Those with Singer high output alternators - 3000GT/Stealth International Message Center
Old 01-20-2013, 03:28 PM   #1 (permalink)
TWIN-TURBO---
HYPERSONIC007's Avatar
Drives: 92' Dodge Stealth TT
HYPERSONIC007 is an unknown quantity at this point
Feedback Score: 2 reviews
Default Those with Singer high output alternators
Was thinking about getting one of these. Its apparently 220amp's, but uses a smaller pulley to generate more current at lower RPM. Just wondering if anyone knows what belt size it would require.
Rick
92' Dodge Stealth R/T Twin-Turbo
Mods:
TD04 19T's (17.5psi), EVO 560's, EVO8 MAF, HDi EBC-R, SAFC II, Custom Coach 14" FMIC, 18" VSR Sonic Wheels, Stillin Downpipe w/ Gutted Kitties, Shaftmasters 2 piece Aluminum/Steel Drive Shaft, AEM UEGO Wideband, Racing Seats, Hot Wired Walbro 255 FP w/ Resister Bypass, AEM FPR, Custom Fuel Supply/Return Lines, FMOC, Vacuum Reduction, EGR Block Off Plates, 15# Battery, Poly Front/Rear Motor Mounts, Clutch Vac Res Delete, Rear Wiper Delete, DEI Wrap, Custom Ground Wires, Hotwired Fans, MSD Wires w/ NGK Coppers, CXRacing Radiator, Drilled/Slotted Rotors, Blitz Dual Turbo Timer, Matrix Air Filter, Dejon Tool Intake Runners, EK2 Fuel Rail Adapter, H4 Headlight Conversion, Oil Filter Heat Sink, Synapse Synchronic BOV, GlowShift Fuel Pressure/Boost/Water Temp Gauges, KYB Struts, Sony Clie SJ22~MMCD...
Summer 13' Project: XTD Stage III Clutch, Maximal Stage II Transfer Case Bracket, KB Boost-A-Spark, 200A Alternator, VIS EVO Hood, Coolingmist Stage I Methanol Injection Kit, Poly Diver/Passenger Mounts
"God invented turbo lag to give V8's a chance"
HYPERSONIC007 is offline   Reply With Quote
Old 01-20-2013, 03:39 PM   #2 (permalink)
Audio Fanatic
hdorre's Avatar
Drives: '95 3000GT NA
hdorre is an unknown quantity at this point
Feedback Score: 5 reviews
Default Re: Those with Singer high output alternators
Why dont you just email Mike? He responds fast, and they are his alts.
hdorre is online now   Reply With Quote
Old 01-20-2013, 03:43 PM   #3 (permalink)
TWIN-TURBO---
Not sure if he will know
Old 01-20-2013, 06:15 PM   #4 (permalink)
Grandpa Poser's Avatar
Grandpa Poser is an unknown quantity at this point
Feedback Score: 0 reviews
Generally speaking the belt usually rides on half or less of the circumference. compare old and new, get the difference and divide by half. subtract that from the belt and it should be close enough to work.
Otherwise, your current tensioner may be able to handle adjustemnt under 1/2 in,
Side note, most things spinning have an effective useable RPM range. A larger driving or smaller driven pulley may bring top RPM out of range at high engine RPM.
Side note, the required HP to spin anything will increase with a larger driving or smaller driven pulley.
luck
When life throws you a curve......Drive Baby, Drive.
Grandpa Poser is offline   Reply With Quote
Old 01-21-2013, 12:43 PM   #5 (permalink)
TWIN-TURBO---
Excellent, thank you for the suggestions!
Rick
