Tools a 3s owner should own. - Page 3 - 3000GT/Stealth International Message Center
Old 01-20-2013, 09:07 PM   #21 (permalink)
kawik101's Avatar
Drives: '93 Stealth RT/TT
kawik101 is an unknown quantity at this point
Feedback Score: 1 reviews
Default Re: Tools a 3s owner should own.
A must for TT owners
kawik101 is online now   Reply With Quote
Old 01-20-2013, 09:17 PM   #22 (permalink)
Thread Killer
hunt.chad's Avatar
Drives: 91 SLTT, 94 SL
hunt.chad is an unknown quantity at this point
Feedback Score: 18 reviews
a shovel..... so you can dig a pit and throw your money into it
Originally Posted by Turbo Beast View Post
Holy shit, besides racing cars, building motors you ride bulls too?
You are the manliest man ever!
hunt.chad is offline   Reply With Quote
Old 01-20-2013, 09:23 PM   #23 (permalink)
^^My name is April^^
dbest671's Avatar
Drives: Spyder VR4, SRT8
dbest671 Level 2dbest671 Level 2dbest671 Level 2dbest671 Level 2dbest671 Level 2
Feedback Score: 72 reviews
dbest671 is offline   Reply With Quote
Old 01-20-2013, 09:35 PM   #24 (permalink)
Djmba's Avatar
Drives: 1992 3000GT VR-4
Djmba is an unknown quantity at this point
Feedback Score: 15 reviews
Lol. Good one April. I'm surprised only one person said a magnet. I thought the shovel comment was spot on.
Daily driven 1992 3000GT VR-4. Check out my rebuild and progress thread: http://www.3si.org/forum/f1/my-1992-...ebuild-543314/
Modifications as of 3/21/13:
3.1L, 0.050" oversized pistons, forged crank, 3SX lightweight crank pulley, K&N intake, CX Racing pre turbo pipes. SS Y-pipe, SS oil feed/return lines, DNP precat deletes, test pipe, ESP downpipe, DSM SMICs, Ninja Performance boost controller set to 13 psi, vacuum reduction, 6 puck clutch, Drweldin custom spark plug cover, Depo Racing gauges, custom leather seats, and MMCdroid OBDI-Bluetooth datalogging adapter. Everything built and done by me. More to come soon.
Currently building/on the shelf:
3.01L, 0.020" oversized pistons, forged crank, NA block, 13T turbos, KYB GR-2 struts, Tein S-Tech lowering springs.
Djmba is online now   Reply With Quote
Old 01-20-2013, 09:35 PM   #25 (permalink)
Adam7's Avatar
Drives: With Both Hands
Adam7 is an unknown quantity at this point
Feedback Score: 2 reviews
Swivels and extensions for sockets(all sizes)
Torch
Die grinders,cut off wheels, sawsall
Blow gun
soldiering iron
Good jack w/4 stands
PB Blaster
good towels
1998 3000GT SL: Current build - TT conversion w/chromed ECU. IPS downpipe, testpipe, Borla catback, Catless, polished Ypipe, Injen filter, Kurama intercooler hose's, 3sx fuel loop, Stm filter to rail, hotwired fuel pump, Greddy+Mishimotto catch cans, Hallman pro MBC, msd 8.5wires, 18x9 Saleens w/Nitto's, Powerslot rotors, Hawk pads, polished plenum, 5k hid's, clear corners, marqui window tint, Tenzo racing seats, weight reduction(289lbs),gasket matched TB/upper/lower plenum,polished exhaust manifold,hdr front lip,UP rear strut bar,Autometer sport comp gauges(center vent & pod) AEM WBO2
Adam7 is offline   Reply With Quote
Old 01-20-2013, 10:37 PM   #26 (permalink)
There will be Blood!
CoopKill's Avatar
Drives: '94 3000GT VR4
CoopKill is an unknown quantity at this point
All this and no one has listed the most important tool...
Factory Service Manual!
.................................................................. If it ain't FUN, I'm Done! ..................................................................
'94 VR4
Still Unsatisfied!
CoopKill is offline   Reply With Quote
Old 01-21-2013, 12:24 PM   #27 (permalink)
jordache16's Avatar
Drives: '94 Black VR4
jordache16 is an unknown quantity at this point
Feedback Score: 0 reviews
Good thread, I can see this being a sticky.
Here is a list of tools I have purchased/received over the past 4 months for using on my VR4:
- Multi meter (must have)
- Floor jack
- 4 jack stands
- Telescoping magnet (must have)
- 1/2" flex head ratchet with extended handle (for removing lug nuts and larger bolts around the car)
- Set of 1/2" impact short well sockets (10mm - 24mm) - would have preferred deep well but both sets were on clearance and the deep wells were out of stock
- 1/2" torque wrench (it's a cheap one but it gets the job done for tightening lug nuts)
- Set of metric combination wrenches
- 138 piece mechanics tool set (includes 1/4", 3/8" and 1/2" ratchets with sockets and extensions) - Asked for this for Christmas
- 4 piece set of 3/8" extension bars
- Large set of flat head and philips screwdrivers (also received this for Christmas)
- Small LED flash light (must have)
- Transaxle fluid pump
- Several piece electrical tool kit (included a crimper, cheap wire strippers, needle nose pliers, black electrical tape, zip ties, alligator clips, various crimp on connectors, extra wire, continuity test light, etc.)
Here are some of the tools which I already had that I have used on my VR4:
- Set of metric ratcheting combination wrenches (very useful for things like battery removal)
- Good wire strippers (used these when replaced rear speakers)
- Tin snips / side cutters (a bit overkill but are great for cutting things like zip ties and wire)
- Needle nose pliers
- Crescent wrench
I had various screwdrivers that I had collected over the years and a cheap 3/8" socket set that I had been using before Christmas which got me by but there were several gaps in these two departments and I found myself needing to buy individual sockets, for example, which is a big reason I wanted new sets for Christmas.
I have probably missed some things here but for someone planning on doing most of the maintenance on these cars themselves and don't yet have a lot of tools I see this list as a decent guide as far as what someone can expect to purchase. I probably have over $300 invested just in tools over the past few months, a lot of which is overkill as several of these items (i.e. individual sockets or wrenches) I may rarely use (if ever), at least on my VR4 anyways. The way I look at it is since I didn't have a lot of tools yet, it was/is more cost effective to buy the set of wrenches, for example, instead of just the individual ones which I needed at that particular time and didn't already have. I may very well have a need for some of these things down the road on a different car or around the house.
jordache16 is online now   Reply With Quote
Old 01-21-2013, 02:32 PM   #28 (permalink)
Adam7's Avatar
I bought a set of the craftsman ratcheting wrenches and realized I cant stand them, never use them. I guess the idea is great for simple things, but their just too bulky to fit in tight spots.
Old 01-21-2013, 09:35 PM   #29 (permalink)
getting there
nawz8r's Avatar
Drives: '91TT, '95TT
nawz8r is an unknown quantity at this point
Feedback Score: 19 reviews
I like the 10mm nut-driver for hose clamps. Handy and quick!
Mitsu 13g's, DSM SMIC's, 3SX DP, Safc II, Hotwired Walbro, Hallman Pro mbc, K&N FIPK, Greddy RS bov,
'99 lifters, DNP Y-pipe, Tein S Techs, Random Tech H-flow cat, Catless precats, Moda MD1 19x8.5
nawz8r is offline   Reply With Quote
Old 01-21-2013, 09:52 PM   #30 (permalink)
Ancient Spirit Of Evil
kelvinTurbo's Avatar
Drives: Mumra tank
kelvinTurbo is an unknown quantity at this point
Default Tools a 3s owner should own.
Every 3s owner should carry this in the car, there are always ricers looking to get their behind raped by a 3s... At least lube them up a little
Lol other than that... Tire iron and jack carry it always, and a spare... Laugh all you want now, one day in the middle of a blizzard, out in bumfaack Egypt some place, wolves howling in the distance and you have no spare or tools... Cellphone shows no bars...
Sent from my iPhone using AutoGuide.com App
Ancient spirits of evil, transform this decayed form into Mum-ra!!
Your girl kissed me on my neck, then kissed me on my chest... and then she... took it to the head yeaay yeaay! no excuses no apologies she's all about it
kelvinTurbo is online now   Reply With Quote
