Old 09-06-2008, 01:33 PM   #51 (permalink)
Certified White Boy
92stealth15g's Avatar
Drives: 1992 Stealth RT/TT
92stealth15g Level 392stealth15g Level 392stealth15g Level 392stealth15g Level 3
Default Re: Trying To Fix Clutch! Need Hlp! Pics
alright I didnt realize it was an NA. sorry. haha. you really did a number on that PP. Nice job man, i beat the hell out of my car and its a TT and I dont even work my shit over that bad. The worst ive done is blow my springs out of the disk.
"Clutch-Eater"
-1992 Dodge Stealth R/T Twin turbo AWD, Dynamic Racing stage II heads, 99 lifters, 6-speed Getrag from 99 vr4, SPEC Stage 4 clutch, TEC 15g's, Greddy blow off valve, Dejon Powerhouse Blow-Thru Intake Pipes, DSM sidemounts, Denso fuel pump, 550cc fuel injectors, Apexi SAFC, HKS VPC, Apexi AVCR, msd ignition dis-4, MSD 8.5mm wires, NGK coppers 1 stage colder, alamo y-pipe, custom exhaust from turbos back, highflow cat, Lowered, Nitto tires.
"Knockin' Beater"
-1996 Mitsubishi Eclipse GS
Originally Posted by TitanGenesis View Post
"That thing got a hemi?"
"No, it's got a V6 TT with AWD sup?"
92stealth15g is offline   Reply With Quote
Old 09-06-2008, 02:24 PM   #52 (permalink)
I drive a Banana
VillasenorStealth's Avatar
Drives: 1994 Stealth R/T
VillasenorStealth level 6VillasenorStealth level 6VillasenorStealth level 6VillasenorStealth level 6VillasenorStealth level 6VillasenorStealth level 6
well a combination of things caused that clutch to fuck up.. first of all i learned to drive standard on it and so did my brother.. and i race a lot and ride the clutch
VillasenorStealth is offline   Reply With Quote
Old 09-08-2008, 03:12 PM   #53 (permalink)
I drive a Banana
so i today i went to exchange my clutch and the manager said he wouldn't do it cuz i supposibly "damaged" it too much.. well i argued and argued and just my luck it turns out they gave me the wrong clutch haha!! they gave a clutch for the tt.. supposibly those have like 23 or 26 needle things and a NA clutch is supposed to have only 20!! idk if this was really the reason for the clutch to crack tho?
Old 09-08-2008, 04:33 PM   #54 (permalink)
Foolish
Mikes95RT Level 2Mikes95RT Level 2Mikes95RT Level 2
There is no way a TT clutch would even start to fit on a NA flywheel. God only knows what they sold you but it wasn't a TT clutch.
Mike Sullivan 95 Stealth FWD TT conversion 10:1 compression@12 PSI
Go...
13c turbos,450cc injectors,
TT pump,3SX braided return line
TurboXS type S open B.O.V.
ATR down pipe
Stuff...
K&N filter,unorthodox U.D.P., Optima red top,
ET performance krank vents
3SX lower poly mounts
Polished y pipe.
cool...
Stock intercoolers,Alcohol injection thanks to turbomirage.com
Tranny...
Auto to 5spd conversion to AWD 5spd/fwd
SPEC Stage 2 AWD clutch 3SX braided clutch line.
Wheels...
Exel Mimi
Fulda extremo 245-40-17
Intrax springs
Control...
Apexi SAFC 2,TT ECU and harness.
TurboXS M.B.C.
M.S.D. Knock alert
Gauges...Autometer...
E.G.T.,Boost,Air/Fuel ratio meter.
13.599@112 at 13psi....traps high enough for 12.3's with the traction for mid 13's..gotta love FWD
All aftermarket parts happily purchased from 3SX performance.com
Turbo conversion parts happily purchased from Mitsuspecialties.
Mikes95RT is offline   Reply With Quote
Old 09-08-2008, 04:48 PM   #55 (permalink)
2 + 2 is CHICKEN!
TwIzTeD_3kGt's Avatar
Drives: 1997 VR4 / 1994 SL
Trader Rating: (11)
TwIzTeD_3kGt Level 7TwIzTeD_3kGt Level 7TwIzTeD_3kGt Level 7TwIzTeD_3kGt Level 7TwIzTeD_3kGt Level 7TwIzTeD_3kGt Level 7TwIzTeD_3kGt Level 7TwIzTeD_3kGt Level 7TwIzTeD_3kGt Level 7TwIzTeD_3kGt Level 7TwIzTeD_3kGt Level 7
+1
TT clutch is a lot bigger than NA, probably the size of the flywheel itself.
TwIzTeD_3kGt is offline   Reply With Quote
Old 09-08-2008, 08:04 PM   #56 (permalink)
I drive a Banana
oh man then idk wat they were talking about
