"Sugar water poured into gas tank" - 3000GT/Stealth International Message Center
Auto Insurance
Wheel & Tire Center
Old 04-15-2012, 08:48 PM   #1 (permalink)
cartarded
3kgt1734's Avatar
Drives: 95 3000gt
3kgt1734 is an unknown quantity at this point
Feedback Score: 1 reviews
Default "Sugar water poured into gas tank"
I just bought a 93 base 3000gt. I bought it from a kid who said he had "sugar water poured into the gas tank and that a piece broke off in the motor"
Alright so I bought it because it was freakin cheap and the body was perfect. I have a 3.5 ready to be swapped in. I was just messin around and put a good battery in it and cranked the car, it started and then died. I literally heard it run for like 2 seconds. It immediately died each time. It doesn't sound like the motor is knocking or anything.
Where would you guys start? Drain tank, flush lines, then what?
3kgt1734 is offline   Reply With Quote Quick reply to this message
Old 04-15-2012, 08:57 PM   #2 (permalink)
3krazygt's Avatar
Drives: 92 R/T TT, 95 Spyder
3krazygt Level 13krazygt Level 1
Feedback Score: 59 reviews
Default Re: "Sugar water poured into gas tank"
add new gas to the tank, pull the fuel line from the rail and then just crank the motor and let fuel run through.
Replace the pump
Clean the fuel rail
pull the injectors. Clean them
... thats probably what I would do if someone really did "put sugar water" in my tank.
Although if it was some kid, it probably did break and he just thinks someone is out to get him.
Photo Sharing and Video Hosting at Photobucket
3krazygt is offline   Reply With Quote Quick reply to this message
Old 04-15-2012, 09:12 PM   #3 (permalink)
cartarded
3kgt1734's Avatar
Drives: 95 3000gt
Replace the pump
Clean the fuel rail
You can see where someone pried the fuel door open so something may have happened. What should I use to clean these parts? Just gasoline?
Old 04-15-2012, 09:21 PM   #4 (permalink)
Talk about a shortshifter
Hard AttacK's Avatar
Drives: 91rttt, 95 miata
Hard AttacK Level 1Hard AttacK Level 1
Feedback Score: 22 reviews
Drop the tank, replace fuel filter, clean strainer
Originally Posted by fastnelson View Post
went over 250 one time
Originally Posted by ADiggidoyoF View Post
I took her to carmax for an appraisal and after a half hour of compliments and friendly small talk they offered me a grand total of $300. I then asked to use the bathroom and proceeded to fill the back part of the their toilets with full rolls of tp.
Hard AttacK is online now   Reply With Quote Quick reply to this message
Old 04-15-2012, 09:27 PM   #5 (permalink)
mas
mas's Avatar
Drives: 95 R/T TT
mas is an unknown quantity at this point
Feedback Score: 5 reviews
shoot me the injectors if you want.
take the fuel line off at the fuel filter.
turn KOEOFF
jump power to fuel pump and pump out everything.
replace fuel filter with new one. send me injectors to clean up and flow .
add 18 gallons of new gas.
jump FP wire again with new filter in place.
let the FP run for a hour or two. hook a charger to the car.
Replace the fuel filter again.
1995 RT TT Galaxy white Pearl. 1 intercooler delete. 1 exhaust delete. More fuel
If SHTF, I want to be out of the room before then.
mas is offline   Reply With Quote Quick reply to this message
Old 04-15-2012, 09:30 PM   #6 (permalink)
cartarded
3kgt1734's Avatar
Drives: 95 3000gt
turn KOEOFF
How much do you charge to clean the injectors?
Old 04-15-2012, 10:20 PM   #7 (permalink)
DJ Kontakt's Avatar
Drives: Mad Max GT
DJ Kontakt is an unknown quantity at this point
Feedback Score: 35 reviews
That new sugar is like throwing rocks in to a crank case...
DJ Kontakt is offline   Reply With Quote Quick reply to this message
Old 04-16-2012, 10:07 AM   #8 (permalink)
Track Whore
Phalse's Avatar
Phalse is an unknown quantity at this point
Feedback Score: 27 reviews
I thought this old myth was put to bed long ago. I'd fill it up and run it after doing the usual maint. It would take a rediculous amount of sugar in a tank with a very low fluid level to do any reasonable damage.
Phalse
DSM & 3000GT/ Stealth Veteran
1995 Stealth - Dead
Phalse is offline   Reply With Quote Quick reply to this message
Old 04-17-2012, 10:05 AM   #9 (permalink)
Dream car in the making
Drives: Stealth
gonen2 is an unknown quantity at this point
Feedback Score: 2 reviews
I thought so too. I saw "Myth Buster" prove it does nothing to your car. Although I think the car was carburetor.
gonen2 is offline   Reply With Quote Quick reply to this message
Old 04-17-2012, 11:45 AM   #10 (permalink)
Ancient Spirit Of Evil
kelvinTurbo's Avatar
Drives: Mumra tank
kelvinTurbo is an unknown quantity at this point
actualy I had rock salt poured into my gas tank once, immediately clogged up the system and killed the pump forcing me into my 1st walbro and yes it was a lot of it and it smelled horrible with the gas... taught me a lesson, if you ever sleep with your girl's mom, make sure no one finds out
Ancient spirits of evil, transform this decayed form into Mum-ra!!
I can show you what it's like to lose control...
kelvinTurbo is offline   Reply With Quote Quick reply to this message
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Real Name(First & Last)
(Required/Hidden)
Mailing Address(Street)
(Required/Hidden)
City
(Required/Hidden)
State
(Required/Hidden)
Zip
(Required/Hidden)
Country
(Required/Hidden)
Date of Birth
Month Day Year
Privacy
Log-in
Random Question
