Old 08-30-2009, 09:32 PM   #131 (permalink)
B-Man0660's Avatar
Drives: '92 Stealth TT
Trader Rating: (6)
B-Man0660 is an unknown quantity at this point
Default Re: Some quick 13T questions
No meth. I kinda hope he does.
'92 dodge stealth r/t TT - 13Ts@18psi on pump, 680cc injectors, 255lph fuel pump, AEM AFPR, Crushed DSM BOV, FMIC, EMU stage 3 with speed density, minimal performance t-case brace, EGR blockoff, DP, 3" custom single shot exhaust.
Waiting to install: RS-R Lowering Springs
B-Man0660 is offline   Reply With Quote
Old 08-30-2009, 09:41 PM   #132 (permalink)
Not here for the tuna.
lawdogg's Avatar
Drives: junk
Trader Rating: (80)
lawdogg Level 2lawdogg Level 2lawdogg Level 2lawdogg Level 2lawdogg Level 2lawdogg Level 2
FWIW with my car, even at 15psi, anthing more than 20-21 degrees advance at 5000RPM is knock city.
edit: I guess 10-11 degrees since the hybrid logger reports timing 10 degrees advanced
R.I.P.
Old 08-30-2009, 09:44 PM   #133 (permalink)
B-Man0660's Avatar
Trader Rating: (6)
uhg, I guess I'll have to actually get the palm out. I've just been using the logs from my EMU and retarding timing when it knocks or add fuel.
Old 08-31-2009, 10:50 AM   #134 (permalink)
Kibwe Walker's Avatar
Drives: 93 RT/tt
Kibwe Walker Level 1Kibwe Walker Level 1
Originally Posted by B-Man0660 View Post
Well, this is a 13T thread, it's also in my sig. As far as I know they're all TD04. Pump in MI is 93, I don't know about everywhere else.
I have seen people running 20+ with these turbos, I'm curious how much timing was being pulled.
Methanol injection or higher octane,
has everything to do with knock resistance.
With my 13t's I need to throw some e85 in there to run more than 16.5 psi and thats with the 93 octane around Nashville TN with already has a fair bit of ethanol mixed in it to raise the octane level to 93 in the first place.
Red 93 RT/tt project car
Mods: stillen dp, custom exhaust, Spec stage 2 clutch, RPS FW, 3sx lightweight crank pulley, BCP7RES-11 @ .030 gap, autometer gauges, dsm SMIC's, Tein S springs, pte 580 inj's, hotwired walbro, maximal performance solid motor mounts, DR plenum spacer.
94 vr4: RIP 4/16/09
Kibwe Walker is offline   Reply With Quote
Old 09-15-2009, 07:06 PM   #135 (permalink)
Forum user
Drives: 96 vr4
Trader Rating: (7)
ArmyVR4 is an unknown quantity at this point
I havent been able to drive my car yet. Im currently in Iraq and will be returning to the states in Nov. I m stationed out in Fort Bragg, NC but my car is in Iowa right now. While I was out here I had the car tuned. Here is a list of mods and the end product was 401HP@ 19PSI on pump. I have a link to the video as well. Rev Hard Inc was the shop that tuned my car. Its hard to see the dyno sheet, but here is the list of mods
Forged Bottom End
weisco piston 8.5:1
3sx rods
stock heads with ips 264 cams
Fidanza Adj. Cam Gears
CX Racing FMIC
Dejon Intake Pipes "blow through"
13T turbos
Cheap ebay headers "only the front one is on lol the rear one wont fit" i know need to fix this"
Downpipe, Full Cat Back exhaust IPS quad tips
AEM with all the sensors
660cc Injectors
Walbro 255 feul pump "hotwire"
Fidazna Alum. Flywheel
Southbend DXD stage 4 clutch
those are my major mods. below is the video on the dyno they sent me. They tell me the car runs awesome and pulls hard. Only issue is they say first 4 or 5 minutes of starting the car when its not warmed up it stutters a bit but after that idles just fine. Currently the car is in the paint shop getting new black paint. Should be done in the next 2wks. Cant wait for pictures.
3000gt vr4 13t turbos 19psi - Car Videos on StreetFire
I have no idea what they did they just told me they worked on it and tuned it for me. The major work was done by a member of 3si. nodoze so once I find more i'll post it up on this thread.
ArmyVR4 is offline   Reply With Quote
Old 09-16-2009, 09:21 AM   #136 (permalink)
Skeptic
bjmsam's Avatar
Drives: 94 Stealth TwinTurbo
Trader Rating: (14)
bjmsam Level 1bjmsam Level 1
8.5:1 running 19psi with no knock? Iowa... ethanol?
Jim's Stealth in the Bavarian Alps, 2001Jim Matthews - Mt. Airy, MD, USA
Team3S, 3SI #30, GTOUK #155
http://www.the-matthews.com/stealth.html
Jet Black '94 Dodge Stealth R/T Twin-Turbo AWD AWS 6-spd
Active Suspension Damping, Active Exhaust Delete, 5300K HIDs
Zorstec custom SS dual-flex DP and dual-exit cat-back, DSM SMICs
A'PEXi SAVC-R Mk-I, MHI TD04L-13Gs, K&N FIPK, IPS SS Y-pipe
A'PEXi SAFC 5-knob, 450cc Black Tops, MirageCorp Hybrid Logger
Mobil 1 & Redline fluids, Hotwired Denso 1020 Pump, IPO/SX AFPR
SCE 332x32/322x28 cryoed StopTechs, Wilwood proportioning valves
Winter: stock alloys 17x8.5-46, Hankook Icebear W300 235/45VR17
Summer: Enkei RPM2 17x9-40, Yokohama AVS ES100 245/45ZR17
Track: Enkei RPM2 17x9-40, Yokohama A-032R Hcomp 275/40R17
My reliable daily driver since Feb 1997!
bjmsam is offline   Reply With Quote
Old 09-16-2009, 02:35 PM   #137 (permalink)
Forum user
Drives: 96 vr4
Trader Rating: (7)
well im not for sure, but the shop told me no issues the tune is safe and I can drive it everyday. only problem they told me was the start up but after 5 minutes of warm up it is fine after that. i'll find out more information once I get the car from the shop when I come back from iraq.
Old 09-16-2009, 02:36 PM   #138 (permalink)
Forum user
Drives: 96 vr4
Trader Rating: (7)
oh and i just use regular premium 93 octane. I choose not to run 93 octane 10% ethanol just because it burns quicker and a tank of gas dosent last as long with ethanol.
