| View Poll Results: TD04 vs TD05 | |||
| TD04 - oohnoo |
137 | 51.70% |
| TD05 - tfw a-ok |
128 | 48.30% |
| Voters: 265. You may not vote on this poll | |||
LinkBack | Thread Tools |
#61 (permalink) |
SOHC you in the FACE
Is he going to be taking advantage of all the power in the 6500-8000 rpms that are not on his dyno sheet?
Brent
1992 Duster -12.7@114 - 14psi boost -13.9@107.4 - 5psi - 6g72 3.13L "built" SOHC, Precision T67 P-trim, Tial 38mm open dump, 3" downpipe, 20x12x3" evo style intercooler, 7:1 compression, balanced, shot peened rods, heavily ported heads (+40% on flowbench), Ferrea Competition Plus +2 +1 stainless valves, Nielson Vintage 278 duration custom turbo cams, RPW Cam gears, Custom Ram Style short runner intake manifold, Walbro 255hp, 6*47# injectors, +0.096" Forged Venolias, Total Seal chrome gapless top rings, Fidandza Flywheel, Clutchnet 3 puck solid hub, OBX Helical LSD, Zeitronix wideband/EGT/Boost sensors, 100watt DevilsOwn Meth Kit. 1994 Spirit - 13.987@101.89 - 5psi- 6g72 SOHC, K27 Turbo ![]() |
#67 (permalink) | |
Hammer
One with td04 and one with td05 to see which turbo held the advantage at an equal whp. Everyone knows td05's can make more power than td04's. Actually to really make this test work both cars need to weigh the same and we need the same driver to run both cars. But that is just wishfull thinking. Have fun guys! Hey maybe Bob and Tommy can switch cars for a second race? Just a wild idea. |
#68 (permalink) | |
July 2003
I thought the idea was to see what the differently setup cars could do on a street tune with pump gas? To see how much of a difference there was between the two setups considering Bob's dyno has a TD04 coming so close to the TD05 setups. If this is the case, then I'd say the retune should safely maximize the potential of each setup to show the reality of each setup's potential. If anyone wanted to race 2 cars of odentical power and dentical weight, then what's the point except to see who's a better driver? I fully concur with the guys who've said the cars should weigh approximately the same. What I want to see is what each car/setup is capable of when tuned to its street potential. Will the TD04's faster spool make up for the power deficit? Will adding meth to the TD04 setup produce the same power as the e16g's on pure pump? etc. Max
1994 3000GT VR-4. Hobbies... what are hobbies? Oh, those things people do when they're NOT working on their cars?
#69 (permalink) | |
Sleeper VR-4
#70 (permalink) | |
Bingo!
Oh and both cars are stock weight, no reduction. Can probably add a few pounds as both have amps/subs, etc. Quote:
----------------[2007 Ride of the Year
![]() "Stroke" her I did. Retired - TD04 WRX19t's = 513awhp @ 18psi on PUMP ![]() |
