Strange issue with pop ups
Hey all, I just brought home my GTO from the body shop after an accident last year. Only recently I managed to raise the money to fix it. I needed to buy the left side pop up assembly as the original was destroyed. The problem is that now the headlights won't come up. I turn the light switch, the lights turn on but they don't move at all. If i turn them up manually they will go down when i turn the switch off. Also the up/down switch on the right side of the cluster does nothing, and i tried disconnecting the neg terminal with no results. What else can I check? They worked fine just before the accident. Also there's an issue with my door locks, when i lock is fine, but when i unlock both locks unlock/lock rapidly for half a minute give or take. Any ideas? Appreciate any help!
