Old 09-22-2008, 05:23 PM   #1 (permalink)
92EuroDiamante's Avatar
Drives: Jdm D, D-LS, GTS
92EuroDiamante Level 792EuroDiamante Level 792EuroDiamante Level 792EuroDiamante Level 792EuroDiamante Level 792EuroDiamante Level 792EuroDiamante Level 792EuroDiamante Level 792EuroDiamante Level 792EuroDiamante Level 792EuroDiamante Level 7
Default transmission question
okay, so i got my new transmission in late april and i love it but it has one weird thing. when starting cold after the car has been sitting and i put it into gear the rpms go up but the car barely moves. no noise and this only lasts like a second or two (so if i took it up to 3.5k after starting it and let it drop it wouldnt move but as the rpms fell it would have already started moving (like i said it only lasts a second)
Any ideas why it would do this? its so much torquier feeling then my stock trans and i really like it but im just wondering why it would do this
Godspeed Radiator,Custom Washer Reservoir Delete Cold Air Intake,Pro-Topline Pistons (old aussie co not topline) ,Custom Dual Exhaust,Homemade Resonated test pipe,Unorthodox underdrive pulley, Stock+Aftermarket Air Ride System, Lowered, Active Aero.Beefed up Tranny (long story), Sniper wet nitrous kit (needs to be tuned)
92EuroDiamante is offline   Reply With Quote
Old 09-22-2008, 05:47 PM   #2 (permalink)
VR3.9's Avatar
Drives: 93 VR4 & 91 VR4
Trader Rating: (8)
VR3.9 Level 7VR3.9 Level 7VR3.9 Level 7VR3.9 Level 7VR3.9 Level 7VR3.9 Level 7VR3.9 Level 7VR3.9 Level 7VR3.9 Level 7VR3.9 Level 7VR3.9 Level 7
Default Re: transmission question
Clutch needs adjusting. Important to do for the tranny to last longer too. Will also improve shifting
Go to jackstransmissions.com he has pretty good video on how to do it.
FIPK, Megan Racing DP, Gutted Pre Cats, MBC, Walbro Fuel pump, Ground Controls, Unortodox Racing Flywheel, Slotted and Vented Rotors. Maximal Rear adjustable upper control arms. Poly Mounts
Under the Knife for: JDM motor with 25k. 13T's, 550CC injectors, SAFCII. Rebuilt 5 speed 25spline tranny.
VR3.9 is offline   Reply With Quote
Old 09-22-2008, 06:58 PM   #3 (permalink)
ccrunner84's Avatar
Drives: 92 Stealth RT/TT FWD
Trader Rating: (16)
ccrunner84 is an unknown quantity at this point
Don't believe Diamante's came with a 5spd, but I could be wrong.
1991 Dodge Stealth RT/TT
2004 Saturn Ion Redline @ 12psi - Daily Driver
ccrunner84 is offline   Reply With Quote
Old 09-22-2008, 07:10 PM   #4 (permalink)
H to the izzO
Hannibalzero's Avatar
Drives: Recklessly
Trader Rating: (55)
Hannibalzero Level 7Hannibalzero Level 7Hannibalzero Level 7Hannibalzero Level 7Hannibalzero Level 7Hannibalzero Level 7Hannibalzero Level 7Hannibalzero Level 7Hannibalzero Level 7Hannibalzero Level 7Hannibalzero Level 7
I wouldn't be surprised if they did in Europe.
Hannibalzero is online now   Reply With Quote
Old 09-22-2008, 07:30 PM   #5 (permalink)
VR3.9's Avatar
Trader Rating: (8)
after re-reading it, it sounds like he's talking about an automatic not moving like it should rather than a manual moving when it shouldn't.
Old 09-23-2008, 02:20 PM   #6 (permalink)
yes, and the euro diamante wasnt even from europe....go figure right? Its a model they made for i think two years then where like shit people would rather buy a bmw for that much not a jap car!
its a different transmission then stock diamantes but unfortunately still automatic. Im just gonna beat the hell out of it cause i have been steadily saving for either a new engine or alot of upgrades to put on this winter and i will have to go manual by then. like i said it doesnt effect anything other than on start up, shift smooth or fast depending on how its set.
