Old 03-17-2008, 07:36 PM   #71 (permalink)
Cant get there from here!
speedy25's Avatar
Drives: Various Japanese
Default Re: Spun Bearing Causes - Please Read!
Interesting......
Some months back I hypothesized that in a spun bearing thread that a caved-in oil pan might be the problem. Also a suprise was the pics in that post that showed how close the clearance is, and then Ray filling in the final clue that the pick-up gets damaged enough to restrict oil flow. (Thanks Toni for posting that thread!)
I cant see how using the bottom of the pan to lift the engine while doing 60k service could ever crush the pan, but I CAN believe it could be possible using the pan to lift the car. But I'm betting the real culprit is curbs and other nasty things people run over that they shouldnt.
Heres to a giant reduction in engine failures from CAREFUL inspections of parts as they get bolted up!
-SP
One of 789
Old 03-19-2008, 03:43 PM   #72 (permalink)
Foolish
Mikes95RT Level 1Mikes95RT Level 1
My oil pan had a serious crease in it. It was like this for about 60K. I knew it was there but my oil pressure was amazing so I didn't care. When I finally decided to rebuild and found a broken ring land I paid extra attention to the bearings because of the crease in the pan.The bearings looked great for having 125K on the car.Once I looked at the screen I noticed that the crease had pushed the screen all the way in but it quickly fell away.Basically the restriction was a thin line through the center of the screen and the screen looked like a ^ with the restriction being the peak.So I guess it was smashed in but allowed enough flow to enter from the sides it was no problem.
Anyway with all of the cash I have spent for a full rebuild and balancing you can bet that I replaced the screen/pick up.I hope to hear her run this week.
Mike Sullivan 95 Stealth FWD TT conversion 10:1 compression@12 PSI
Go...
13c turbos,450cc injectors,
TT pump,3SX braided return line
TurboXS type S open B.O.V.
ATR down pipe
Stuff...
K&N filter,unorthodox U.D.P., Optima red top,
ET performance krank vents
3SX lower poly mounts
Polished y pipe.
cool...
Stock intercoolers,Alcohol injection thanks to turbomirage.com
Tranny...
Auto to 5spd conversion to AWD 5spd/fwd
SPEC Stage 2 AWD clutch 3SX braided clutch line.
Wheels...
Exel Mimi
Fulda extremo 245-40-17
Intrax springs
Control...
Apexi SAFC 2,TT ECU and harness.
TurboXS M.B.C.
M.S.D. Knock alert
Gauges...Autometer...
E.G.T.,Boost,Air/Fuel ratio meter.
13.599@112 at 13psi....traps high enough for 12.3's with the traction for mid 13's..gotta love FWD
All aftermarket parts happily purchased from 3SX performance.com
Turbo conversion parts happily purchased from Mitsuspecialties.
Mikes95RT is offline   Reply With Quote
Old 03-25-2008, 07:17 PM   #73 (permalink)
soaking it up
nawz8r's Avatar
Drives: '91TT '02Avalanche
Trader Rating: (6)
nawz8r Level 1nawz8r Level 1
I bought a '91 TT last September...checked the pan - dented, removed it and pounded it out. Thanks for the heads-up Ray, certainly makes sense as a cause!
nawz8r is offline   Reply With Quote
Old 03-26-2008, 09:00 AM   #74 (permalink)
whaddsyaname
tomownzjoo's Avatar
Drives: 93 3000gt VR4
tomownzjoo is an unknown quantity at this point
Ive been hearing some things... im not trying to start an argument... about the oil pan is supposed to be creased a little inward ( NOT all the way dented in) because that rise in the oil pan pushes sludge to the sides assuring you get good clean oil in your sump.
EDIT: like i said im not saying this is true, but this does have some validity as ive heard it from a few people.
EVOIII16G Kit - IPS, 750 fmic kit - IPS, 780cc inj, stg 2 cams, stg 3 heads, Spec stage 2.5, .30 over, weisco pistons, shotpeened rods, clevite bearings
tomownzjoo is offline   Reply With Quote
Old 03-26-2008, 09:39 AM   #75 (permalink)
never a dull moment
DCIV's Avatar
Drives: 92 VR4
Trader Rating: (12)
DCIV level 6DCIV level 6DCIV level 6DCIV level 6DCIV level 6DCIV level 6
its not true.
Coop
To many mods to list.
Old 03-26-2008, 09:48 AM   #76 (permalink)
Idaho's Avatar
Idaho is an unknown quantity at this point
wrong. there is a thin stamped circular crease in the pan that does go upward, but the sump itself lies lower, or at the bottom of the pan.
Idaho is offline   Reply With Quote
Old 03-26-2008, 10:32 AM   #77 (permalink)
Warning: I'm an asshole
SkortchGT's Avatar
Drives: 1992 3000GT VR4
Trader Rating: (10)
SkortchGT Level 7SkortchGT Level 7SkortchGT Level 7SkortchGT Level 7SkortchGT Level 7SkortchGT Level 7SkortchGT Level 7SkortchGT Level 7
Whoever you heard that from is a complete toolbag.
1992 3000GT VR4
--Completely rebuilt 5/06-4/07. Everything new. For a list see: http://www.3si.org/forum/showthread.php?t=372579
--First time on dyno: 364AWHP@16psi with a 10.3AFR (now tuned at 11.4-11.6 with timing control, time for another dyno run soon)
--Mods: DR Stage I heads, 3rd gen lifters, TD04L 13Gs, DSM SMICs, PTE 550s, Apexi SAFC, Apexi SITC, Walbro FP, IPO hotwire, Robbeck adapter & AEM FPR, 3SX underhood fuel gauge, 3SX fuel rail loop, DN Y-pipe, HKS SSQ BOV, K&N FIPK, Greddy Profec Spec S, AEM WB02, Autometer C2 boost, egt, oil press & water temp gauges, MSD wires, NGK BCP7ES's, TEIN FLEX coilovers, Maximal performance control arms, solid engine mounts & powdercoating, RPS Streetmax Clutch, RPS Flywheel, NBT Tranny (cryotreated OS, shift forks & rails), updated speedo gear, solid shifter bushings, full 2nd gen brake conversion, 3SX SS brake & clutch lines, Carbotech Panther+ pads in the front & Bob Cats in the rear, 3SX clutch vac delete, EGR delete, vac reduction, Ebay DP, gutted pre cats, Bronze FN01RCs 5Zigen 18x8.5 + 30 offset, Pirelli P-Zeros, engine dress up kit, Bigtyla ground wire kit.
--Daily Driver: 98 Malibu, 4cyl, auto
SkortchGT is offline   Reply With Quote
Old 03-26-2008, 10:38 AM   #78 (permalink)
Dragon slayer
3000gt1999's Avatar
Drives: 91VR4/99 base/92 S13
3000gt1999 is an unknown quantity at this point
Just found this thread.. and got me curious. So i went to the basement and reached under the car and sure enough, the center of the pan was dented in. Oil pressure is good so i'm not real worried, but will be fixing the pan before running it hard again.
3000gt1999 is offline   Reply With Quote
Old 03-26-2008, 04:21 PM   #79 (permalink)
moffman93''s Avatar
Drives: 91 vr-4
Trader Rating: (6)
moffman93' Level 1moffman93' Level 1
Originally Posted by ray pampena View Post
hey moffman, didnt you dent your own oil pan working on your car behind the shop? lol
Thats because the jacks holding the car up sunk into the blacktop a solid inch and a half while the floor jack holding the engine up stayed up butting ALOT more stress on the pan then I intended to. I don't think its dented enough to touch the pickup you cant even tell its dented unless you look at it at an angle. Look in the back of steves shop, the marks are still there Either way when I do fix it, it will get a new pickup just incase. Im in no rush though, its been down for the last 4 months anyhow.
1993 3000gt base - SOLD
1991 3000gt Vr-4(white) - purchased 12-23, given back 4 days later lol.
1991 3000gt vr-4(red) - purchased 12-28
Performance mods : K&N air filter, fully built engine with ross forged rods and pistons, hks ssqv bov, homemade MBC, aluminum y-pipe, 25spline output shaft, steel crank, lightly ported heads, rotora drilled and slotted rotors, gutted main cat, SPEC Stage II.
Audio : Sony CDX M8815x headunit, Alpine type-s 6 1/2" door panel speakers, Alpine type-s 6x9" rear speakers.
Originally Posted by eljefefx View Post
I've pretty much made up a list in my head of who here is more useless than two midgets at a giraffe farm.
moffman93' is offline   Reply With Quote
Old 03-26-2008, 05:16 PM   #80 (permalink)
never a dull moment
DCIV's Avatar
Drives: 92 VR4
Trader Rating: (12)
rush now, pay later....
Coop
