#21 (permalink) |
2 + 2 is CHICKEN!
Reading what you write is giving me headaches. If you didn't drain the fluid out of the tranny before you started all this, then yes fluid should come out when you remove the axles.
#23 (permalink) |
Certified White Boy
oh jesus man.... you are trying to drop the transmission to fix the clutch? It sounds like you dont really know what you are doing and its going to be a pain in your ass to do. I have a pretty high mechanical knowledge and I just did the clutch in my stealth and it was a BITCH. I just hope you have a transmission jack and some better luck if your breaking stuff. follow the stealth316.com instructions.
"Clutch-Eater"
-1992 Dodge Stealth R/T Twin turbo AWD, Dynamic Racing stage II heads, 99 lifters, 6-speed Getrag from 99 vr4, SPEC Stage 4 clutch, TEC 15g's, Greddy blow off valve, Dejon Powerhouse Blow-Thru Intake Pipes, DSM sidemounts, Denso fuel pump, 550cc fuel injectors, Apexi SAFC, HKS VPC, Apexi AVCR, msd ignition dis-4, MSD 8.5mm wires, NGK coppers 1 stage colder, alamo y-pipe, custom exhaust from turbos back, highflow cat, Lowered, Nitto tires. "Knockin' Beater" -1996 Mitsubishi Eclipse GS |
#24 (permalink) | |
2 + 2 is CHICKEN!
