Old 03-11-2008, 08:08 PM   #11 (permalink)
broke joke
zba857's Avatar
Drives: 6spd 92'
zba857 is an unknown quantity at this point
Default Re: Attention Anyone Who Bought A Pampena Engine...
Good info to keep fresh on the boards. Check your pans people. Thanks Ray.
92' firestorm VR-4 - complete 96' JDM drivetrain - 92' electronics/sensors - UR cam gears, flywheel - DNP pipes - Stillen intake, rotors - 3sx downpipe, steel braided lines, subframe/diff bushings, control arms, plennum spacer - Tein s - denso IK24 - Apex'i AVC-r - MP solid mounts - Spec 3 - Vacc reduction
Deleted - ALL emissions, AA, antenna, rear wiper, front washer bottle, batt relocate, 4WS
zba857 is online now   Reply With Quote
Old 03-11-2008, 08:11 PM   #12 (permalink)
SOHC Power!!!
SOHC3000GT's Avatar
Drives: Like a nut job......
Trader Rating: (91)
SOHC3000GT Level 4SOHC3000GT Level 4SOHC3000GT Level 4SOHC3000GT Level 4SOHC3000GT Level 4
Very good info! I better check that 196K mile oil pan on my engine...
'93 Green 3000GT - Back on the road!!!
Fidanza 2.1 cltuch / Fidanza flywheel / 3SX ss clutch line / 3SX crank pulley / Lethal_VR4 manual steering rack / TT radiator / BigTyla ground wires / ebay intake / '99 lifters / TT fuel pump / Maximal solid motor mounts / 3SX long headers / TT race pipe / TT cat-back / KSport coilovers / Maximal rear toe & camber arms /
SOHC3000GT is offline   Reply With Quote
Old 03-11-2008, 08:14 PM   #13 (permalink)
SerebReal's Avatar
Drives: '95 VR4
SerebReal is an unknown quantity at this point
Should the oil pan be totally flat on the bottom? Mine has a circle in the middle that looks like it is raised up slightly...
SerebReal is offline   Reply With Quote
Old 03-11-2008, 08:25 PM   #14 (permalink)
HLxDrummer's Avatar
Drives: 3000GT, '71 Mustang
HLxDrummer Level 1HLxDrummer Level 1
I never knew this! I thought it was still under investigation as to why these engines spin bearings.
Definitely nice to know, and mine is dented like SerebReal's (circular). Looks sort of like it was supposed to be like that
I'll have to check it out, thanks!
1994 3000GT SL - Old Daily Driver Being Sold Once VR4 is in Action
Go: 3SX Downpipe with Custom DP Back Exhaust, K&N Filter
Show: 3SX Clear Corners, New Custom Paint
1993 VR4 with 150K miles - Daily Driver/Weekend Warrior/Sole Method of Transportation Hopefully on the road soon!
Go: eBay Tanabe Concept G Blue Replica TBE, HKS SSQV, Wastegate Boost
Monitoring/Maintenance: 120K with oil pump and main/rod bearings, MSD 8.5MM wires, NGK Platinum plugs, Palm M100 with MMCD, Redline/Castrol Fluids, New ECU, Lowes Pressure Tester
Show: '99 Garnish, Alan's Snake Eyes, Stealthy Wiper Mod
HLxDrummer is offline   Reply With Quote
Old 03-11-2008, 08:28 PM   #15 (permalink)
ver. 3
VR-4ever's Avatar
Trader Rating: (12)
VR-4ever Level 4VR-4ever Level 4VR-4ever Level 4VR-4ever Level 4VR-4ever Level 4
The circle in the middle of the bottom part of the oil pan should not be raised up at all. It should stick out downwards evenly all around with no dents in it.
We can build it.
VR-4ever is offline   Reply With Quote
Old 03-11-2008, 08:37 PM   #16 (permalink)
My92Stealth's Avatar
Drives: 91RT/TT,92Base
Trader Rating: (34)
My92Stealth Level 1My92Stealth Level 1
Good reminder. Im happy to say that I just put a new one on my TT. Old one was semi dented, I figured I'm doing tons of work town there I may as well. Luckily nothing with the pickup was busted up.
1991 RT/TT Pearl White/Porn Red 15g's + supporting, other mods. 92 Stealth Base DD.
My92Stealth is offline   Reply With Quote
Old 03-11-2008, 08:44 PM   #17 (permalink)
RollinSixties3000's Avatar
Drives: 3000gt base model
RollinSixties3000 is an unknown quantity at this point
Dude i so wish you would have told me a lil sooner man. Blew my engine in my '94. High revin and Bam!
RollinSixties3000 is offline   Reply With Quote
Old 03-11-2008, 08:51 PM   #18 (permalink)
I'm a dude.
Toni's Avatar
Drives: 13geed 92 rt tt
Toni Level 7Toni Level 7Toni Level 7Toni Level 7Toni Level 7Toni Level 7Toni Level 7
I got my car with a dented pan
found low oil pressure
out of spec pump
worn rod/bearings
I undented it but the damage was done already.
My site, tons of pics/faqs(Added LED faq!)
DIY LED Kit for Sale
Speed Factor 2nd place best interior modified
'92 pearl white stealth Rt TT: Mitsu 13gs, Black Racing pro n1s, LC1/LM1 logging (rpm, tps, map, dual egt), RPS street disc/fly,255 Walbro, high flow filter, -6an from tank, AFPR with RobBeck adapter, Apexi el2 5 gauges, maximalperformance tcase bracket/adjustable arms/powdercoating, Tein S-Tech, Greddy Type S bov, Custom exhaust, poly motor mounts, short shifter, led interior.
'06 ninja 500r
'08 vw rabbit
Toni is offline   Reply With Quote
Old 03-11-2008, 09:11 PM   #19 (permalink)
TEXAS!! FIGHT!!
AdamVR4's Avatar
Drives: NoCar XCase Test Car
Trader Rating: (22)
AdamVR4 Level 7AdamVR4 Level 7AdamVR4 Level 7AdamVR4 Level 7AdamVR4 Level 7AdamVR4 Level 7AdamVR4 Level 7
Yup, oil pans in good condition are few and far between.
Until I fixed all of them in central Texas
PEARL WHITE '93 VR-4 // Under Construction. Looking forward to lighting up the drag radials
E16G's: 10.573 @ 135.01
(Trevor owns me )
E16G's: 11.28 @ 124.7
(Pure pump gas ET record )
14B's: 11.10 @ 127.3
(AWD 14B ET record. Take THAT, Trev! )
9B's: 12.78 @ 107.1
Still clinging to my spot in the top 10:
DynamicRacing: US 3S Top 10 Fastest List
AdamVR4 is offline   Reply With Quote
Old 03-11-2008, 11:20 PM   #20 (permalink)
Norcal3S.com
slage's Avatar
Drives: 92 VR4 // 96 Jeep ZJ
Trader Rating: (58)
slage Level 5slage Level 5slage Level 5slage Level 5slage Level 5slage Level 5
Great reminder! however mine was never dented 165k+ miles and still chuggin
13T's + Supporting Mods|DSM SMIC's|K-Sport Coilovers|Battery in Trunk
Alchy Injection|Saner Sway Bars|Bronze 17x9 FN01R-C's|3" Straight Pipe
1996 Grand Cherokee: My DD, 4" Lift and 31" Tires
1992 VR-4: My Weekend Warrior
slage is online now   Reply With Quote
