Hi All,
Not sure how relevant this is to most of you folks but I had some issues recently with my MAF.
I kept getting told by many very knowledgeable people that any MAF will work regardless of year or model. Every thread I read said the same thing. However...... my car is a JDM TT so what has been said on all these threads appears to be correct for USDM models ONLY.
I had some issue which I suspected was my MAF. So in all my wisdom I cleaned my MAF with electronic parts cleaner. This made my car undrivable as it stumbled and lurched constantly. I cleaned it again and it came good for about a week. Then back to the same issues. Then one day it threw a CEL pointing to code 12 air flow sensor.
I bought a replacement going on the above rule that any version will work.
I had a 165 which I replaced with a 337. The stumbling issues was gone but now I had a different CEL. Code 25 this time Barometric Pressure Sensor. I had the seller send me another one just incase it was a dud. Next one was a 789. Same issue.
Ran through diagnostic process in the service manual and confirmed wiring is all OK.
Did more reading and searching on ASA/CAPS on both JDM and USDM versions and found the part numbers listed for both are the same.
I then had a light bulb moment and worked out what the numbers mean. The 3 digit number is actually the last 3 digits of the part number.
So:
165 = MD170165 [1st gen TT/VR4]
618 = MD183618 [2nd gen TT/VR4]
337 = MD357337 [NA]
338 = MD357338 [NA]
055 = MD151055 [NA]
789 = MD187789 [NA]
From this brainwave I realised the 2 parts I had tried are both from an NA version.
I then sourced another 165 and fitted it tonight and car is back to normal. No CEL.
So... moral of the story is. If you have a USDM 3S then you should be able to use any MAF version. However even 3sx sell a different part number per version so I would attempt to locate the correct part number.
If you have a JDM GTO then you MUST use the correct part number.
I can only assume this is due to the differnt ECU used. I am yet to check the ECU part numbers for Europe yet as I haven't installed EU ASA. Once I have done this i'll check back.
These are the threads I had running incase it's helpful to anyone.
http://www.3si.org/forum/f1/issues-using-alternative-maf-part-number-502142/
http://www.3si.org/forum/f1/cel-code-25-barrometric-pressure-sensor-501593/
http://www.3si.org/forum/f155/australia-anyone-got-1st-gen-maf-spare-502208/
Sorry about the length but hopefully it will help someone in need.
Cheers,
Joe
So:
337 = MD357337 [NA]
338 = MD357338 [NA]
055 = MD151055 [NA]
789 = MD187789 [NA]
Cheers,
Joe
