Old 06-22-2008, 06:28 AM   #1 (permalink)
Drives: allthrottlenobottle
Mint1992vr4 is an unknown quantity at this point
Default Starting issues
Got in my vr-4 yesterday to give it a start. I put the key in, gave it a turn, and not a thing happens. I thought it was the battery and had it charged and tested yesterday. The battery was fine, all of the dash lights come on and all other electrical items work. The engine doesn't even turnover. Any suggestions?
[size="2"]
1992 3000gt vr-4 13,132 original miles
Sports vr-4 chromies
Cars in the garage:
jaguar x-type (Sold)
vw passat 07
Ford Focus (DD)
Eclipse GST
VR-4
Wanted:
97-03 Diamante Infinity Amp (#MR172814)
97-99 DSM GSX rims 17" or Stock Evo Rims
Wanted *3/S Parts*:
Wire harness from the amp and CD changer
Infinity speakers (all)
Mint1992vr4 is offline   Reply With Quote
Old 06-22-2008, 07:45 AM   #2 (permalink)
Default Re: Starting issues
bumpty bump!
Old 06-23-2008, 06:30 AM   #3 (permalink)
To the top!
Old 07-05-2008, 09:57 AM   #4 (permalink)
nihilism5150's Avatar
Drives: '92 Stealth SOHC
nihilism5150 is an unknown quantity at this point
I'm having the same problem. accessories work fine but it just doesn't turn over.
nihilism5150 is offline   Reply With Quote
Old 07-05-2008, 11:28 AM   #5 (permalink)
og
chansigril's Avatar
Drives: 93 stealth rt tt
chansigril Level 1chansigril Level 1
here we go again
click click start
93 stealth r/t tt: mildly modified, 12.4@109
94 stealth r/t na: used to drive, 13.9@100
03 ford focus se: beater
chansigril is online now   Reply With Quote
Old 07-06-2008, 10:33 AM   #6 (permalink)
whats the click click start?
Old 07-06-2008, 11:22 AM   #7 (permalink)
og
chansigril's Avatar
Kinda URGENT - car won't start
Old 07-06-2008, 05:22 PM   #8 (permalink)
it sounds like this will really help but i dont even get a click from the starter. would it still be the same problem? im new with working with cars and i know even less about electrical.
Old 07-06-2008, 05:57 PM   #9 (permalink)
og
chansigril's Avatar
the problem is related to your starting system, possible causes:
1. ignition switch - unlikely.
2. starter solenoid - possible.
3. starter engagement - possible but less likely, no noise.
4. wiring, basically power to starter - probable.
5. anti-theft if so equipped, clutch pedal position switch or other more esoteric cause - unlikely.
thankfully our starting system is fairly basic so the potential causes are limited.
i would recommend fixing the relay issue per the post above, it doesn't take too long and is fairly straightforward. that doesn't work, it's good preventative medicine and you've eliminated it as a potential cause.
Old 07-07-2008, 06:42 PM   #10 (permalink)
the starter doesnt respond at all when i go to start the car. nothing clicks. possibly a bad starter?
