#11 (permalink) |
Money Pit
Go:
DR-800 kit | AEM EMS | AEM Wideband UGEO | AEM 3.5 map sensor | AEM AIT sensor | AEM boost control solenoid | Front mount IC | PPE Engineering IC pipes | 3SX Custom Complete Underhood Fuel Kit | Setrab oil cooler | 3sx Dual Pass Radiator | Flex-a-lite Fans | RC ported throttle body | Samco radiator hoses | Blitz radiator cap | 3sx engine dress up kit | Krank vent kit | 3sx EGR block-off plates | 3rd Gen big bore lifter | 3sx Underdrive pulley | Gatorback belts | Kevlar timing belt | PTE 680cc injectors | Dejon Tool duel "NO-MAF" intakes | K&N cone filters | Hotwired Denso pump | Copper plugs | Accel wires | HKS Super SQV blow off valve | DR downpipe | Q-TEC 3in cutout | Custom 3in exhaust with Apexi 5in tips | ACT Stage 3 clutch | 3sx poly motor mounts Show: GT Factory lambo doors | Eibach Pro lowering springs | Custom vented hood | Window tint Command Center: Blitz(black light) boost gauge | AEM Wideband Air/Fuel gauge | Blitz full auto turbo timer | 3sx (black and tan) E-brake & shift boot | 3sx short throw shifter | MOMO chrome shift knob | Changed factory lights to blue leds | Smell-good air freshener |
#12 (permalink) |
Damage Control
Even without EDFC you can adjust coilovers softness in under a minute with the turn of a knob on each coilover.
Adjusting height takes more effort. Some people feel the softest setting still isnt soft enough.
Kbizzle [11:25 P.M.]: this is most displeasing |
#13 (permalink) |
The cake is a lie!
One thing to keep in mind is that typically the Japanese coilover systems have a very narrow range of damping adjustment and are meant for one certain spring rate, meaning that you can't usually go to a softer spring without hurting your handling. And since they just don't adjust much, if you don't like the ride they give, oh well, you're stuck with it.
The European school of thought for coilover design is to give a very large adjustment range, meaning that you can actually go from comfort to track-stiff by just turning a few nobs. And you can also use different rate springs without a big negative effect. To see what I mean, find the Sport Compact Car issue from a couple months ago when they tested a bunch of coilovers on S2000s. They show all of the empirical data and the Euro designs almost universally had a lot larger adjustment range.
Atheist and proud of it!
The meaning of life is what it means to you. Thank you to all our armed service men and women! |
#14 (permalink) |
Dru
that's interested about the euro/japanease approach....i'll check into that...
i'm not worried about adjusting heigh easily..once that's set, i'm not going ot mess with it..i'd just like to be able to adjust the dampening easily.... basically i'm not looking to spend a fortune..i just want something that rides as good as stock did in tour mode or better...the intrax springs basically put my car in sport mode all the time...and now sport mode is like granite mode |
#16 (permalink) |
Although this might be out of your price range, it might be worthwhile looking for some JIC's with tender springs. The tender springs will absorb the smaller annoying bumps with ease you'll still have the larger springs to help with handling.
#17 (permalink) | |
Dru
well that sucks..haha..that's pretty much what I was going for. Oh well..maybe things will be better when I move to Florida....PA roads are terrible...it's not so much that it really annoys me...i just sounds so bad for the car every time I hit a bump....and in turn, THAT annoys me....hah |
#18 (permalink) |
July 2003
Well, it actually is possible to find an aftermarket suspension that rides better than stock on tour mode, but you'ld have to try contacting a company like Ohlins for a custom sprung/valved setup. Cost would be approximately $5-$12k.
1994 3000GT VR-4. Hobbies... what are hobbies? Oh, those things people do when they're NOT working on their cars?
