LinkBack (1) Thread Tools
Old 02-15-2007, 02:08 PM   #11 (permalink)
3Sfever's Avatar
Drives: '91 Stealth TT
3Sfever is an unknown quantity at this point
Default Re: The vacuum hose reduction: walkthrough and pics
Just wondering (I have not read thru this in detail or thought about it carefully) . . . does this reduction make it easier to lift the intake plenum, like when changing sparkplugs etc. . . . or is most of the restriction in movement from something else anyway (like the coolant lines to the throttle body).
-Ron
'91 Stealth TT
purchased Aug 2004
3Sfever is offline   Reply With Quote
Old 02-15-2007, 02:26 PM   #12 (permalink)
Drunk as a lord
Forest Gump's Avatar
Drives: 1992 Stealth TT
Trader Rating: (51)
Forest Gump Level 1Forest Gump Level 1Forest Gump Level 1
if you do the egr delete it makes a huge difference. Next to that I find the wiring thats bolted on the passenger side to be the biggest obstacle. Unbolt that and you can push the plenum to the side enough to change plugs without completely removing it.
Power:13Ts, 550s, SAFC, K&N, Downpipe, ATR Catback, DevilsOwn meth, UDP, SSQV, EVC5, Walbro, IK24s
Best 1/4 12.62 @ 111.9 2.0 60 FT Best 1/8th 8.00 @ 87.24 1.80 60FT
Suspension: Konig Villians, Pilot A/S, Tein S-Techs, Hawk HPS Pads, 2G front brakes AWS Delete
Drivetrain: ACT HDMM, 300m O/S, PST 2 piece Al/Steel Driveshaft, F&R Poly Mounts, EK2 ExoCage
Etc: Leatherseats.com Charcoal/Grey Interior, 99 front end/lights/wing/sideskirts/doorcaps, Scanmaster3, AEM UEGO
Forest Gump is offline   Reply With Quote
Old 02-15-2007, 05:23 PM   #13 (permalink)
Envious for a VR-4
NOMIEZVR-4's Avatar
NOMIEZVR-4 is an unknown quantity at this point
Can we get before after pictures?
Great write-up. subscribed.
Nomie
Ya the car this next time is going to have new parts, and not just junk I had laying around. So everybody better watch out, I went 9.73@151 with a pile of junk, imagine what it's going to do now.
The new toy.. 2005 ZX-10R
NOMIEZVR-4 is offline   Reply With Quote
Old 02-19-2007, 09:28 PM   #14 (permalink)
Asian Heat
Drives: 1992 3000GT vr4
spyder44 is an unknown quantity at this point
Mitsubishi Re: The vacuum hose reduction: walkthrough and pics
Sorry for the stupid question but about how many feet would you need of each 4mm(or 3.5mm) and the 6mm line to do this mod?
-Dan
RIP
spyder44 is offline   Reply With Quote
Old 02-19-2007, 09:54 PM   #15 (permalink)
5150
VR4's-Kick-Ass's Avatar
Drives: 91 RT-TT
VR4's-Kick-Ass is an unknown quantity at this point
Why do you keep the black purge valve?
VR4's-Kick-Ass is offline   Reply With Quote
Old 02-19-2007, 10:15 PM   #16 (permalink)
moffman93''s Avatar
Drives: 91 vr-4
Trader Rating: (6)
moffman93' is an unknown quantity at this point
wondering same question. Ive been waiting for this writeup. You did a great job struggly. Does this setup void emissions. EGR blockoff im assuming? Now i can finally clean up all that extra shit in my engine bay.
1993 3000gt base - SOLD
1991 3000gt Vr-4(white) - purchased 12-23, given back 4 days later lol.
1991 3000gt vr-4(red) - purchased 12-28
Performance mods : K&N air filter, fully built engine with ross forged rods and pistons, hks ssqv bov, homemade MBC, aluminum y-pipe, 25spline output shaft, steel crank, lightly ported heads, rotora drilled and slotted rotors, gutted main cat, SPEC Stage II.
Audio : Sony CDX M8815x headunit, Alpine type-s 6 1/2" door panel speakers, Alpine type-s 6x9" rear speakers.
Originally Posted by eljefefx View Post
I've pretty much made up a list in my head of who here is more useless than two midgets at a giraffe farm.
moffman93' is offline   Reply With Quote
Old 02-19-2007, 10:31 PM   #17 (permalink)
Electrical Whiz
Drives: Topless!
Trader Rating: (37)
3000SL95 is an unknown quantity at this point
i'm very interested in doing this. I've heard many times about doing the hose reduction, but does it serve any benefits aside from a cleaner engine bay? and does it alter the performance of the car in any way? since you are eliminating things like the egr and a couple of solenoids that are controlled by the computer. my car is a 95 spyder which has the cali spec ecu, can i assume my car falls into that category of the 94-95 hybrid ecu cars?
1995 Vr4 Spyder purchased 3/01/05 Completely Stock. currently pushing 357 AWHP
3000SL95 is offline   Reply With Quote
Old 02-19-2007, 10:35 PM   #18 (permalink)
I kill brakes
Highboosted's Avatar
Drives: Other People Around
Trader Rating: (29)
Highboosted Level 1Highboosted Level 1
You can use the purge valve to plug the front turbo intake pipe. I used a vacuum cap.
On 94-95 cars you will get a CEL by removing the EGR system, but using the EGR-T for boost logging and keeping the sensor may prevent this, but it didn't work for me so EGR stays. EGR will NOT cause you to fail emissions unless the inspector is doing a visual inspection and owns one of these cars...
pıdnʇs 'ɹǝʌo ǝɯ dılɟ
Official member of the "I upgraded everything in my car and now it's slower than stock" club.
12.8@107, 13 psi @ NG09.
Highboosted is offline   Reply With Quote
Old 02-19-2007, 10:38 PM   #19 (permalink)
I kill brakes
Trader Rating: (29)
Less chance of boost leaks from torn hose, cleaner intake runners from EGR removal, easier maintenance. Your not going to get faster.
Old 02-19-2007, 11:03 PM   #20 (permalink)
Drives: 95rt/tt, suzuki
95 RT/TT is an unknown quantity at this point
really good thread, nicey done
95 RT/TT is offline   Reply With Quote
LinkBacks (?)
LinkBack to this Thread: http://www.3si.org/forum/f1/vacuum-hose-reduction-walkthrough-pics-359412/
Posted By For Type Date
FAQ..read Before Asking! - Page 2 - Automotive Forums .com Car Chat This thread Refback 04-13-2008 04:42 AM
