View Poll Results: TD04 vs TD05
TD04 - oohnoo 137 51.70%
TD05 - tfw a-ok 128 48.30%
Voters: 265. You may not vote on this poll
Old 05-19-2008, 06:14 AM   #71 (permalink)
cyber bully
Trader Rating: (14)
green-lantern Level 7green-lantern Level 7green-lantern Level 7green-lantern Level 7green-lantern Level 7green-lantern Level 7green-lantern Level 7green-lantern Level 7green-lantern Level 7green-lantern Level 7green-lantern Level 7
Default Re: The stage is set - TD04 vs TD05 - oohnoo vs tfw a-ok
I am going with the TD05's
this would be great to do at NG!
Old 05-25-2008, 12:50 PM   #72 (permalink)
selling 95 vr4
seta8967's Avatar
Drives: 1995 3000gt VR-4
seta8967 is an unknown quantity at this point
I'm going with the TD04 its a quicker spinning turbo. With both running the same HP the TD04 will spin up and be on top of the TD05 before the TD05 can fully spool up. If it was a TD04 against a high HP TD05 it would be a different story... Every shift means the TD04 will spool up faster and gain more and more. This is why some people prefer N/A because they don't have the disadvantage of the turbo lag or having to wait for it to spool up. personally a 500hp little turbo vs 500hp big turbo vs 500hp N/A. I think the NA would win follow by the little turbo... This is all my idea though and theory...
seta8967 is offline   Reply With Quote
Old 05-25-2008, 01:44 PM   #73 (permalink)
Forest Gump
cbehnken's Avatar
Drives: 1992 Stealth TT
Trader Rating: (42)
cbehnken Level 7cbehnken Level 7cbehnken Level 7cbehnken Level 7cbehnken Level 7cbehnken Level 7cbehnken Level 7cbehnken Level 7cbehnken Level 7
Good enough points, but low displacement high horsepower NA engines are usually peaky and do not have a wide power band.
Most of the time a good turbo setup will have a very strong midrange compared to an NA setup.
The NAs have to run heads and cam to make the high horsepower than make them unfriendly at low and mid RPMs.
Power: DSM 13G/DR650 Combo, DSM 450 cc bluetops, SAFC I, K&N, Ebay Downpipe, ATR Dual Catback,
no cats, DN Y-Pipe, HKS SSQV, HKS EVC 5 at 14.5PSI, Walbro 255 with AN Bulkhead 8.07 @ 85.55 1/8th mile 1.84 60FT
Suspension: KYB GR-2 - Tein S-Techs, Crossdrilled/slotted rotors, AWS Delete
Drivetrain: RPS Street Max, M.W. 300m O/S, Seattle F&R Poly Mounts
Etc: Roller Bearing Short Shifter Smokinvr-4 Corner box, 10" Rockford Fosgate Punch sub, Eclipse Headunit
Leatherseats.com Charcoal/Dove Grey Interior, 99 front end/lights/wing/sideskirts/doorcaps
Maintenance New VSS, all 60K stuff, new 1st,2nd, 3rd syncro, trans seals, oil pump, rod and main bearings.
Mobile 1 10w40, Redline MTL in trans, 85w90 Coastal GL5 in transfer case and rear
cbehnken is online now   Reply With Quote
Old 05-25-2008, 02:10 PM   #74 (permalink)
Used to have a mitsu...
My_Car_Goes_Rar's Avatar
Drives: Jeep TJ
My_Car_Goes_Rar Level 7My_Car_Goes_Rar Level 7My_Car_Goes_Rar Level 7My_Car_Goes_Rar Level 7My_Car_Goes_Rar Level 7My_Car_Goes_Rar Level 7My_Car_Goes_Rar Level 7My_Car_Goes_Rar Level 7My_Car_Goes_Rar Level 7My_Car_Goes_Rar Level 7
I would just like to throw in that both of you make me really sad when I look at your wheels... they are TOO baller.
GL guys.
2000 Jeep TJ - No it's not a 3S... but at least I don't have to worry about speed bumps ruining my bumper anymore.
Originally Posted by Doomtech View Post
CB the point is that car is NA not turbo with 721whp, unless I am missing something that says you can go well over 200whp NA... which seemed to be the issue at that point in the conversation. Once again answer the question asked, you were not asked if the OP should go turbo or even if he should go just exhaust and NOS, he asked specifically what the upgrades he listed would do to his car and you guys all began to reply with the stock answer of "should have gone VR4" . And I NEVER SAID HE COULD GET 700FWHP on BPU, I was showing an NA car that is well over the 200whp barrier you seem to think is so hard to reach. We did not even begin discussing traction issues or anything like that. Yet again you seem to think I don't know a thing about my car and you could not be more wrong. If I could neg rep you for "reading comprehension" I would because you obviously only see and read what you want to.
My_Car_Goes_Rar is offline   Reply With Quote
Old 05-25-2008, 02:41 PM   #75 (permalink)
selling 95 vr4
seta8967's Avatar
All I can say is your obviously more experienced than I. You also make me very jealous with that color car and interior.
Old 05-25-2008, 02:56 PM   #76 (permalink)
Paid Member
jba3's Avatar
Drives: mitsu's stock up ^_^
Trader Rating: (15)
jba3 Level 7jba3 Level 7jba3 Level 7jba3 Level 7jba3 Level 7jba3 Level 7jba3 Level 7jba3 Level 7
In for results, and to enjoy the smack talk.
If my posts have been helpful or informative, or even entertaining, rep is appreciated.
Old 05-25-2008, 03:36 PM   #77 (permalink)
Forest Gump
cbehnken's Avatar
Trader Rating: (42)
Don't be jealous, you make me jealous having a real 2nd gen
I don't know a ton, but from what I've seen really hot NA motors are lucky to have 2 or 3 thosand RPM power bands. OTOH a good turbo motor can have a nice 4 thousand RPM power band fairly easily.
Exceptions to this always...
Old 05-25-2008, 08:26 PM   #78 (permalink)
helmvr4's Avatar
Drives: 93 vr4,turbo mustang
helmvr4 Level 1helmvr4 Level 1
Tdo5 All The Way!!!!!!!!!!!!
dr stage 3 heads, steet cams ,cam gears ,evo 3's 660's street beast 20 lbs w meth
a
helmvr4 is offline   Reply With Quote
Old 05-26-2008, 05:36 AM   #79 (permalink)
SOHC you in the FACE
Ondontii's Avatar
Ondontii level 6Ondontii level 6Ondontii level 6Ondontii level 6Ondontii level 6Ondontii level 6
Why do people think low boost threshold is going to make a difference at the track? We aren't having a "lug it from low rpms" competition.
This isn't a 5mph roll race, and if it was, a little 2 steppin would ruin that advantage too.
Brent
1992 Duster -12.7@114 - 14psi boost -13.9@107.4 - 5psi - 6g72 3.13L "built" SOHC, Precision T67 P-trim, Tial 38mm open dump, 3" downpipe, 20x12x3" evo style intercooler, 7:1 compression, balanced, shot peened rods, heavily ported heads (+40% on flowbench), Ferrea Competition Plus +2 +1 stainless valves, Nielson Vintage 278 duration custom turbo cams, RPW Cam gears, Custom Ram Style short runner intake manifold, Walbro 255hp, 6*47# injectors, +0.096" Forged Venolias, Total Seal chrome gapless top rings, Fidandza Flywheel, Clutchnet 3 puck solid hub, OBX Helical LSD, Zeitronix wideband/EGT/Boost sensors, 100watt DevilsOwn Meth Kit.
1994 Spirit - 13.987@101.89 - 5psi- 6g72 SOHC, K27 Turbo
Ondontii is offline   Reply With Quote
Old 05-26-2008, 05:48 AM   #80 (permalink)
shadow334485's Avatar
Drives: 91 VR4
Trader Rating: (7)
shadow334485 Level 7shadow334485 Level 7shadow334485 Level 7shadow334485 Level 7shadow334485 Level 7shadow334485 Level 7shadow334485 Level 7
I dont even know but I just enjoy the smack talk
X2 coming this fall
shadow334485 is offline   Reply With Quote
