Old 09-29-2008, 05:58 PM   #21 (permalink)
EVO Terminator
ramnakhle's Avatar
Drives: '97 3000GT VR-4
ramnakhle is an unknown quantity at this point
Default Re: Spark plug problem... again.
Originally Posted by Black_Sunshine View Post
rule of thumb is always hand tighten, then tighten 1/4 turn by wrench. it's always worked for me.
Duly noted. Thx.
Where's the 3K ????
ramnakhle is offline   Reply With Quote
Old 09-29-2008, 06:06 PM   #22 (permalink)
est. sept, 2000
91vr4n00maxima's Avatar
Drives: slow 97 VR4
91vr4n00maxima Level 791vr4n00maxima Level 791vr4n00maxima Level 791vr4n00maxima Level 791vr4n00maxima Level 791vr4n00maxima Level 791vr4n00maxima Level 791vr4n00maxima Level 791vr4n00maxima Level 791vr4n00maxima Level 791vr4n00maxima Level 7
thats called carbon tracking. it happens when the spark travels down the side of the plug due to a poor seal from the plug wire. you need to replace the plug that is in the cylinder thats happening on and put new wires on. as you found out you cant just change the plugs. if you put a new wire set on without replacing the plug it will happen again and the plug wire will be toast again.
97 VR4 12.417@111.16 9b time. full weight almost BPU
95 mark viii. 14.35@98
03 cobra vert. 4 mods=118mph traps
91 stealth TT. td05 18G, heads/cams, 3000lbs
95 montero SR. factory rear locker. 3.5 DOHC
91vr4n00maxima is offline   Reply With Quote
Old 09-29-2008, 06:15 PM   #23 (permalink)
Forum user
donniekak's Avatar
Drives: 92rt/tt
donniekak Level 7donniekak Level 7donniekak Level 7donniekak Level 7donniekak Level 7donniekak Level 7donniekak Level 7donniekak Level 7donniekak Level 7donniekak Level 7donniekak Level 7
That makes sense, i've never seen that happen before. I was stumped.
donniekak is offline   Reply With Quote
Old 09-30-2008, 10:53 AM   #24 (permalink)
EVO Terminator
ramnakhle's Avatar
thats called carbon tracking. it happens when the spark travels down the side of the plug due to a poor seal from the plug wire...
makes sense but let me get this straight: down the side of the plug... you mean i'm getting a spark outside of the combustion chamber? between the wire terminal and the head? wow i never knew this could happen.
Sure would explain a lot though... but what i don't get though is that since i had the injectors cleaned and replaced the damaged plug, everything's been going fine. I'm using the same old wires. Like i said before it's been well above 500 miles since that happened.
Old 09-30-2008, 10:59 AM   #25 (permalink)
est. sept, 2000
Drives: slow 97 VR4
give it more time.
Old 09-30-2008, 12:40 PM   #26 (permalink)
EVO Terminator
ramnakhle's Avatar
oh ok... hehe
Thanks for the explanation. Guess i'm off to the dealership...
cheers.
Old 09-30-2008, 01:00 PM   #27 (permalink)
Boost Happy
Black_Sunshine's Avatar
Drives: a japanese dodge
Trader Rating: (70)
Black_Sunshine Level 7Black_Sunshine Level 7Black_Sunshine Level 7Black_Sunshine Level 7Black_Sunshine Level 7Black_Sunshine Level 7Black_Sunshine Level 7
why not go afternarket instead of oem wires? u'll get better performance and it's not all that expensive.
Black_Sunshine is offline   Reply With Quote
Old 10-03-2008, 04:00 AM   #28 (permalink)
EVO Terminator
ramnakhle's Avatar
I have thought about it. Problem is not cost, but shipping cos the stuff's not available in my country so i have to have it shipped in.
I have a few things i wanna do in the near future so i'm probably gonna get the parts in one big order...
-60 K kit from 3sx
-wires
-motor mounts
-some other stuff...
What plug wires do you recommend for a stock vr-4 ? NGK? are they really better than the oem ones?
