Old 11-05-2007, 07:44 PM   #1 (permalink)
Foolish
Mikes95RT Level 1Mikes95RT Level 1
Default So it was a GOOD THING that I broke that piston.
Some of you have followed my 60K service where I happened to trash a perfectly good motor.
Cliff notes..I was doing a 60K with oil pump and decided to look at the rod bearings. Pulled a piston down after unbolting the rod and the piston bumped the crank counterweight and broke off the little tab that sticks out on the piston.The bearings all looked good and I had even and great compression across the board at 118K.Basically mad as hell because I trashed a perfectly running motor.
Forward to Friday. I picked up the rods,pistons and crank to plastigauge the rods as the machine shop said my crank was on the outter limit of tolerance.I wanted to check them myself.I took the pistons in the block so I hadn't looked at them up close.After inspection I find that the #6 piston had a broken ring land.The car had run fine and had great compression. So now I don't feel so bad about breaking that little piece off.It was a blessing in disguise.Replacing them with Ross forged 9:1. A little ray of light in my otherwise crappy month(3s) wise.
Mike Sullivan 95 Stealth FWD TT conversion 10:1 compression@12 PSI
Go...
13c turbos,450cc injectors,
TT pump,3SX braided return line
TurboXS type S open B.O.V.
ATR down pipe
Stuff...
K&N filter,unorthodox U.D.P., Optima red top,
ET performance krank vents
3SX lower poly mounts
Polished y pipe.
cool...
Stock intercoolers,Alcohol injection thanks to turbomirage.com
Tranny...
Auto to 5spd conversion to AWD 5spd/fwd
SPEC Stage 2 AWD clutch 3SX braided clutch line.
Wheels...
Exel Mimi
Fulda extremo 245-40-17
Intrax springs
Control...
Apexi SAFC 2,TT ECU and harness.
TurboXS M.B.C.
M.S.D. Knock alert
Gauges...Autometer...
E.G.T.,Boost,Air/Fuel ratio meter.
13.599@112 at 13psi....traps high enough for 12.3's with the traction for mid 13's..gotta love FWD
All aftermarket parts happily purchased from 3SX performance.com
Turbo conversion parts happily purchased from Mitsuspecialties.
Mikes95RT is offline   Reply With Quote
Old 11-05-2007, 07:45 PM   #2 (permalink)
Damage Control
Stealthee's Avatar
Drives: 1994 Stealth
Trader Rating: (78)
Default Re: So it was a GOOD THING that I broke that psiton.
Good to hear things are turning around for you Mike. I am sure you are going to love those 9:1 pistons.
Old 11-05-2007, 07:50 PM   #3 (permalink)
Foolish
Default Re: So it was a GOOD THING that I broke that piston.
Your Quaife diff is boxed in my living room and one tranny is boxed up. I need to find another 2 boxes.Who knew how hard it would be to ship two trannies?Anyway, I have tomorrow afternoon off and it's off to UPS.Looking at the Quaife and how nice it is makes me want to keep it.Too bad it will only work as a door stop with the tranny I have now.
Old 11-05-2007, 07:57 PM   #4 (permalink)
Damage Control
Stealthee's Avatar
Trader Rating: (78)
Like I said man no worries. I know shit can happen.
Old 11-05-2007, 10:16 PM   #5 (permalink)
eri536's Avatar
Drives: 1997 pearl white vr4
eri536 is an unknown quantity at this point
118 is terrible compression it should be around 155 - 160, why didnt you go with 8:1 or 8.5:1 instead of 9
97 white vr4
Current car
96 white vr4 - RIP
2000 eclipse gt - biggest p.o.s ever
eri536 is offline   Reply With Quote
Old 11-05-2007, 10:18 PM   #6 (permalink)
Damage Control
Stealthee's Avatar
Trader Rating: (78)
Reading comprehension > you
He said he had great compression at 118k miles......
Also 9:1 allows for better off boost response and allows for more "error" over the 10:1 hes been running for years.
Old 11-05-2007, 11:15 PM   #7 (permalink)
eri536's Avatar
i didnt see the k
