#1 (permalink) |
Stupid question and behold my mspaint drawing!!!
I just replaced my plenum with a polished one (96 vr4). I made sure to rememebr every bolt, I tightened everything back hard by hand because I didnt have my adapter for my tourque wrench, but all the bolts are tighter than torque spec for now (i will redo). Anyways, When putting the plenum back on I couldnt remember is there was a gasket here?!?! Its where (what I think iss the rear turbo right?) connects to the back of the plenum? I thought I heard something fall when I put the plenum back on , sounded gasket like bujt couldnt find it (maybe it was my imagination). Anyways, the car seems to drive like normal as far as I can tell...but im worried about boost leaks. Was there a gasket for this? if so anyone have a part number?
![]() Maximum Power: 417.2 @ 5812RPM / 91.1MPH @ 18PSI (Mustang Dyno) Maximum Torque: 440.7 @ 3615 RPM / 57.3MPH @ 18PSI (Mustang Dyno) Best Track time: 12.211 @ 119.45 (NE Dragway) but not for long! www.MyVR4.net |
#2 (permalink) |
Rear pipe from O2 housing to plenum, it's the metal gasket shown on right. Very easy to loose when taking off that pipe if your not carefull. If you want send me your address via email and I'll send you one, got a few extras.
----------------[2007 Ride of the Year
![]() ![]() "Stroke" her I did. Retired - TD04 WRX19t's = 513awhp @ 18psi on PUMP ![]() |
