Old 03-24-2008, 05:38 PM   #121 (permalink)
Back in the Saddle
VR4neophyte's Avatar
Drives: 95 VR4 + 03 Vette
Trader Rating: (23)
VR4neophyte Level 1VR4neophyte Level 1
Default Re: Thottle Body O-ring repair/replace with PICS
Originally Posted by Drweldin View Post
Good tips....where did you order the o-rings from? McMaster or?
I used AC system o-rings, hopfully of better material than the Home Depot...
www.smallparts.com
part number is ORV-012-10
3/8" ID x 1/2" OD x 1/16" WIDE
$1.50 for a package of 10
I'm sure you can get 'em just about anywhere.
VR4neophyte is offline   Reply With Quote
Old 06-06-2008, 10:39 AM   #122 (permalink)
3sienvy's Avatar
Drives: Vr4
Trader Rating: (9)
3sienvy Negative 1
i have to actually pop off that metal retainer clip on the end of the shaft seal side? Reason being is wont there be a lot of movement forward and backwards with just a #8 in there, it seems like a lot of room. I tried stuffing the #8 behind the metal clip and it worked on one side but not the other. But now my throttle response is really sticky.
Help please.
3sienvy is offline   Reply With Quote
Old 06-06-2008, 11:27 AM   #123 (permalink)
BlackStealth's Avatar
Drives: 93 RT/TT
Trader Rating: (155)
BlackStealth Level 3BlackStealth Level 3BlackStealth Level 3BlackStealth Level 3
I used the parts VR4neophyte described, and it fits fine with the metal retaining clips.
BlackStealth is offline   Reply With Quote
Old 06-06-2008, 08:02 PM   #124 (permalink)
Drives: 1993 Mits 3000gt VR4
q2418130103p is an unknown quantity at this point
i used CR3930 oil seal orings as described in the write up below which is abot fixing DSM shaft seals.
they fit very well, has to used some grease, but they are VERY similar in shape to the originals.
TB Shaft Seals VFAQ
Want to Buy:
  • Door Interior with no bubbles
q2418130103p is offline   Reply With Quote
Old 08-22-2008, 09:44 AM   #125 (permalink)
VR4-Quest's Avatar
VR4-Quest is an unknown quantity at this point
I just redid my TB seals, was originally gonna go the o-ring route from Home Depot/Lowes, but didnt want this to be a problem again anytime soon, plus wanted better performance.
Some might have already mentioned these, and the EVO guys swear by them, and where the better performance comes in is that they can hold higher boost (25 PSI) than stock seals or o-rings for sure.
Throttle body shaft seal kit- 91-99 DSM and Evo 8/9 03+ : JNZ Tuning
Went on perfectly and no issues with being tight or loose, and hold 15 psi with no problem.
They are a bit pricey but well worth it to do the job right.
Michael S. Skurich
Dunlop/Goodyear Tire Design Engineer
mike_skurich@goodyear.com
corvetteboy6988@aol.com
Cars
1992 Mitsubishi 3000GT VR-4
2006 Mitsubishi Montero Limited
2005 Coupe Z51 6-speed
1988 Coupe L98 4+3
1969 Coupe 350/350HP 4 speed
2001 Isuzu Vehicross (SOLD)
Bikes
2002 BMW R1100S
1997 BMW F650ST (SOLD)
VR4-Quest is offline   Reply With Quote
Old 08-22-2008, 10:51 AM   #126 (permalink)
Regulator...
mikes2nd's Avatar
Trader Rating: (30)
mikes2nd Level 7mikes2nd Level 7mikes2nd Level 7mikes2nd Level 7mikes2nd Level 7mikes2nd Level 7mikes2nd Level 7mikes2nd Level 7
WARNING...
Mark the up and down, front and back of the butterfly.
Put a TOP, FRONT mark on your butterfly valve before you do anything.
Its a perfect fit and mind you you cant "eyeball" it either. You cant see the misfit.
If you dont get this back on exactly where it was youll get idle problems...
Hijacking semi's with black Civics since 2001...
mikes2nd is offline   Reply With Quote
