Old 02-23-2005, 12:16 AM   #21 (permalink)
Loud Noises!!
red_3000's Avatar
Drives: V R 4
red_3000 is an unknown quantity at this point
Default Re: Thottle Body O-ring repair/replace with PICS
yeah I pressure tested, and I'm leaking from my y-pipe (stock pos) BOV (stock pos), BISS o-ring & TB o-rings. So I replaced the o-rings, got a dejontool y-pipe and I have a DSM BOV in the mail.
Hopefully that gets rid on my leaks, and most importantly, my hesitation (mainly when it's cold) and overly ritch problems.
red_3000 is offline   Reply With Quote
Old 02-23-2005, 12:26 AM   #22 (permalink)
Loud Noises!!
red_3000's Avatar
Drives: V R 4
Silly, I don't want to burst your bubble, but those o-rings might be made of EPDM rubber. You should check the box to see what they're made of. Nitrile, HI-sat nitrile, silicon, or Viton are what you want.
EPDM rubber will degrade quickly when it contacts oil/fuel. Also the upper temp limit is 250degrees (not sure how hot the TB gets though). I suspect that they are EPDM because it is very good for use with water, and it is the most economical. If the box makes no mention of the composition... most likely EPDM.
Old 02-23-2005, 05:03 AM   #23 (permalink)
Mellon's Avatar
Drives: 91 TT Stealth 05 EVO
Trader Rating: (18)
Mellon Level 4Mellon Level 4Mellon Level 4Mellon Level 4Mellon Level 4
if those start leaking some day years down the road, replace them again worst case scenario.
- Chris
05 EVO and 91 Stealth R/T TT
**video**
Upload your 3/S videos here http://3svideo.vidiac.com and post www.racevideoforums.com
Intake: E16G turbos, DR Stage III heads, DR Race cams, Unorthodox Cam gears, Stock MAS, 6" K&N air filter, HKS SSBOV, Vacuum Reduction, custom 2.5" intake pipes and Dejon FMIC
Ignition: MSD 8.5mm spark plug wires, NGK non-resistor non-projected R5671A-8 gapped at .026, HKS Twin Power DLI
Electronics: Greddy Turbo Timer, Greddy E-Manage Blue, Greddy Profec E-01, MMCD and Palm, LM-1 Wideband + RPM Converter
Fuel: Blitz 720cc injectors, Denso 310lph fuel pump, Fuel pump Hotwire , relay bypass, IPO SX Fuel Pressure Regulator and Kenne Bell Boost-a-pump
Exhaust: Titan TD05 Headers and 02 housings, EGR Blockoff Plates, ATR downpipe, Twin Borla mufflers
Driveline: RPS MAX 6-Puck Clutch and RPS Flywheel, 17" Enkei RPF1 (16lbs each), Nitto 555 Extreme, TEIN S-Tech springs and KYB GR2 Struts
Other: Unorthodox Underdrive Pulley, Krankvents
Mellon is offline   Reply With Quote
Old 02-23-2005, 05:20 AM   #24 (permalink)
BucknVR4's Avatar
Drives: 94 VR4
Trader Rating: (9)
BucknVR4 is an unknown quantity at this point
That's what I was saying, just red_3000 has a more eloquent way of saying it.
BucknVR4 is offline   Reply With Quote
Old 02-23-2005, 08:19 AM   #25 (permalink)
OMGOMGOMGOMG
J-Ville VR-4's Avatar
Drives: 91 VR-4
Trader Rating: (13)
J-Ville VR-4 is an unknown quantity at this point
Default Re: Throttle Body O-ring repair/replace with PICS
The backs of them are hammered down (or crimped) from the factory.
The more commonly used term for this is peened
Jake - 91 VR-4
J-Ville VR-4 is offline   Reply With Quote
Old 02-25-2005, 02:10 PM   #26 (permalink)
asitmc's Avatar
Drives: 97 3kgt VR-4
Trader Rating: (31)
asitmc is an unknown quantity at this point
so what do we do to take off that screws????????????
don't want to strip anything..
I am going to do this soon,
asitmc is offline   Reply With Quote
Old 02-25-2005, 02:13 PM   #27 (permalink)
OMGOMGOMGOMG
Drives: 91 VR-4
Trader Rating: (13)
I was just really careful. I used a lot of pressure on the screwdriver when unscrewing them.
Old 02-25-2005, 02:21 PM   #28 (permalink)
Loud Noises!!
red_3000's Avatar
Drives: V R 4
I used a dremmel.
Here is a link with more pics about another o-ring to replace, and how to modify the TB to flow more air if you want to do that.
http://www.3si.org/forum/showthread.php?t=258294
Might as well get as much done as you can while it's off.
Old 02-25-2005, 03:00 PM   #29 (permalink)
asitmc's Avatar
Trader Rating: (31)
okok, Thanks for the link and info.
Old 02-25-2005, 03:16 PM   #30 (permalink)
TEXAS!! FIGHT!!
AdamVR4's Avatar
Drives: NoCar XCase Test Car
Trader Rating: (22)
AdamVR4 Level 7AdamVR4 Level 7AdamVR4 Level 7AdamVR4 Level 7AdamVR4 Level 7AdamVR4 Level 7AdamVR4 Level 7AdamVR4 Level 7AdamVR4 Level 7AdamVR4 Level 7AdamVR4 Level 7
Sometimes that works and sometimes it doesn't.
An impact screw driver made it almost impossible to strip them though. Those things are bad ass.
AdamVR4 is offline   Reply With Quote
