#1 (permalink) |
alright the other day i was heading out to ct to get the emissions done and as i was driving on 84 the trans just started to slip badly. id give it a little gas and the rpms would just shoot up without the tranny engaging. i pulled off the next exit and check the fluid. fine. after the car sitting for half an hour i started it back up and it would catch and i could move again. 2 minutes later trying to drive up the on ramp it started slipping again. i tried running it in L, 2, D w/o o/d and o/d. same thing. it seemed like once the car was running it would slip. and then after it cooled down a little the trans would work for a little while, i drove it onto the flatbed and into the parking space where its being kept after all. any ideas?
#3 (permalink) |
Member
Could be a clogged trans filter. Worth doing the service first. Ive seen this before on newer carvans.. When cold it drives fine, After 20 minutes of driving the trans starts skipping
Bob
Rear ended by homeless drunk driver July 12 04Please wait 13 seconds.. RPS full face clutch, Fidanza flywheel, ATR downpipe, TurboXS dual stage boost controller, K+N fipk, Turboxs h34 bov, Kormex 25 spline, recall transfercase. 180k service done thanks Clint. Soon>>>Hotwire + fuel pump, water/meth ![]() SOLD Now driving 38mpg Escort |
#4 (permalink) |
im REALLY hoping i dont have to go through a rebuild. to be honest i doubt the trans has been serviced since it came from the factory. whoever had it before me really did not care to even bother with maintenance. ill deal with the trans filter and do a fluid change and see what happens.
#5 (permalink) |
est. sept, 2000
if it slipped you burnt clutches and bands. if it was 100% not engaging you might be ok with a service.
97 VR4 12.417@111.16 9b time. full weight almost BPU
95 mark viii. 14.35@98 03 cobra vert. 4 mods=118mph traps 91 stealth TT. td05 18G, heads/cams, 3000lbs 95 montero SR. factory rear locker. 3.5 DOHC ![]() |
#6 (permalink) |
Warning: I'm an asshole
The #1 destroyer of automatic transmissions is failing to change the fluid and filter at the recommended service interval.
1992 3000GT VR4
![]() ![]() --Completely rebuilt 5/06-4/07. Everything new. For a list see: http://www.3si.org/forum/showthread.php?t=372579 --First time on dyno: 364AWHP@16psi with a 10.3AFR (now tuned at 11.4-11.6 with timing control, time for another dyno run soon) --Mods: DR Stage I heads, 3rd gen lifters, TD04L 13Gs, DSM SMICs, PTE 550s, Apexi SAFC, Apexi SITC, Walbro FP, IPO hotwire, Robbeck adapter & AEM FPR, 3SX underhood fuel gauge, 3SX fuel rail loop, DN Y-pipe, HKS SSQ BOV, K&N FIPK, Greddy Profec Spec S, AEM WB02, Autometer C2 boost, egt, oil press & water temp gauges, MSD wires, NGK BCP7ES's, TEIN FLEX coilovers, Maximal performance control arms, solid engine mounts & powdercoating, RPS Streetmax Clutch, RPS Flywheel, NBT Tranny (cryotreated OS, shift forks & rails), updated speedo gear, solid shifter bushings, full 2nd gen brake conversion, 3SX SS brake & clutch lines, Carbotech Panther+ pads in the front & Bob Cats in the rear, 3SX clutch vac delete, EGR delete, vac reduction, Ebay DP, gutted pre cats, Bronze FN01RCs 5Zigen 18x8.5 + 30 offset, Pirelli P-Zeros, engine dress up kit, Bigtyla ground wire kit. --Daily Driver: 98 Malibu, 4cyl, auto |
#7 (permalink) | |
GTONW is good to go
drain the oil in a clean tub and check for sludge, if you got sludge you got no clutch plates left. IPT do everything for these and at a very reasonable price too. possibly the best place for the pan filter and pencil filter along with fluid and gaskets good luck
#8 (permalink) |
alright well the transmission pan is off and the fluid was jet black. i was told that the gaskets were discontinued though. i also looked on 3sx and couldnt find a replacement. there were also 3 flat magnets in the pan. anyone have an explanation for this?
#9 (permalink) |
Member
The gasket may be just an RTV suitable for trans fluid. Availabe at any auto parts store.
The magnets are there on purpose. They collect, or try to collect, the metallic debri that otherwise would be floating around and eventually wearing the seals. Simply clean the magnets of the fuzzy stuff and reinstall. Use a can of brake parts cleaner to remove residue of trans and pan especially since you are most likely gonna use an RTV....sometimes the rtv won't stick and may leak if the surfaces are not really really really clean...It sucks to have to take the pan down again. If you do use the RTV, I like to put a generous amount all the way around. Then with a glove on take your finger and evenly smear RTV on the pan gasket surface. Then take a pencil or the cap that the RTV came with and poke the holes clear because you dont want RTV inside the threaded cavities.....if the hole isn't open on the other side, the pressure caused by the bolt going in can crack the case. |
