#31 (permalink) | |
OMGOMGOMGOMG
Jake - 91 VR-4
#32 (permalink) | |
TEXAS!! FIGHT!!
hahahaha...... *Late Chris Farley - Tommy Boy* "Why?? "![]() |
#34 (permalink) | |
I hear what your saying and I know all about the importance of having proper O-rings. It's difficult trying to get specialty O-rings where I am, and I assume that goes for a lot of other people too. I guess I could track down some good quality O-rings if I really tried. The Home Depot #7's were mentioned in previous threads so that's what I searched for. let me know if you can share your source for those high quality O-rings, I'd really like to get some(2) for when the #7's start leaking. -silly
mods - this, that, and the other thing
#35 (permalink) | |
Loud Noises!!
But here is the mecca of o-rings; http://www.allorings.com/ |
#36 (permalink) |
No loer a Noob?
Have your pressure tested yet? I think something got lost in this mod. Origonaly the #7 oring is supposed to be put into the center of the existing stock shaft seals (the metal outside of the stock seal). If you just put the #7 oring in without first putting it into the stock trottle body shaft seals they have too much space around them and leak.
The #8 oring from home depot works without having to use the stock shaft seals. http://www.3si.org/forum/showthread....ghlight=o-ring sam
92 Stealth R/T TT - 13t's Installed. note:Is the machining right? - boosting to 15psi so far.
Do I do this for others? No. robbeck is your man.... We know his work . |
#37 (permalink) | |
Loud Noises!!
#38 (permalink) | |
-silly |
#39 (permalink) |
After thinking about it a little, maybe the O-rings I used were actually #8 and not #7. Since I got them from the assortment pack(Pic attached) I don't know which O-rings are which in the package. But I do know that as of right now they are a snug fit because the when I step on the gas pedal I have to first break the tension that the O-rings have on the TB shaft before the shaft will turn. So the O-ring assortment pack(Pic attached) should have the proper size O-rings, I'm just not sure if they're #7 or #8. I assumed that they were #7, and yes I now what happens when you A$$-U-ME
-silly |
