Old 04-05-2006, 07:57 PM   #101 (permalink)
TRILIGHT's Avatar
Drives: 91 Stealth R/T Turbo
TRILIGHT is an unknown quantity at this point
Default Re: Thottle Body O-ring repair/replace with PICS
Originally Posted by grtn316
I replaced the orings and now my idle is high & when i let off the gas it hangs for a few seconds before it starts to slowly decelerate.
Anyone have this prob?
Sounds like the throttle plate isn't centered properly or something else is too tight. Keeps it open more than it should be and doesn't allow it to close off as fast as it should when you let off.
Blitz SBC i-color EBC | HKS SSQV BOV | ATR Downpipe | K&N FIPK | Catless
Snow Performance Stage II Water/Meth Injection | Walbro 255 + Hotwire/Bypass
MSD Wires | Tein S-Tech Springs | AdamVR4 Extensive 120k
Aluminum Rear Control Arms | Silverstar lights/fogs
3SX SS Braided Brake Lines | Crossdrilled Rotors | EBC Redstuff
TRILIGHT is offline   Reply With Quote
Old 04-06-2006, 12:40 PM   #102 (permalink)
Wheels In Hand...
grtn316's Avatar
Drives: 95 TT
Trader Rating: (10)
grtn316 Level 5grtn316 Level 5grtn316 Level 5grtn316 Level 5grtn316 Level 5grtn316 Level 5
If I open and close it about 10 times it loosens up for a little bit. Guess my grease didnt work. What kind of grease is everyone using that has lasted them a while without stickin?
Personal Best:
1995 Stealth TT - 11/17/2006 - 1.759 60' / 11.978 @ 116.08 MPH - UNDER CONSTRUCTION
Building the 19T record!
grtn316 is offline   Reply With Quote
Old 04-06-2006, 12:47 PM   #103 (permalink)
No loer a Noob?
skunkworks's Avatar
Drives: low impedance inputs
Trader Rating: (9)
skunkworks is an unknown quantity at this point
I used lithium grease
sam
92 Stealth R/T TT - 13t's Installed. note:Is the machining right? - boosting to 15psi so far.
Do I do this for others? No. robbeck is your man.... We know his work
skunkworks is offline   Reply With Quote
Old 04-06-2006, 12:50 PM   #104 (permalink)
Wheels In Hand...
grtn316's Avatar
Drives: 95 TT
Trader Rating: (10)
what the phizzuck! thats why I am using and its sticking...
Old 04-06-2006, 02:17 PM   #105 (permalink)
TRILIGHT's Avatar
I wouldn't use that on the o-rings themselves. Fine for metal but I don't think it's good for rubber. I could be wrong. Silicone grease or dielectric grease for the rubber o-rings. I just went back and it looks like you put #8 in there? Way too big. I don't know why the hell people say to use that. #7 is a perfect fit and I have no TB leaks.
Old 04-06-2006, 02:23 PM   #106 (permalink)
Wheels In Hand...
grtn316's Avatar
Drives: 95 TT
Trader Rating: (10)
#7 fit in mine loosely & #8 was crammed in. Did you use that metal oring with the #7? Was your loose or was it a snug fit?
Old 04-06-2006, 02:28 PM   #107 (permalink)
TRILIGHT's Avatar
There was a metal o-ring there which made sort of a "channel" that the rubber o-ring sits in. It did not appear to want to be removed and I was not going to force it out. I put silicone grease (sold in a small round gray container in the same section as the o-rings) on them and slid them into place. It was a perfect fit. I have zero air leaks from the TB now.
Old 01-06-2007, 07:19 PM   #108 (permalink)
Trader Rating: (107)
Drweldin Level 3Drweldin Level 3Drweldin Level 3Drweldin Level 3
This is back from the dead, but Im about to do this, and was wondering if any one has compared the BISS o-ring to the T-body o-ring...if they are the same, then the exact ring could be ordered through mitsu...just a thought...maybe they are not even close (?)
1992 Stealth RT/TT:
Drweldin is online now   Reply With Quote
Old 01-07-2007, 04:25 PM   #109 (permalink)
I miss my boost.
Synchro's Avatar
Drives: '01 S2000
Trader Rating: (10)
Synchro is an unknown quantity at this point
BISS o-ring is much different from the shaft seals.
The BISS o-ring is just that, an o-ring. The shaft seals are metal rings that have a rubber flap that acts as a seal against the shaft.
Better to just go to a hardware store and buy some viton o-rings. Home Depot #8's worked best for me on my throttle shaft. I'd think that a #6 or #7 would work for the BISS, but I can't remember correctly (been a while). The only downside is that the Home Depot rings are rubber, so they will break down over time from the oil that comes through the PCV system into the intake.
It's not like rebuilding the throttle body is a huge chore, so in a year or two after the rubber rings wear out, you can replace them and clean the entire TB at the same time. Just follow a good maintenance schedule.
This really should be stickied...
Mods: Honda mod
Synchro is offline   Reply With Quote
Old 01-07-2007, 06:24 PM   #110 (permalink)
Wrenchmonkey #839
John Monnin's Avatar
Drives: crappy SHO
Trader Rating: (27)
John Monnin Level 7John Monnin Level 7John Monnin Level 7John Monnin Level 7John Monnin Level 7John Monnin Level 7John Monnin Level 7John Monnin Level 7John Monnin Level 7John Monnin Level 7John Monnin Level 7
I made a Wikipedia entry for this, I am trying to encourage other people to use Wikipedia mores so we won't have to search for greats threads like this.
http://www.3si.org/wiki/index.php/Th...ng_Replacement
For sale 3.5L 6g74 Swap modified oil pans and thermostat hosuings
http://www.3si.org/forum/f4/fs-6g74-...ied-3s-420690/
John Monnin is offline   Reply With Quote
