Old 03-26-2008, 05:38 PM   #81 (permalink)
moffman93''s Avatar
Drives: 91 vr-4
Trader Rating: (6)
moffman93' Level 2moffman93' Level 2moffman93' Level 2
Default Re: Spun Bearing Causes - Please Read!
Originally Posted by DCIV View Post
rush now, pay later....
Coop
Ha I fixed it. I mean "im in no rush"
1993 3000gt base - SOLD
1991 3000gt Vr-4(white) - purchased 12-23, given back 4 days later lol.
1991 3000gt vr-4(red) - purchased 12-28
Performance mods : K&N air filter, fully built engine with ross forged rods and pistons, hks ssqv bov, homemade MBC, aluminum y-pipe, 25spline output shaft, steel crank, lightly ported heads, rotora drilled and slotted rotors, gutted main cat, SPEC Stage II.
Audio : Sony CDX M8815x headunit, Alpine type-s 6 1/2" door panel speakers, Alpine type-s 6x9" rear speakers.
Originally Posted by eljefefx View Post
I've pretty much made up a list in my head of who here is more useless than two midgets at a giraffe farm.
moffman93' is offline   Reply With Quote
Old 03-26-2008, 11:34 PM   #82 (permalink)
One day at a time.
RebelExtrm02's Avatar
Drives: 95 3000GT SL MTX
RebelExtrm02 is an unknown quantity at this point
How big of a job is it to remove the pan? I looked under there and it appears that I just need to remove the crossmember, the large sheld looking things on each side with the big bolts in them, then the bolts all around the pan itself. Is this correct or is there more to it?
Also, How hard is it to replace the pickup tube and screen as well? Anyone have a roundabout price for these parts as well?
Brand new N/A Adjustable Control Arms for sale.
Sell me your 18" wheels!
1995 Mitsubishi 3000GT SL 5-Speed *60k Complete* DD
1989 Dodge Daytona ES T-Top 5-Speed *sold*
RebelExtrm02 is offline   Reply With Quote
Old 03-26-2008, 11:44 PM   #83 (permalink)
Mr. Cheese
92RT-TT's Avatar
Drives: 92 RT/TT & 92 RT/TT
Trader Rating: (15)
92RT-TT Level 792RT-TT Level 792RT-TT Level 792RT-TT Level 792RT-TT Level 792RT-TT Level 792RT-TT Level 792RT-TT Level 792RT-TT Level 792RT-TT Level 792RT-TT Level 7
Default Re: Attention Anyone Who Bought A Pampena Engine...
Originally Posted by 91vr4n00maxima View Post
i have only seen 1 3s with an original oil pan that wasnt dented. my 97. never had the timing belt changed. im sure if it had been the pan would be dented.
good info... I just checked my pan in my 92 TT. No dent and still looks like new so that was a relief.. course with 60k it should still look good lol. Ray thanks for the info! I'm sure this will save more than one person some headaches
1992 Dodge Stealth RT-Twin Turbo
64,000 miles, Stored Winters, AEM Tru-Boost, Greddy Type S BOV, DNP Hardpipes, Palm MMCD, Tein S-Tech Springs, Brembo Rotors, MSD Wires, K&N FIPK, EGR Delete, Vacuum Reduction, Cianci 3 Gauge A-Pillar, 5zigen FN01R-C 18x9.5's wrapped in BFG KDW 265-35-18's. 13% Tint, 12 Disc CD changer, 3 1/2 inch Custom Exhaust.
DD-Pearl White 92 Stealth TT-85,000 on it, BPU 270 awhp, 307 awtq on 8-23-08
92RT-TT is offline   Reply With Quote
Old 03-27-2008, 03:27 AM   #84 (permalink)
never a dull moment
DCIV's Avatar
Drives: 92 VR4
Trader Rating: (12)
DCIV Level 7DCIV Level 7DCIV Level 7DCIV Level 7DCIV Level 7DCIV Level 7DCIV Level 7DCIV Level 7DCIV Level 7
Drop the down pipe, starter, TC, and easyest if you drop that crossmember (its just 6 bolts. Then your oil return lines have to come be lossened, then pan. Its really not that bad.
Coop
To many mods to list.
Old 03-27-2008, 11:47 AM   #85 (permalink)
moffman93''s Avatar
Drives: 91 vr-4
Trader Rating: (6)
Nope not that bad just kind of a PITA to clean the pan and make sure you get all the gasket resedue off. If its stock and has never came off before it should be easier. I believe the pickup tube is ~=30 bucks or so from the dealer.
Old 04-25-2008, 04:54 PM   #86 (permalink)
Drives: 91 Stealth tt
Joey_ld@hotmail.com Negative 2
As long as you already have the car in the air supported by stands you can use a jack on the engines oil pan just to support the engine from stooping down and destroying the other mounts. But always stick some rags on the jack to distribute the weight evently.
Joey_ld@hotmail.com is offline   Reply With Quote
Old 04-25-2008, 05:53 PM   #87 (permalink)
oohnoo's Avatar
Trader Rating: (146)
oohnoo Level 7oohnoo Level 7oohnoo Level 7oohnoo Level 7oohnoo Level 7oohnoo Level 7oohnoo Level 7oohnoo Level 7oohnoo Level 7oohnoo Level 7oohnoo Level 7
WTF! Nooooooooooo
oohnoo is offline   Reply With Quote
Old 04-25-2008, 05:56 PM   #88 (permalink)
Praise RaptorJesus!
sammage's Avatar
Drives: bugeye wagon
Trader Rating: (25)
sammage level 6sammage level 6sammage level 6sammage level 6sammage level 6sammage level 6
Good luck with that!
Originally Posted by Predacon View Post
PS. Everyone be nice in this thread, mean people suck!!!!
sammage is offline   Reply With Quote
Old 04-25-2008, 06:47 PM   #89 (permalink)
Someone else's mistakes
venetrex's Avatar
Drives: 1992 3000GT VR4
venetrex is an unknown quantity at this point
I supported my engine by the oil pan when I did my 120K, however I had a piece of 3/4 plywood under the entire flatside of the pan, it was okay, real pain because I had the tranny out too.
DR650R's, supra fuel pump hotwired and aem fuel pressure regulator with bob beck adapter, addicted performance front mount intercooler and piping, ceramin coated inside and out, ebay knockoff DN headers, cusom stillen downpipe, Borla catback, precision turbo 550cc injectors, RPS MAX series clutch, street disc, and RPS segmented aluminum flywheel, 3sx braided stainless turbo feed and return lines, 3sx braided clutch line, fidanza adjustable cam gears, arc2 fuel controller with ford MAS, greddy E-manage blue for fine tuning and timind control, Greddy profec E-01 for boost control, AEM widemand O2, arm-1 narrow band o2, autometer boost gauge, HKS ssqv with custom recirc adapter, 3sx fuel rail adapter.
venetrex is offline   Reply With Quote
Old 04-25-2008, 07:26 PM   #90 (permalink)
doing the impossible
lDoomZdaYl's Avatar
Drives: Her Crazy
lDoomZdaYl level 6lDoomZdaYl level 6lDoomZdaYl level 6lDoomZdaYl level 6lDoomZdaYl level 6lDoomZdaYl level 6
great info
lDoomZdaYl is offline   Reply With Quote
