Old 10-03-2008, 09:37 AM   #11 (permalink)
vitalivr4's Avatar
Drives: BMW X5, 3000GT VR-4
Trader Rating: (10)
vitalivr4 is an unknown quantity at this point
Default Re: Which Spark Plug Wires to Run?
Ultra Are The Best
vitalivr4 is online now   Reply With Quote
Old 10-03-2008, 11:41 AM   #12 (permalink)
Yank in Yorkshire
bjmsam's Avatar
Drives: 94 Stealth TwinTurbo
Trader Rating: (12)
bjmsam Level 7bjmsam Level 7bjmsam Level 7bjmsam Level 7bjmsam Level 7bjmsam Level 7bjmsam Level 7bjmsam Level 7bjmsam Level 7
Originally Posted by Import Power View Post
Same 8.5 superconductor wire. Just different spark plug boots. They work just as well.
Good. I was encouraged by this thread but discouraged by posts such as these:
Originally Posted by ZephTheChef View Post
AFAIK, the straight boot performs just as well, but they lack the advantage of covering the spark plug hole like the stock style does. They do come off easier, but again, water and oil and stuff can get down there and cause you problems.
Originally Posted by Polygon View Post
For wires stick with OEM or get the MSD wires with the L-shaped boot. The straight boot has issues with arcing on the head. The L-shaped boots are the more expensive of the two.
make sure you get the right MSD wires. There are two kinds and you DON'T want the ones with the straight boots. They are the cheaper set. Make sure you get the ones with the L shaped boot.
I've heard of them arcing on the head from various people. Those two reasons make me think they are crap and you should spend the extra money for the L shaped boots.
Originally Posted by Phoenix_TT View Post
Whatever you decide to go with, stay away from straight boot wires! Straight boots can arc, and don't protect the chamber from foreign objects.
Make sure your get wires with the stock boot. I bought 9mm irridium core wires off ebay to replace my straight-boot MSDs
Originally Posted by Dewman View Post
msd 8.5mm wires are junk mine only last 1 year before they started arching
Originally Posted by Smyte View Post
I got the custom set from 3sx. The arching is coming from inside the little cylinder on the valve cover where the spark plug is at. I was told that the end that connects to the spark plug is exposed to much.
Originally Posted by TRILIGHT View Post
I bought the MSD's with the OEM boots. Dirt collects in that part of the engine fairly easily. I could not believe they were even sold the other way. I've also heard from people who have had problems removing them by having to pull on the wire. I didn't like that idea at all.
Jim's Stealth in the Bavarian Alps, 2001Jim Matthews - Yorkshire, England, UK
Team3S, 3SI #30, GTOUK #155
http://www.the-matthews.com/stealth.html
Jet Black '94 Dodge Stealth R/T Twin-Turbo AWD AWS 6-spd
Active Suspension Damping, Active Exhaust Delete, 5300K HIDs
Ek2MFG dual-flex downpipe, Zorstec custom SS cat-back dual
A'PEXi SAVC-R Mk-I, MHI TD04L-13Gs, K&N FIPK, IPS SS Y-pipe
A'PEXi SAFC 5-knob, 450cc Black Tops, MirageCorp Logger, DSM SMICs
Mobil 1 & Redline fluids, Hotwired Denso 1020 Pump, IPO/SX AFPR
SCE 332x32/322x28 cryoed StopTechs, Wilwood proportioning valves
Winter: stock alloys 17x8.5-46, Hankook Icebear W300 235/45VR17
Summer: Enkei RPM2 17x9-40, Yokohama AVS ES100 245/45ZR17
Track: Enkei RPM2 17x9-40, Yokohama A-032R Hcomp 275/40R17
My reliable daily driver since Feb 1997!
bjmsam is offline   Reply With Quote
Old 10-03-2008, 11:52 AM   #13 (permalink)
Supporting Vendor
BET-RHD's Avatar
Drives: GTO
Trader Rating: (26)
BET-RHD Level 7BET-RHD Level 7BET-RHD Level 7BET-RHD Level 7BET-RHD Level 7BET-RHD Level 7BET-RHD Level 7
Stock or MSD FTW.. I Have to agree though.. it is worth the extra to have the right boots. The "L" boots as people are calling them.
BET-RHD is offline   Reply With Quote
