Old 09-19-2008, 07:50 AM   #1 (permalink)
EVO Terminator
ramnakhle's Avatar
Drives: '97 3000GT VR-4
ramnakhle is an unknown quantity at this point
Default Spark plug problem... again.
Hi. keeping this short so here's the deal.
97 Vr-4 bone stock.
-Engine was missing on WOT
-Changed spark plugs, NGK plats (6J-11) Noticed one of the old (bosch, previous owner) plugs had a black line along the ceramic insulator, like a very thin but long crack through which some soot was comin out.
-Tested the car, drove perfectly 1st pull then another, then a third. On the fourth, the miss came back like nothing had happened.
-About 2 weeks later i took out the front bank plugs, one of them had the same mark i saw in the old plug. (don't know if it was the same one). Also noticed that the plugs had some brown stuff at the point where the insulator meets with the metal body of the plug. These had less than a 1000 miles on them so why are they so old-looking? is this normal?
-replaced the 1 damaged plug, cleaned injectors and the car's been running fine since.
questions: what's that stupid crack??? could it have been caused by clogged injectors (they were a bit dirty that's for sure)
how can it be avoided?
thx
Where's the 3K ????
ramnakhle is offline   Reply With Quote
Old 09-19-2008, 07:54 AM   #2 (permalink)
Now with 100% more NSX
leet's Avatar
Drives: 95 NSX and 92 TT
Trader Rating: (24)
leet Level 2leet Level 2leet Level 2
Default Re: Spark plug problem... again.
I don't know about the crack, but have you tried gapping the plugs down, start at .032 and go from there
when I was stock .032 worked well
the stealth is officially for sale, PM for info
leet is offline   Reply With Quote
Old 09-19-2008, 09:23 AM   #3 (permalink)
Senior Member
defgh1's Avatar
Drives: 99 VR4, 04Volvo V70R
Trader Rating: (8)
defgh1 Level 7defgh1 Level 7defgh1 Level 7defgh1 Level 7defgh1 Level 7defgh1 Level 7defgh1 Level 7defgh1 Level 7defgh1 Level 7defgh1 Level 7defgh1 Level 7
thx
I hope I am wrong, but it sounds like Detonation which is most frequently caused by hot spots in the combustion chamber. Hot spots will allow the air/fuel mixture to pre-ignite. If you have been having Pre-ignition for a period of time due to lean air/fuel mixture you may have damaged the piston surface resulting in hot spots. If it is a damaged piston then only correction is to replace it!
Doug H
91 Sandstorm TT, 431 AWHP, 433 ft-lbs. , Kormex 25 spline,LSD, RPS CC Clutch, 4 bolt conversion, Super 15Gs, Stage 3 heads, DSM Sidemounts, PST Driveshaft, Blitz DSBS, HKS Exhaust, 3SX Downpipe, Supra Pump, 780 cc PTE Injectors, SX Fuel reg. & dual feed, AEM, Duel WJO Wideband, HKS DL1, Alcohol Injection. Photos: -->
defgh1 is offline   Reply With Quote
Old 09-19-2008, 01:39 PM   #4 (permalink)
EVO Terminator
ramnakhle's Avatar
I don't see how that would help... I'm running stock and the NGK plats come pregapped... if i have to gap them down something else must be going wrong...
Doug H
ok...I'm worried now! how does pre-ignition / detonation feel like in the driver's seat?
I see... But since i replaced that plug and cleaned the fuel delivery system, the car's been runnin great... bout 500 miles now, better than ever...
any particular symptoms of piston damage i should be looking out for?
PS i really baby that car around... no racing, mostly cruising with a few pulls here and there...
Old 09-19-2008, 02:14 PM   #5 (permalink)
Senior Member
defgh1's Avatar
Trader Rating: (8)
Depending on the amount it can be not noticeable to engine rattle to sudden loss of power. I would keep an eye on the plugs. If they continue to look and run normal then hopefully you only had a lean condition that only affected the plug. If you keep damaging plugs then most likely you have a hot spot (damage) in that cylinder.
Doug H
Old 09-19-2008, 02:31 PM   #6 (permalink)
EVO Terminator
ramnakhle's Avatar
Doug H
OK. well right now it's purring like a kitten so i'm hoping it'll stay that way. I'll check the plugs soon to make sure all is well. I'll have some pics cos i'm no expert
Thanks for the help
Old 09-19-2008, 11:12 PM   #7 (permalink)
leet's Avatar
Trader Rating: (24)
I had to gap mine down when I was stock, as have many many other people on the boards
Old 09-20-2008, 07:06 AM   #8 (permalink)
EVO Terminator
ramnakhle's Avatar
oh ok...
but did the gap cause DAMAGE to the plug? I will get a picture of the old plug to show you that crack... pretty nasty imo for a gap
anyways i am planning to change the plugs out soon... will regap.
was power loss an issue though?
Old 09-23-2008, 01:52 PM   #9 (permalink)
EVO Terminator
ramnakhle's Avatar
Ok so i found that old plug. Wanted to post a pic just to make sure you guys knew what i was talking about.
Well?
And what's that brown stuff? the new spark plugs got this deposit very quickly, but i was driving with clogged injectors. stupid.
Old 09-23-2008, 02:00 PM   #10 (permalink)
Forum user
donniekak's Avatar
Drives: 92rt/tt
donniekak Level 7donniekak Level 7donniekak Level 7donniekak Level 7donniekak Level 7donniekak Level 7donniekak Level 7donniekak Level 7donniekak Level 7donniekak Level 7donniekak Level 7
Everybody thought you were talking about the part of the plug that is actually in the combustion chamber. Looks like maybe the valve cover gasket around the plug is leaking.
donniekak is offline   Reply With Quote
