
I knew it was coming though; no biggie since I don't have to pass emissions testing for another 2 years
Maddog Performance Engineering | Put Some South in Your Mouth | Competitive Rates
92 SL | 99 SL | 97 VR4 | my custom gauges | taco bell crew | parking lot crew | PBR sucks crew
SOUTHEAST DRAG DAY 2009 TAKE 3! DOOO EEEET!
PezCore is offline   Reply With Quote
Old 07-25-2009, 04:22 PM   #82 (permalink)
Deman420's Avatar
Drives: 95 Stealth rttt
Deman420 is an unknown quantity at this point
95 stealth rt tt. did vac reduction n added mbc. Left egr on but all disconnected waitting on plates. Unable to boost above 12 psi. 8psi in 1st 2nd n 3rd. 3rd over 60m/hr will hit 12psi n in 4th 12psi. No leaks after test. Anyone know why I cant up the boost to 14.5psi. The boost controller is cranked all the way n no change.
Deman420 is offline   Reply With Quote
Old 08-02-2009, 12:19 AM   #83 (permalink)
Geordon's Avatar
Drives: 92 Stealth R/T TT
Geordon is an unknown quantity at this point
Did anyone buy 3.5mm hose instead of 4mm? It seems all the Universal kits include 4/6/8mm thin-wall stuff, instead of the thicker hose sold by 3SX or boostcontrollers. Since the non-kits are sold by the foot, can anyone provide a better estimate of lengths of each to buy? I would hate to buy 10' of each at $2+ per foot, if I can avoid it. Thanks.
'92 Stealth R/T TT Black
Geordon is offline   Reply With Quote
Old 08-03-2009, 03:34 PM   #84 (permalink)
Paid Member
jba3's Avatar
Drives: until bearings spin
Trader Rating: (21)
jba3 Level 1jba3 Level 1
The length is going to vary a bit depending on how long you make the lines, but I don't think I used maybe 6" of the 8mm (pass side of valve cover to tee only iirc), and almost all of the 4mm or 6mm (4mm I *think*). At $30 for the kit, it will probably be roughly the same cost as going by the foot, but with the kit, you'd have some leftovers too.
Old 08-03-2009, 10:35 PM   #85 (permalink)
stupidvr4's Avatar
Drives: 92 vr4
Trader Rating: (6)
stupidvr4 is an unknown quantity at this point
So lets say you're keeping the factory BCS for now is it still possible this way? Because i hooked everything up and did one 2nd gear pull and got knock like crazy.
stupidvr4 is offline   Reply With Quote
LinkBacks (?)
LinkBack to this Thread: http://www.3si.org/forum/f1/vacuum-hose-reduction-walkthrough-pics-359412/
Posted By For Type Date
FAQ..read Before Asking! - Page 2 - Automotive Forums .com Car Chat This thread Refback 04-13-2008 04:42 AM
