Old 05-12-2008, 10:29 PM   #11 (permalink)
Certified *** BADASS
superinflamo's Avatar
Drives: 1995 3000GT VR4
Trader Rating: (11)
superinflamo Level 3superinflamo Level 3superinflamo Level 3superinflamo Level 3
Default Re: TwoStep Worth It?
i think when a car is two-stepping, it sounds like shit
like somethings misfiring, even though its helping out the car get a better launch
lol
Originally Posted by i3igpete View Post
just wait until you get the 16g's in there and mash the throttle. 2nd gear =
superinflamo is offline   Reply With Quote
Old 05-12-2008, 10:37 PM   #12 (permalink)
Master Of Disaster
Gray Haze's Avatar
Drives: 3S's Since Feb 2002.
Trader Rating: (26)
Gray Haze Level 3Gray Haze Level 3Gray Haze Level 3Gray Haze Level 3
high 1.5 60's.
Just gotta find the right RPM, and timing adjustment.
Dont even bother with the switch on the EMU, just use the vs pulses. Start off around 10 pulses, that should be around 12-15 feet that you can slip the clutch before the rev limiter goes high.
4500K, pull 10 deg, then test it and see if you can build enough boost.
I 2step down low, but I also have a carbon carbon that i can slip the bejesus out of.
1992 3000GT VR-4 #15 of 24. The ORIGINAL Sandstone Gray '99 Conversion.
A slow strangle with your feet on the floor.
www.3stech.org - Now with 100% less invite codes! Free Registration!
Gray Haze is online now   Reply With Quote
Old 05-14-2008, 01:53 PM   #13 (permalink)
keithmac Level 1keithmac Level 1
I have mine set at 5000rpm (fuel cut only though), I found full throttle shifting using the same rev limit worked very well also; seems less stress to the tranny.
JDM GTO TT, Emanage Blue - 450`s
Hotwired Walbro - Gutted MAS - K&N
Blitz SSBC - Aquamist Water Injection
keithmac is offline   Reply With Quote
Old 05-14-2008, 03:28 PM   #14 (permalink)
crazzy259 is an unknown quantity at this point
Something IS missing.
The EMU is pulling spark to make it miss.
Kinda the whole point.
crazzy259 is offline   Reply With Quote
Old 05-14-2008, 04:20 PM   #15 (permalink)
resident evil
wraith's Avatar
Trader Rating: (15)
wraith Level 7wraith Level 7wraith Level 7wraith Level 7wraith Level 7wraith Level 7wraith Level 7wraith Level 7wraith Level 7wraith Level 7
get the aem. After you add a timing controller, fuel controller, two step, etc., you have a bunch of boxes, tons of taps and splices into everything. Keep it clean and and keep it centralized and just get a better controller. I am saving all of you a ton of time and energy because I already went thru all the piggys and ejected all that crap for a better solution. I might not have saved alot of money, but what I have is much better then what I left behind.
wraith is offline   Reply With Quote
Old 05-14-2008, 08:33 PM   #16 (permalink)
Drives: all four wheels
darkkiller Level 1darkkiller Level 1
running the MSD dis-4 with the launch control hooked up, havent broken any parts musta launched my car over 50 times with the 2 step now, oh and im using a spec stage 4 unsprung launching at 5750rpms. just gotta know how to drive and u wont break things
Originally Posted by IttyBitty9Bees View Post
ugh, f&#ckin women. Someone decided they should have an opinion and it all went downhill from there.
darkkiller is offline   Reply With Quote
Old 05-14-2008, 09:18 PM   #17 (permalink)
rock on, yeah rock on
spfan's Avatar
Drives: 4 x 22,000 lbs jets
Trader Rating: (6)
spfan is an unknown quantity at this point
and for those of us that want to still be able to pass emissions? which requires a stock ecu be in place? i don't mean to be argumentative, just throwing it out there. the emanage ultimate has a 2-step in it.
Dyno Collection Thread
1993 Dodge Stealth ES, White, April 2002 - April 2005, SOLD 1 of 53
1993 Dodge Stealth TT, Black, Since April 2004, 1 of 5 ever made more rarity info
2003 Subaru Forester 2.5X, Blue, Sept. 2005, Daily Driver with 165 HP of Fury! At least it's AWD.
305 awhp, 325 awtq(BPU minus full catback exhaust)Mods at that time
13.02@104.67 (9bs, dp, fipk, 15.5 psi, bov, no cats, streetmax clutch, 1.77 60', decent conditions, full weight (even spare tire/jack)
13.09@105.08 (1.80 60', same conditions as above)
Beyond BPU: (meaning upgraded turbos/fuel/etc) before engine rebuild Mods at that time
12.38@113.00(20 psi, 110 octane, massive knock above 6k rpms)
12.41@115.10(ditto)
After Rebuild: Current Mods Dyno Tune by IPS
12.8@108 (12.5 psi dropping to ~11 @redline, 2.0 60', pump gas, my tune)
spfan is offline   Reply With Quote
Old 05-14-2008, 09:24 PM   #18 (permalink)
Paid Member
bstewart87's Avatar
Drives: 92 Stealth
Trader Rating: (14)
bstewart87 Almost Gonebstewart87 Almost Gone
Originally Posted by Gray Haze View Post
high 1.5 60's.
I agree with Gray Haze. Don't use the switch to 2 step. It is more of a headache than it is worth. Use the method using the vs pulses as he stated.
bstewart87 is offline   Reply With Quote
Old 05-15-2008, 04:58 AM   #19 (permalink)
alottaboost's Avatar
Drives: 95 Stealth RT/TT
alottaboost is an unknown quantity at this point
getting the new msd digital 6al2 here. has a built in 2 step and it's all dials, so you don't have to worry about getting a 6al, 2 step box, and misc pills and wiring running all over the place. just sticking the 6al2 in the glove box and forgetting about it. should build mucho boost off the line.
alottaboost is offline   Reply With Quote
Old 05-15-2008, 06:20 AM   #20 (permalink)
Pro xfercase destroyer
mjannusch's Avatar
Drives: 2005 Toyota Prius
Trader Rating: (15)
mjannusch Level 1mjannusch Level 1
Wrong box - you need DIS4 or DIS4Plus.
-Matt
'95 3000GT Spyder VR4 (11.838@117.56)
'93 3000GT VR4 (Project for 2009)
'91 3000GT VR4 (Only a shell of its former self)
mjannusch is offline   Reply With Quote
