Old 03-12-2008, 12:04 AM   #21 (permalink)
jfdr6911's Avatar
Drives: 1996 3000GT VR-4
jfdr6911 is an unknown quantity at this point
Default Re: Attention Anyone Who Bought A Pampena Engine...
a good friend of mine makes a bigger oil pan he said the heads on our engines are too big for our oil pan, apparently the heads take up most of the oil leaving next to nothing for the block. Should i check for dents on this or does the bigger size negate the problem. I guess i am also a bit confused is this an exterior dent from a hit or is this something that can get dented upon installation. sorry to be a noobee
-Daniel: 1996 GT-368SX Powerd3000GT VR-4
jfdr6911 is offline   Reply With Quote
Old 03-12-2008, 06:39 AM   #22 (permalink)
3S Motorsports
Drives: 95 VR4
WidowMaker Level 1WidowMaker Level 1
an undented stock pan is just fine. Unless you are installing an oil pan with a mini sledge hammer, it should not be dented upon install. Usually this happens when people don't know where the jack points are and simply use the oil pan to jack the car up.
3S Motorsports Is Open For Business
(631) 676-2448
Running the First Pampena 3.5L Stroker
http://www.3smotors.com
-Steve
WidowMaker is offline   Reply With Quote
Old 03-12-2008, 06:47 AM   #23 (permalink)
no speed limits here
BLACK94TT's Avatar
Drives: A109E
Trader Rating: (20)
BLACK94TT is an unknown quantity at this point
The dent is typically caused while a 60K is being done. A floor jack is placed under the pan to support the engine when the top motor mount is removed. I bet others have even used that point to jack the car.
The manual shows the specific points to raise and place jack stands.
Steve
BLACK94TT is offline   Reply With Quote
Old 03-12-2008, 06:52 AM   #24 (permalink)
oohnoo's Avatar
Trader Rating: (128)
oohnoo Level 5oohnoo Level 5oohnoo Level 5oohnoo Level 5oohnoo Level 5oohnoo Level 5
I always use the AC bracket for supporting the motor when removing the driver side mount. A short piece of a 2x4 and a bottle jack does the job.
oohnoo is offline   Reply With Quote
Old 03-12-2008, 07:25 AM   #25 (permalink)
Racing
Barefoot's Avatar
Drives: 92R/T - converted ;)
Trader Rating: (31)
Barefoot Level 1Barefoot Level 1
Glad I always use an engine hoist to do a 60k service.. if needed.. Too bad even that is not needed with solid motor mounts
92 Dodge Stealth R/T AWD/TT (TD05) converted ( 11.894 @ 120.56 - 18 psi -> Video )
Twin TD05H EvoIII 16G's - Garrett FMIC - PTE 680cc - IPO Propane Injection - Maftpro - SouthBend DXD-F - PST CFDS - Northbend OS - Kaaz LSD - Cianci Victory Hood - Cianci Novara Bumper - Forged Internals 1mm over - and MUCH more..
Barefoot is offline   Reply With Quote
Old 03-12-2008, 09:19 AM   #26 (permalink)
Sleeper VR-4
tfw a-ok's Avatar
Drives: Benz, 1996 VR4
Trader Rating: (16)
tfw a-ok Level 1tfw a-ok Level 1
If you have a bottle of jack, envite me over, I'll help the next time.
Originally Posted by DomGT View Post
For some reason I idolize Tommy Williams. Maybe it's his perfect example of a 3000GT. I haven't been on the board in about a month, can somebody fill me in?
I have a new cellphone number, had to change it. 516-491-9004, call anytime for random 3/S funfacts.
tfw a-ok is offline   Reply With Quote
Old 03-12-2008, 10:33 AM   #27 (permalink)
Drives: allthrottlenobottle
Mint1992vr4 is an unknown quantity at this point
Do DSMs have similar problems with oil pans?
[size="2"]
1992 3000gt vr-4 13,132 original miles
Sports vr-4 chromies
Cars in the garage:
jaguar x-type (Sold)
vw passat 07
Ford Focus (DD)
Eclipse GST
VR-4
Wanted:
97-03 Diamante Infinity Amp (#MR172814)
97-99 DSM GSX rims 17" or Stock Evo Rims
Wanted *3/S Parts*:
Wire harness from the amp and CD changer
Infinity speakers (all)
Mint1992vr4 is offline   Reply With Quote
Old 03-12-2008, 10:44 AM   #28 (permalink)
BLACK94TT's Avatar
Drives: A109E
Trader Rating: (20)
Old 03-12-2008, 11:16 AM   #29 (permalink)
Oh SNAP!!!
mywetdream's Avatar
Drives: 94 TT, 69 427 vette
Trader Rating: (19)
mywetdream Level 1mywetdream Level 1
Originally Posted by 91vr4n00maxima View Post
i have only seen 1 3s with an original oil pan that wasnt dented. my 97. never had the timing belt changed. im sure if it had been the pan would be dented.
my car has the orginal oil pan...and its almost in prefect shape.
If you feel I have answered your question..leave me some rep...thanks
**1ST place RMG 07 best engine**
Like the snake the BITE must be felt and not seen, goin super, until then super slow want some!!!
1st car with the Enkei RZ-5 18''x8.5''
*534x306*
1994 Dodge Stealth R/T TT~Pearl Yellow
mywetdream is offline   Reply With Quote
Old 03-12-2008, 11:20 AM   #30 (permalink)
I'm a dude.
Toni's Avatar
Drives: 13geed 92 rt tt
Trader Rating: (44)
Toni Level 7Toni Level 7Toni Level 7Toni Level 7Toni Level 7Toni Level 7Toni Level 7
Edit: Guilty for not searching
Here is a link to a cutaway of an oil pan
Pulling a Dent From the Oil Pan
My site, tons of pics/faqs(Added LED faq!)
DIY LED Kit for Sale
Speed Factor 2nd place best interior modified
'92 pearl white stealth Rt TT: Mitsu 13gs, Black Racing pro n1s, LC1/LM1 logging (rpm, tps, map, dual egt), RPS street disc/fly,255 Walbro, high flow filter, -6an from tank, AFPR with RobBeck adapter, Apexi el2 5 gauges, maximalperformance tcase bracket/adjustable arms/powdercoating, Tein S-Tech, Greddy Type S bov, Custom exhaust, poly motor mounts, short shifter, led interior.
'06 ninja 500r
'08 vw rabbit
Toni is online now   Reply With Quote
