#1 (permalink) |
Corn Its whats for boost
Well, I have repaired the Tranny and have T4 back on the rollers.
Figured I would tune the piss out of her and see what she can do. The current record at 935 although held by a 3.6L Kia motor on a Dynojet I think we can break it or come close with the 3.0L All numbers will be totally UNCORRECTED. Since we got flack about using Dynojet correction we went to SAE correction which is about 11% lower than DJ. And the lowest you can go. We then got flack that we shouldn't use ANY correction. So for sake of argument we are using UNCORRECTED numbers. T4 1991 3000GT VR4 4 bolt stock block bored to 93mm due to wall scuffing Stock OEM crank 3SX-Pauter Rods 3SX Ross Pistons 3SX Exclusive Tool steel Piston Pins (kept bending aftermarket pins) 3SX Heads Fully built with +2 +1 valves 3SX Retainers and springs 3SX Ultra Weld cams 3SX Turbo Manifold kit (Available TD05 kit modified for T4 flange) AEM w/ dual uego 5 bar map Triple Walbro Fuel pumps 3SX Dual feed fuel system Spec stage 5 clutch MSD Dis4-HO MSD wires NGK copper race 9's On to the show End result:New record and with a 3.0L! ![]()
AEM Factory Trained Tuner
![]() 91VR4-3.0L-Stock heads and Cams-762AWHP 747AWTQ 30psi E100 Daily Driver 10.63@121mph SLTT-10.9 @ 140MPH Stock NA motor and NA heads/Cams T4 AWD 9.21 @ 154.98 T2 FWD 10.19 @ 140.31 T4-159.23 MPH Ran on 6G72 3.1L! T4-995AWHP Uncorrected 6G72 3.0L C16 T2-820FWHP 3.1L 27psi C16 91VR4 Red-17Gs w/supporting mods-sold 93SLTT/T2 91VR4 Pearl White-sold 91VR4 Black-sold 92VR4 Sandstone-sold 94VR4 Green-sold 93VR4 Pearl White-sold NG09 Title Sponsor 3SX Performance 3SX Performance Service Email Last edited by Import Power : 10-21-2007 at 09:03 AM. |
#5 (permalink) |
11 Sec Club on 13t's
Not bad keep them coming!
#10 (permalink) |
Crimson Jihad
Sweet!
CAUTION: Over Boosting May Cause Accidental Orgasm.
![]() 1993 Mitsubishi 3000gt VR-4 1994 Mitsubishi 3000gt SL mtx..... I miss her! Dyno: 243awhp/280awt On stock boost(~8psi) mods: K&N/Greddy type-RS (Badly Heatsoaked + Boost Leak). Mods: K&N filter, HKS SSQV, Redline motor oil 10w40, IPS 3" DP, Custom single shot, SSR GT7's, Tein S-tech,MSD 8.5 Super conductor wires, NGK |X Iridium spark plugs. Waiting install: Blitz DSBC, , Greddy fatt, Apexi Safc2, Apexi S-itc, Maximal mounts, FMIC, RobBecks 13t's, Maf-t, z06 maf, evo9 560cc, Denso supra pump. Contemplating: Small ones |
