#22 (permalink) |
est. sept, 2000
thats called carbon tracking. it happens when the spark travels down the side of the plug due to a poor seal from the plug wire. you need to replace the plug that is in the cylinder thats happening on and put new wires on. as you found out you cant just change the plugs. if you put a new wire set on without replacing the plug it will happen again and the plug wire will be toast again.
97 VR4 12.417@111.16 9b time. full weight almost BPU
95 mark viii. 14.35@98 03 cobra vert. 4 mods=118mph traps 91 stealth TT. td05 18G, heads/cams, 3000lbs 95 montero SR. factory rear locker. 3.5 DOHC ![]() |
#23 (permalink) | |
Forum user
#24 (permalink) | |
EVO Terminator
Sure would explain a lot though... but what i don't get though is that since i had the injectors cleaned and replaced the damaged plug, everything's been going fine. I'm using the same old wires. Like i said before it's been well above 500 miles since that happened. |
#25 (permalink) | |
est. sept, 2000
#28 (permalink) | |
EVO Terminator
I have a few things i wanna do in the near future so i'm probably gonna get the parts in one big order... -60 K kit from 3sx -wires -motor mounts -some other stuff... What plug wires do you recommend for a stock vr-4 ? NGK? are they really better than the oem ones? |
| Thread Tools | |
