#31 (permalink) | |
Dec. 2001
![]() 1991 Dodge Stealth R/T Twin Turbo MODS|ATR Downpipe|HKS Super Dragger|DN Pre Cat Elims|AEM WB02 Gauge|Ek2mfg Fuel Rail Loop|Polished Fuel Rail|Wrinkle Black Intake Mani|Mirror Red Valve Cover|Injector Harness Cover|Ohio Bob Short Throw Shifter|DN Intake Pipes|Palm Datalogger|TD04L 15G Turbos|EGR Block Off Plates|Vac Reduction|Evap Delete|Cruise Control Delete|A/C Delete|Battery Relocated|E2kmfg Poly Mounts|PTE 680 Injectors|Hotwired Walbro 255lph FP|Snow Performance Water/Meth Injection|Tein Coilovers|18x9 Saleen Replicas| 265/35/18 Sumitomo HTR II|New Shortblock|Rebuilt Heads|IPS FMIC|RPS Max Street|AEM EMS|AEM IAT|AEM 3.5 BAR| Next Up: Tuning AEM 1994 Dodge Stealth R/T Twin Turbo Under ConstructionTD05's & Much More |
#32 (permalink) | |
mc.noob
I can make some plates in a matter of minutes. |
#34 (permalink) |
mc.noob
thanks!
btw that pre-cat is working out nicely. When I installed it the first time I did not realize that you left that nut on the bottom on. I installed everything and was getting weird o2 readings. I finally realized it was pushing the pre-cat off the turbo so it wasn't sealed perfectly....im so dumb ![]() |
#35 (permalink) |
crash & rebuild
I used the EGR line flanges as blockoffs but after I welded the holes shut the exhaust side plate wasn't straight any more so I have a leak there. I'll shut it temporarily with exhaust sealant and buy a blockoff kit later.
Everything else seems to work fine. |
#36 (permalink) |
mc.noob
ok, I am doing the wastegates right now and have one simple question. Do I need to use clamps on the wastegates? The only clamps I ahve which are small enough are the stockers. However they do not have enough tension to push on the silicone line. Also, I lost my last t that fits the wastegate lines. Is it ok to use the H thing that was on the rear wastegate until I can get another T?
#37 (permalink) |
I'm not a big fan of having a hose sticking out of the front of my car, or cutting the evap line at the tank. Isn't there another way to do this? I think I recall reading that the M-Spec kits came with a hobbs switch or something, so the evap fumes would be fed into the intake during cruise, but not while the car is off and not while the car is idling? Can anybody supply any information on how to do this?
'91 VR4 - Rebuild in progress: Mods TBA.
#38 (permalink) |
Davey99VR4
hey I have searched the forums and couldn't find my answers,I'm still learning. i have a 99 vr4, need to do a vacuum reduction /egr delete,, Can I follow these instrucions with my car , or will I run into running issues due to the ecu??? Was wondering if anybody with a 98,99 has performed a vacuum reduction( which i'm 100 percent sure there is) Just wanted some input... I have a vacuum leak somewhere , becasue I can't control boost.. I have narrowed it down to a couple things.. I either think it has something to do with my egr, or its a vacuum leak that I haven't found. I have checked all my hoses for leaks and made sure all my connections were on. About a week ago I brought it into lse and it was throwing egr code, and I hadn't done anything to it, except remove it and attach it back. Can that effect boost...
what happens is my boost just sky rockets to somewhere above 1.5 bars and my warning turns it back down. I basically can not control boost.. need some input. sorry if this os confusing my dam. roomies wont stop talking,, thanks dave
99VR4 is sold
05 Pontiac LS2 GTO 360WHP360WTQ Tune coming... |
#39 (permalink) | ||
Damage Control
This one doesnt have any notes regarding the 99's only up to 95. I would assume the 99's would probably suffer from a CEL for the evap or EGR. I doubt the EGR had anything to do with your boost spikes. The big problem is the stock vac lines. Instead of equal length runs to the wastegates and then a direct T to the boost controller you have different lengths and then a cluster of hoses. I wouldnt recommend a full reduction without confirmation from another 99 owner but I would look at replacing the lines to the wastegates and then T them in the center and run to your boost controller. For mine I just ran a line between the two, took it out and folded it, cut in two, added the T and then ran a line from the T to the boost controller. This helps ensure that both wastegates get the same amount of pressure or vac. The spikes are typically caused by the uneven runs of line letting one turbo spool a little longer than the other.
1993 3000GT VR4: Upgraded Clutch & Pressure Plate || Greddy RS BOV (closed loop) || BLITZ Turbo Timer|| Open Element Filter || Gutted Front and Rear Pre-Cats || APEXI AVC-R @ 1bar ||
#40 (permalink) |
It's all stock.
I've seen this happen several times now when someone installs an aftermarket boost controller and leaves the stock boost control system in place. Try unplugging your stock boost control solenoid and see if your aftermarket boost controller works a little better.
Handing out reality checks to "500HP Hondas" for 8 years and counting.
'92 Sandstone Grey 3000GT VR-4. K&N filter, Spec 5 clutch, NGK plugs/wires, Custom EBC, Greddy E-manage Ultimate, built 6G74 engine (in progress), Turbonetics ceramic ball-bearing T-70, custom intake/exhaust/intercooler piping (still plumbing those), 24"x12" FMIC, Brembo rotors, Stillen pads, E-bay Ground kit, 2nd gen shifter, HKS SSQV, Denso 660's, twin Walbro fuel pumps, GTO center garnish, eK2 EGR block-off plates, Prosport gauges: [oil press, fuel press, manifold press, oil temp, water temp, volts], Toni's interior LED conversion (still installing), forgot the rest. '91 Firestorm Red 3000GT VR-4. K&N filter, eK2 poly engine mounts, Seattle Short Shifter, custom MBC, Spec 3+ clutch, Forged crankshaft, Tein S-Tech springs (front only), DNP Y-pipe, TD04H-13T's (with 13T wastegates), amber taillights, gutted pre-kitties, eK2 EGR block-off plates, Prosport gauges: [oil press, manifold press, fuel press, water temp], Megan Racing downpipe, Borla exhaust, NGK plugs, MSD wires, Greddy type-S BOV, Greddy E-manage Ultimate, RC 550 injectors, Denso "Supra" fuel pump, MSD DIS-4, Brembo rotors, Stillen pads, forgot the rest. '90 Fiji Blue 300ZX TT. Stillen front bumper/nose-panel/wing/control arms/sway bars, Greddy intake/exhaust/clutch/fuel injectors, Super Autobachs strut bars, Brembo brakes, Energy Suspension bushings, Tokico shocks, JWT ECU chip, Bomex rear bumper, Nismo gound kit, NGK plugs, IPS short shifter, Custom interior, forgot the rest. '92 Black MR2. Wife's car. K&N filter on a custom cold-air intake, some interior stuff. |
LinkBacks (?)
LinkBack to this Thread: http://www.3si.org/forum/f1/vacuum-hose-reduction-walkthrough-pics-359412/
| Posted By | For | Type | Date | |
| FAQ..read Before Asking! - Page 2 - Automotive Forums .com Car Chat | This thread | Refback | 04-13-2008 01:42 AM | |
| Thread Tools | |
