#11 (permalink) | |
No fuel flowing through but it sure ends up with oil base fumes. Maybe not enough to really make a diff. though especially if Vac reduction has been done.I was really just making a comment about those o-rings. Same ones that I replace often in my faucets due to my well water. ![]() |
#13 (permalink) | |
Here it is. Home Depot No.7 O-Ring 1/2" Outer Diameter 3/8" Inner Diameter 1/16" Wall Thickness Good Luck to everyone in searching for these. -silly
mods - this, that, and the other thing
#16 (permalink) | |
-silly |
#17 (permalink) | |
-silly |
#19 (permalink) | |
Loud Noises!!
The backs of them are hammered down (or crimped) from the factory. I had one screw about 1/2 turn and the other one I stripped before I figured this out. I had to drill one and used a reverse bit on it to remove it. You need to grind the backs of the screws off. Then when you re-install them (or use new ones), you should use locktite on the threads to be sure they don't fall out and get sucked into your engine. ![]() |
#20 (permalink) |
TEXAS!! FIGHT!!
What's odd, is removing them is only a major pain about 50% of the time... The rest of the time, they come right out... But I noticed what you're talking about, and on the last TB I worked on, ended up having the grind down the back side of the screw.
red_3000: Boost leaks KILL power. The most noticeable things will be an increase in lag, boost falling off more rapidly and more severely towards redline, and an overly rich state of tune at WOT. Aside from that, they're not a big deal ![]() Basically, pressure testing = free power. Do it. I can't emphasize it enough... |
| Thread Tools | |
