Old 09-20-2005, 03:45 PM   #51 (permalink)
Twin turbo toy
1HOT VR4's Avatar
Drives: 92 VR4
Trader Rating: (34)
1HOT VR4 is an unknown quantity at this point
Default Re: Thottle Body O-ring repair/replace with PICS
One more thing to add to the to-do list
John McCain for president.
GT368SX-R's, Stage III Heads, New 4-bolt main w/ Venolia Pistons & Pauter rods, Denso 720cc injectors, GT-PRO custom headers, Race grind cams, Fidanza cam gears, 1-piece PST CFDS, AEM EMS & UEGO, Billet adjustable actuators, Blitz DSBC, K&N FIPK, Intrax springs, PRM dual-cannon titanium exhaust, Victory hood, Koyo Aluminum radiator, Setrab oil cooler, IPS FMIC, NOCAR billet T-Case, Supercar racing oil-pan, short shifter, Stillen DP, Black leather Recaro racing seats, 2nd gen brakes & steering wheel, Kaze front bumper lip, ETOH injection...& more Carizzma deep candy red paint in progress!
1HOT VR4 is offline   Reply With Quote
Old 09-20-2005, 03:52 PM   #52 (permalink)
Corn Its whats for boost
Import Power's Avatar
Drives: Vicki Insane
Trader Rating: (210)
Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7
Originally Posted by Mellon
yeah I fixed mine months ago.. freaked me out when I sprayed windex around the tb while checking for leaks and huge bubbles starting coming out of the wound up spring
Exactly where mine would bubble out of
AEM Factory Trained Tuner
91VR4-3.0L-Stock heads and Cams-762AWHP 747AWTQ 30psi E100 Daily Driver 10.63@121mph
T4 AWD 9.21 @ 154.98
T2 FWD 10.19 @ 140.31
T2-820FWHP 3.1L 27psi C16
91VR4 Red-17Gs w/supporting mods-sold
93SLTT/T2
91VR4 Pearl White-sold
91VR4 Black-sold
92VR4 Sandstone-sold
94VR4 Green-sold
93VR4 Pearl White-sold
NG09 Title Sponsor
3SX Performance
3SX Performance Service Email
Old 09-20-2005, 04:05 PM   #53 (permalink)
Former DSMer - now VR-4er
James92TSi's Avatar
Drives: #388 Red
Trader Rating: (11)
James92TSi Level 7James92TSi Level 7James92TSi Level 7James92TSi Level 7James92TSi Level 7James92TSi Level 7James92TSi Level 7James92TSi Level 7James92TSi Level 7James92TSi Level 7James92TSi Level 7
Originally Posted by Synchro
A word of experience - don't forget to get two full winds on the throttle springs!!
Heh. I had a bitch of a time winding those springs, and the first time I didn't get them wound all the way around properly. Imagine my surprise when my car wouldn't return to idle! It wouldn't be so bad if it were just one spring...
I like to draw a line across all coils of the outer spring before disassembly. Then when putting it back together you just wind it until the marks you made form a line again. Simple
'91 3000GT VR-4 Jackstand Racing League 2008 points leader.
'03 G35 Sport Coupe Retains transmission and full warranty, even with VDC off!
James92TSi is offline   Reply With Quote
Old 09-20-2005, 07:56 PM   #54 (permalink)
I did it without unspringing the coil at all
Wire tied it as it sat so it never lost tension
Old 09-20-2005, 08:01 PM   #55 (permalink)
I miss my boost.
Synchro's Avatar
Drives: '01 S2000
Trader Rating: (10)
Synchro is an unknown quantity at this point
Cheater.
REAL Men let the spring take two, three, hell maybe even TEN chunks out of their hands...just to prove the springs don't scare 'em!
Synchro is offline   Reply With Quote
Old 09-20-2005, 08:18 PM   #56 (permalink)
Mellon's Avatar
Drives: 91 TT Stealth 05 EVO
Trader Rating: (18)
Mellon Level 7Mellon Level 7Mellon Level 7Mellon Level 7Mellon Level 7Mellon Level 7Mellon Level 7
Cheater.
I'm a member of the notched finger club
- Chris
05 EVO and 91 Stealth R/T TT
**video**
Upload your 3/S videos here http://3svideo.vidiac.com and post www.racevideoforums.com
Intake: E16G turbos, DR Stage III heads, DR Race cams, Unorthodox Cam gears, Stock MAS, 6" K&N air filter, HKS SSBOV, Vacuum Reduction, custom 2.5" intake pipes and Dejon FMIC
Ignition: MSD 8.5mm spark plug wires, NGK non-resistor non-projected R5671A-8 gapped at .026, HKS Twin Power DLI
Electronics: Greddy Turbo Timer, Greddy E-Manage Blue, Greddy Profec E-01, MMCD and Palm, LM-1 Wideband + RPM Converter
Fuel: Blitz 720cc injectors, Denso 310lph fuel pump, Fuel pump Hotwire , relay bypass, IPO SX Fuel Pressure Regulator and Kenne Bell Boost-a-pump
Exhaust: Titan TD05 Headers and 02 housings, EGR Blockoff Plates, ATR downpipe, Twin Borla mufflers
Driveline: RPS MAX 6-Puck Clutch and RPS Flywheel, 17" Enkei RPF1 (16lbs each), Nitto 555 Extreme, TEIN S-Tech springs and KYB GR2 Struts
Other: Unorthodox Underdrive Pulley, Krankvents
Mellon is offline   Reply With Quote
Old 09-30-2005, 05:08 PM   #57 (permalink)
Hunter...
Drives: 9.08 @ 155 Supra
Wicked91RT is an unknown quantity at this point
I just did this now and it fixed the leak hissing!!!!
Bad thing is...the car wont accelerat or hold a constant RPM. If I hold it about 20% thorttle it will act like normal...then all of a sudden its like the power gets cut..then keeps doing that.
If I do it WOT it will do the same thing, just at the higher RPM...it will cut in and cut out.
It still idles the same, right around 1000rpm but after each time I turn it back on and see if I fix it...by the time im done the idle is at 1500 to 2000...I am just stumped!
I fix one thing and screw up another!!
anyone have any sugjestions? Is it possible to put the butterly in the wrong way and have it opening up backwords? Even soo...it doesnt seem like that would matter since its still opening and letting the air through.
http://www.to4r.com/members/bretttodd.html
White 6SPD 1994 GTS-76
618whp pump gas 18-19lbs
808whp race gas 30-31lbs
934whp race gas + n2o on IC and ~33lbs
All through a 2.75 inch downpipe
Daily Driver - 96 Full Race 67mm Honda Hatch
Wicked91RT is offline   Reply With Quote
Old 09-30-2005, 06:07 PM   #58 (permalink)
I miss my boost.
Synchro's Avatar
Drives: '01 S2000
Trader Rating: (10)
TPS misaligned maybe?
Forgot to connect a random sensor plug?
Old 09-30-2005, 07:40 PM   #59 (permalink)
Hunter...
I was just gonna come back on here and post that I got it
It was the TPS, I had it on wrong.
Thanks!
Old 10-01-2005, 12:42 AM   #60 (permalink)
activeSeven's Avatar
Drives: 1994 3000GT VR4
Trader Rating: (7)
activeSeven Level 1activeSeven Level 1
Be sure to use a voltometer to make sure that your TPS is on correctly....
[ s e v e n ]
activeSeven is offline   Reply With Quote
